ARC Wiring Diagrams
Old June 17th 08, 10:50 PM posted to rec.aviation.owning,rec.aviation.homebuilt,rec.aviation.misc,rec.aviation.marketplace
Darrel Toepfer
Default ARC Wiring Diagrams
I have a recently purchased (eBay) Aircraft Radio Corporation audio
control panel with R-402 Marker Beacon Receiver. I don't have the wiring
diagrams or operations manuals for either unit. I've looked on the
Aeroelectric site and the usual search places with no luck turning up
the data I need...
Audio Control Panel Assy
Incandescent Lighting
Assy. No. 2470003-1 / 2470013-1
R-402A PN 42410-512828
Serial 22886
Aircraft Radio and Control
Div Cessna Aircraft Co
Boonton NJ
Pictures of the units are available he
http://www.whodat.net/n8629c
Also looking for suggestions on a budget (homebrew) antenna for the
above...
TIA...
Darrel Toepfer
Eunice, LA. 4R7
Old June 18th 08, 01:15 AM posted to rec.aviation.owning,rec.aviation.homebuilt
RST Engineering
What kind of airplane and do you want it to look homebrew or store-boughten?
"It is the mark of an educated mind to be able to entertain a thought
without accepting it."
--Aristotle
Serial 22886
above...
TIA...
Darrel Toepfer
Eunice, LA. 4R7
Old June 18th 08, 01:47 AM posted to rec.aviation.owning,rec.aviation.homebuilt
Scott Skylane
the data I need...
Serial 22886
Boonton NJ
Darrel,
I can scan an install diagram for the audio switching panel, but I don't
have a diagram for the panel, itself. BTW, those are rather notorius
units these days, and I notice the sticker on yours labeling it as a
"core". Those blue transmit relays are some of the biggest offenders,
but at least everything is easy to get to!
Happy Flying!
Scott Skylane
Old June 19th 08, 04:52 AM posted to rec.aviation.owning,rec.aviation.homebuilt
Darrel Toepfer
wiring diagrams or operations manuals for either unit. I've looked on
the Aeroelectric site and the usual search places with no luck
turning up the data I need...
Serial 22886
Boonton NJ
Darrel,
don't have a diagram for the panel, itself. BTW, those are rather
notorius units these days, and I notice the sticker on yours labeling
it as a "core". Those blue transmit relays are some of the biggest
offenders, but at least everything is easy to get to!
Happy Flying!
Scott Skylane
At this point I'd be happy for anything... Thanks... This is a valid
reply address from the national providers, but you can use my last name
and any of the following too: gmail.com hotmail.com bellsouth.net
Old June 19th 08, 04:56 AM posted to rec.aviation.owning,rec.aviation.homebuilt
Darrel Toepfer
store-boughten?
Thanks for the reply Jim, its a Piper PA-20, not particular at the moment.
I need to take a picture of the vertical antenna inside the tail and get an
opinion from you as to whether to remove it or not. I figure it'll make a
better one (more crash worthy) for the ELT than the whip thats inside the
baggage compartment now (or was until I stripped out the fuselage)...
Old June 19th 08, 05:13 AM posted to rec.aviation.owning,rec.aviation.homebuilt
Scott Skylane
Sent to Gmail...
Happy Flying!
Scott Skylane
Old June 20th 08, 04:27 AM posted to rec.aviation.owning,rec.aviation.homebuilt
Darrel Toepfer
Sent to Gmail...
Got it, thanks... Haven't verified if it matches yet though...
Old August 19th 11, 03:21 PM
Jyncus Jyncus is offline
Junior Member
First recorded activity by AviationBanter: Aug 2011
Sent to Gmail...
Happy Flying!
Scott Skylane
Scott,
I'm in need of the same pinout for a 2470003-1 Cessna audio panel; if you still have a scan available, would you mind emailing it to me? My email address is will.carroll AT gmail.com
Thanks!
Will.
Old September 6th 14, 11:17 AM
okey1 okey1 is offline
Junior Member
First recorded activity by AviationBanter: Sep 2014
the data I need...
Serial 22886
Boonton NJ
Darrel,
Happy Flying!
Scott Skylane
I am looking for a wiring diagram for the Audio Control Panel Assy Incandescent Lighting Assy. NO.2470003-1 also. I know this is an old thread, but maybe someone is still watching and can help me locate one.
Okey1
Old April 21st 15, 08:30 PM posted to rec.aviation.owning
I am looking for a pinout or install manual for an ARC audio control panel 2470003-1 (2470013-1).
Any help greatly appreciated.
ARC Wiring Diagrams Darrel Toepfer General Aviation 0 June 17th 08 10:50 PM
Canadian aiport diagrams on-line Icebound Piloting 0 May 31st 05 02:13 AM
V-n Diagrams john smith Piloting 19 August 30th 04 02:48 PM
Piper Cheyenne wiring diagrams. Steve Piloting 1 April 7th 04 03:50 AM
Piper Cheyenne Wiring Diagrams Steve Restoration 0 April 7th 04 03:03 AM
