Mechanics of Elevator Trim. In Detail.
Old June 14th 08, 11:26 PM posted to rec.aviation.student,rec.aviation.piloting
Ron
Default Mechanics of Elevator Trim. In Detail.
On Sat, 14 Jun 2008 00:33:00 -0700 (PDT), "Ken S. Tucker"
On Jun 13, 9:23 pm, Ron wrote:
On Fri, 13 Jun 2008 11:02:35 -0700 (PDT), "Ken S. Tucker"
On Jun 12, 9:53 pm, Ron wrote:
On Thu, 12 Jun 2008 09:43:07 -0700 (PDT), "Ken S. Tucker"
On Jun 12, 5:08 am, Tina wrote:
Yes, the time my son spent with canard aircraft brought out all sorts
of interesting information about canards and the history of trying to
scale up Rutan's original concept Beech Starship. The smaller true
canards like the Long-eze are pretty good aircraft. However there is
a reason why we don't see large (six plus passenger) true canards.
It's the relationship between CG, fuel load, payload and range.
Apparently in the scale up process there is a point where it is no
longer practical.
Ron Kelley
Hmm, how the XB-70 or this,
http://en.wikipedia.org/wiki/Boeing_Sonic_Cruiser
True, the XB-70 was a qualified success of a large canard type
aircraft. Most of it's problems were due to system failures and
trying to fly at Mach 3.0. The only control issues I know of were
related to overly sensitive pitch response to control inputs. Ref:http://www.labiker.org/xb70.html
Thanks for that link.
As far as I know the Boeing Sonic Cruiser hasn't gone beyond the
artists concept stage. I guess it's no accident that all the current
crop of passenger jets look alike. That could be partially due to the
reluctance of any large airframe manufacturer to take a gamble on
trying to certify any new "radical" design. Who knows.
Personally, I am intrigued by the three surface aircraft like the
Piaggio. They seem to have done pretty good with their design. One
wonders if given enough time, money and talent, there is some room for
improvement there.
Yes! That Piaggio is one real impressive piece of
aerodynamics, and it sounds very pilot user-friendly.
Very remarkable how they utilized the canard.
I think the aircraft business is extremely conservative.
KISS applies, also canards are difficult for the average
pilot to understand, (Hey man, you got that thar tail on
the wrong end :-).
Would it not also be true that passive stability is not as important
in larger modern airplanes? I would guess (again, I admit being
ignorant of the realities) that adding a 10% aerodynamically induced
increased load on bigger aircraft would be avoided for efficiency
reasons? It might be better to have enough fly by wire and computer
induced stability instead. I don't know enough about this stuff to
even find the back of an envelope, let alone do a calculation there.
Canards are NOT simple, I've designed quite a few,
and studied others, especially Rutan's.
I find they can be optimised for a given air speed
and are much better than the conventional lay-out.
The main problem is designing the stall.
Ken
Anyone who can design a successful canard aircraft has my respect. I
didn't learn a whole lot about the design aspects from my son (he was
in flight test, not design), but what we did learn was everything
interacted with everything else. The job was interesting, but didn't
last long.
Your son sounds like a cool dude.
Yeah, I kinda like him. ;-)
The major PITA is designing aircraft to be efficient
at cruise, but safe all the way to stalling, and
recoverable. The difficulty is the movement of the
Center of Lift forward on the main wing as stall
begins.
I seem to remember a problem they had with the fuel load and the
center of lift moving close to (ahead/behind?) the CG. They also had
a problem with getting enough fuel on board (this was a single engine
turboprop) and where to put it to get the range they wanted.
I guess one way to figure that out is to place weigh
scales under the tires and then fill in increments,
to give the exact CG in horizontal pitch, that can
be readily calculated by the ratios. Fuel movement
for various pitchs would affect the CG.
While on the subject of trim, any excessive trim
required *should* indicate a possible excursion
from the appropriate CG - CL relation.
Alas, we'll never know if they could have solved their problems. The
company went out of business. They made some smart moves and some
not-so-smart moves (based on investor funding and lack of funding) and
finally closed the doors.
Regards
Ken
PS: I turned on a TV show "ECW" (no volume),
this is Friday PM here...near midnight, and two
busty chicks (a blonde and redhead) dressed up
in vinyl are beating each other up. It looks rough!
Back on the "old days" we used to watch Roller Derby on TV. Man, you
wouldn't want to mess with those ladies if you didn't want your head
handed to you on a platter.
Ron Kelley
Old June 16th 08, 12:18 AM posted to rec.aviation.student,rec.aviation.piloting
Ken S. Tucker
longer practical.
Ron Kelley
improvement there.
the wrong end :-).
Ken
last long.
begins.
Regards
Ken
Wow, you're dating yourself. (I'm a 1953 boomer).
Yeah Roller Derby, Sat or Sun afternoon on TV,
and some actually got hurt, but I do respect those
stunt skills as long as it's healthy, (I used to wrestle
and do some martial arts).
I think it's mostly sexxy, with the men sometimes
wearing panties and the gals in vinyl.
I sure hope they would stop getting injured, and
just have fun.
Same as stunt flying, cut the risk, and show off
the skill.
Ron Kelley
Regards
Ken
Old June 22nd 08, 02:19 AM posted to rec.aviation.student,rec.aviation.piloting,alt.usenet.kooks
Bertie the Bunyip[_25_]
"Ken S. Tucker" wrote in
out all sorts of interesting information about canards and
the history of trying to scale up Rutan's original concept
Beech Starship. The smaller true canards like the
canards. It's the relationship between CG, fuel load,
payload and range. Apparently in the scale up process
there is a point where it is no longer practical.
Ron Kelley
and trying to fly at Mach 3.0. The only control issues I know
of were related to overly sensitive pitch response to control
the artists concept stage. I guess it's no accident that all
the current crop of passenger jets look alike. That could be
partially due to the reluctance of any large airframe
manufacturer to take a gamble on trying to certify any new
the Piaggio. They seem to have done pretty good with their
design. One wonders if given enough time, money and talent,
there is some room for improvement there.
the wrong end :-).
important in larger modern airplanes? I would guess (again,
I admit being ignorant of the realities) that adding a 10%
aerodynamically induced increased load on bigger aircraft
would be avoided for efficiency reasons? It might be better
to have enough fly by wire and computer induced stability
calculation there.
Ken
respect. I didn't learn a whole lot about the design aspects
from my son (he was in flight test, not design), but what we
did learn was everything interacted with everything else. The
job was interesting, but didn't last long.
begins.
had a problem with getting enough fuel on board (this was a single
engine turboprop) and where to put it to get the range they
wanted.
and finally closed the doors.
Regards
Ken
Obviously where you learned both your physics and psychology.
Bertie
F-100 detail Pjmac35 Aviation Photos 0 July 26th 07 10:29 AM
Finding "Neutral" Position on Piper Elevator/Trim Tab [email protected] Owning 10 December 7th 06 01:43 PM
Detail pops in too late in FS2004 CatharticF1 Simulators 0 August 27th 03 03:25 AM
