On Jun 12, 8:29*am, Scott wrote:
5Z wrote: On Jun 12, 7:28 am, Jim Beckman wrote: At 04:22 12 June 2008, wrote: Center reported a Mayday from a "powered glider with a failed engine" Sounds like the pilot involved has a really odd sort of mindset - mired in the world of powered flight. *I mean, what's the use of those long wings if you're not going to use them? OK, I'm sure some of you are jesting, but here's what *might* have happened: Pilot is soaring over remote Utah with some reasonably safe looking dry lakes, pastures, whatever below. *Runs out of lift and decides it's time to start the engine while within easy range of one of these landing options. *The engine fails to start, the location is extremely remote, so pilot makes a MAYDAY call while still in the landing pattern to ensure someone will come get him if problems arise. If he had a transponder or SPOT, he might activate these before landing, again in case something bad happens. Easy Cowboys, if you transmit a MAYDAY or activate your transponder to Mayday before landing and land where radio transmission is not likely to reach anyone, wouldn't this activate SAR missions? If one had ELT or SPOT this could be used on the ground anywhere except in dense jungle, right? Granted in Utah & Nevada you could actually land in an area so remote that not even a paved road for 50 miles is near your dry lake or open desert landing, in which case this would be prudent. I guess what I'm saying is, if you could still be in deep doo-doo after a landing, it would be prudent to Mayday, but if the landing is pretty near civilization, maybe hold off till you get on the ground? Any comments from SAR people on this? Thanks, Wayne |
Sparrowhawk 300 km in Utah | Mike the Strike | Soaring | 8 | May 6th 07 03:33 AM |
MAYDAY in the Everglades | Marty from Sunny Florida | Owning | 46 | May 16th 05 10:01 PM |
Utah Bush Flying | O-Usagi | Piloting | 3 | March 22nd 04 04:24 PM |
Region 9 - Parowan Utah | Dirk Elber | Soaring | 0 | February 9th 04 12:54 AM |
St George Utah | Casey Wilson | Piloting | 6 | August 9th 03 04:17 AM |
