Future of Electronics In Aviation
Old June 19th 08, 06:11 PM posted to rec.aviation.piloting,rec.aviation.student
Le Chaud Lapin
Default Future of Electronics In Aviation
Hi All,
I have noticed that each time this subject is broached, there seem to
be many who are perturbed by the idea of electronics/software assuming
a primary role (control, stabilization, etc.) in GA aircraft.
There are some who believe that electronics and software are sorely
underutilized. The electronics that are used are mostly employed in
an ancillary role, like providing data to a pilot, etc.
There are others who feel that electronics should be fundamentally
integral to the design of the aircraft from the start, meaning that
any potential opportunity for use of electronics should be employed,
as it is almost always the case that digital version of a mechanical,
analog part is better on many axes, including weight, cost,
reliability, controllability, etc.
Ken Tucker mentioned a rotary wing aircraft for his project. I have
not specified what type of propulsion mechanism I have in mind for my
project. Both of us feel that electronic, fly-by-wire is the future of
aviation.
What do you think?
1. Do you think that current GA aircraft use not enough electronics?
2. Do you think that current GA aircraft use too much electronics?
3. Do you think electronics should retain a peripheral role ? (Garmin,
etc) but not be used in control paths (fly-by-wire)?
4. What role will electronics play in aicraft designed in the year
2108?
5. What will the aircraft look like in 2108?
6. Any other thoughts...
-Le Chaud Lapin-
Here is an excerpt from a concurrent thread, where the conversation
seems to be turning toward Electronics-Or-Not:
On Jun 19, 11:16 am, wrote:
On Jun 19, 10:40 am, wrote:
On Jun 19, 7:26 am, wrote:
The notion of first principles, like some of the conservation laws,
seems to be lost on Le Chaud and others. He calls himself an engineer,
but seems not very familiar with Newton, or concepts like energy
density when talking about a prime mover, or. . . but why go on?
Austin has its village idiot.
Lots of guys like that. The idea that electronics can somehow
make an airplane lighter and faster and better, all at once, is just
an obsession with electronics and computers. The idea that electric
power is green is another falsehood; where does most electricity come
from? Hydroelectric dams (devastated valleys), coal (dirty), natural
gas (CO2 and an increasingly limited resource), nuclear (dangerous and
waste problems), and so on. Hydrogen fuel cells, even if they worked
well and were affordable, require hydrogen, which requires the
electrolysis of water, which needs vast amounts of electricity. Other
methods of storage involve heavy metals and their dangers. The idea
that a helicopter is easy to build (with biplane blades, yet, which
was tried in the early years of 'copters) just reveals that the writer
knows nothing of the problems that gyroscopic precession present to
all rotating components of the helicopter, to say nothing of the AOA
and airspeed variations of all rotor blades during flight. Helicopter
flight is appallingly complex and it's a wonder it happened so soon
after fixed-wing flight (35 years or so).
Dan
Here is a frightening thought. If Le Chaud is in fact an engineer,
someone is paying him money for his lack of knowledge of basics, like
the power demand to keep a something with a specific gravity greater
than its environment suspended there. Well, that may be second term
physics. Lift ferries indeed.
I wonder how long it would take me to understand his true worth -- I
do make mistakes in hiring, but rarely in discharging.
Old June 19th 08, 06:40 PM posted to rec.aviation.piloting,rec.aviation.student
Jim Stewart
Le Chaud Lapin wrote:
What do you think?
I think you are off-topic for rec.aviation.student
Please do not crosspost to non-relevant groups.
Old June 19th 08, 07:04 PM posted to rec.aviation.piloting,rec.aviation.student
Le Chaud Lapin
What do you think?
Both groups begin with "rec", which means "recreation" to mean, which
applies at least a minimal amount of amusement.
And since students possess brains, ideas, and opinions, just as do
licensed pilots, they might find the post just as amusing as pilots.
-Le Chaud Lapin-
Old June 19th 08, 07:05 PM posted to rec.aviation.piloting,rec.aviation.student
In rec.aviation.piloting Le Chaud Lapin wrote:
Hi All,
aviation.
What do you think?
2108?
1. Real things cost real money.
2. If some gizmo in an automobile goes tits up, you coast to the side of
the road and call AAA. If some gizmo in an airplane goes tits up,
the outcome probably won't be as benign.
3. There's an old aerospace saying about certain people that goes along
the lines of "He always seems to be able to come up the the ten
thousand dollar solution to the 98 cent problem".
4. Have you seen a current production aircraft?
5. Have you seen the price tag of a current production aircraft?
6. Fly by wire was invented to solve the problems of huge control
forces in big airplanes and instability in highly manueverable
aircraft such as fighters. Neither problem exists in GA aircraft.
Jim Pennino
Remove .spam.sux to reply.
Old June 19th 08, 07:07 PM posted to rec.aviation.piloting,rec.aviation.student
Le Chaud Lapin
Hi All,
underutilized. *The electronics that are used are mostly employed in
Ken Tucker mentioned a rotary wing aircraft for his project. *I have
aviation.
What do you think?
2108?
* *the road and call AAA. If some gizmo in an airplane goes tits up,
* *the outcome probably won't be as benign.
* *the lines of "He always seems to be able to come up the the ten
* *thousand dollar solution to the 98 cent problem".
* *forces in big airplanes and instability in highly manueverable
* *aircraft such as fighters. Neither problem exists in GA aircraft.
I must ask then, if one were to look at a typical GA aircraft, in the
year 2100, in your opinion, will it be as devoid of electro-mechanical
controls as it is today?
What will it look like?
-Le Chaud Lapin-
Old June 19th 08, 07:30 PM posted to rec.aviation.piloting
Jim Logajan
Your premise is simply incorrect. You took this post as support for your
premise:
just an obsession with electronics and computers.
And basically misunderstood what it was objecting to.
A fair number of homebuilts and certified GA aircraft are now being
outfitted with autopilots anyway, so I'm not sure your premise has any
merit even absent your misunderstanding of the post in question.
Old June 19th 08, 07:35 PM posted to rec.aviation.piloting,rec.aviation.student
Hi All,
underutilized. ?The electronics that are used are mostly employed in
Ken Tucker mentioned a rotary wing aircraft for his project. ?I have
aviation.
What do you think?
2108?
? ?the road and call AAA. If some gizmo in an airplane goes tits up,
? ?the outcome probably won't be as benign.
? ?the lines of "He always seems to be able to come up the the ten
? ?thousand dollar solution to the 98 cent problem".
? ?forces in big airplanes and instability in highly manueverable
? ?aircraft such as fighters. Neither problem exists in GA aircraft.
Since electro-mechanical adds cost, complexity, and weight with no
advantage, what do you think?
Like they do now.
Jim Pennino
Old June 19th 08, 07:56 PM posted to rec.aviation.piloting,rec.aviation.student
Le Chaud Lapin
Hi All,
aviation.
What do you think?
2108?
I think the opposite.
Like they do now.
I guess that's reasonable. It is conceivable that typical Cessna willl
look the same in 2108 as it does in 2008.
How about 2508?
Will the typical Cessna (or whatever dominant GA manufacturer make)
look roughly the same in 2508 as it does in 2008, using essentially
the same mechanical controls (wires, pulleys, bellcranks, etc.)
-Le Chaud Lapin-
Old June 19th 08, 07:58 PM posted to rec.aviation.piloting,rec.aviation.student
es330td
On Jun 19, 1:11*pm, Le Chaud Lapin wrote:
Hi All,
What do you think?
2108?
I will answer your questions by starting with a question of my own:
which is a more reliable mode of transportation, a 1964 Mustang or a
1994 Mustang? If you had to pick one in which you got one chance to
turn the key and it had to start and get you where you need to go,
which one would you pick?
I think that electronics are great in airplanes that are flown
frequently and checked over regularly by professional mechanics.
Those kinds of planes have additional concerns that don't really
affect GA; things like cost efficiency, payload, range, etc. Given
that GA planes can be asked to sit, unflown, in a hangar for extended
periods and then be called on to fly a cross country trip, I think
that absolute reliability is the #1 factor over all else when it comes
to making choices about the powerplant and control surfaces that keep
the plane off the ground.
As pointed out above, if something goes wrong in the air you can't
just coast over to the side of the road when something fails at FL65.
Something else that is extremely significant is that in the analog,
physical world, most things don't fail out of the blue and when they
do, they don't usually fail completely. You start to get indications
from the plane that something is having a problem long before it
actually fails. Computers, on the other hand can go from 100% to 0%
in the blink of an eye without warning.
I have no problems with all the avionics in the world helping me do my
job of flying the plane; radar, strike finders, WAAS, GPS, IFR, XM
Weather but to keep GA in the hands of everyday pilots fly-by-wire
needs to remain in the world of a different kind of plane and pilot.
Old June 19th 08, 08:08 PM posted to rec.aviation.piloting,rec.aviation.student
gatt[_5_]
What do you think?
Not at all. Basic airplanes used for aerobatics, recreation, crop
dusting and other cross-country activities don't need all the crap, and
the extra weight involved with all it reduces performance and creates
potential issues. I had an electric window wire catch fire in my old
Chevy Blazer one time. What the hell? I don't need electric windows
any more than I need a fire in my door.
Not really. GA is a broad spectrum, and things like GPS and glass panels
are huge workload relievers for cross-country operations and things like
that. You wouldn't want all that crap in an ultralight--although
NWPilot has a kickass electronic kneeboard--but for larger, faster or
more navigation-oriented aircraft it's good to have.
I'd hate to be reliant on an electrical system and have an electrical
fire or fuses blowing. For comparison, I couldn't roll down the window
in my Chevy until I fixed the wiring. That really sucked.
Can't wait to find out. Hopefully we'll still be able to afford to fly
them.
-c
FA: 1-Day-Left: 3 Advanced AVIATION Books: Aviation Electronics, Air Transportation, Aircraft Control and Simulation Mel[_2_] Aviation Marketplace 0 September 8th 07 01:37 PM
FA: 3 Advanced AVIATION Books: Aviation Electronics, Air Transportation, Aircraft Control and Simulation Derek Aviation Marketplace 0 September 3rd 07 02:17 AM
FA: 1-Day-Left: 3 AVIATION Books: Aviation Electronics, Air Transportation, Aircraft Control and Simulation Jeff[_5_] Aviation Marketplace 0 September 1st 07 12:45 PM
FA: 3 AVIATION Books: Aviation Electronics, Air Transportation, Aircraft Control and Simulation Jon[_4_] Aviation Marketplace 0 August 24th 07 01:13 AM
FA: 3 ADVANCED AVIATION Books: Aviation Electronics, Air Transportation, Aircraft Control and Simulation Larry[_3_] Aviation Marketplace 0 August 6th 07 02:23 AM
