First U.S. Pilot Jailed For A Domestic Aircraft Accident
Old June 20th 08, 08:40 PM posted to rec.aviation.piloting
Darkwing
Default First U.S. Pilot Jailed For A Domestic Aircraft Accident
"Larry Dighera" wrote in message
Here's a timely story about piloting and the law. While I might
disagree with some of the FSDO Inspector's conclusions, there seems to
be little doubt that the pilot made a fatal mistake in failing to
realize the substantial and unreasonable risk of death or great bodily
harm flying low over the river created.. That said, you can bet the
DA wasn't offering a plea bargain because he believed a conviction was
assured.
http://www.aopa.org/members/files/pi...ident0807.html
July 2008 Volume 51 / Number 7
After the Accident
From ultimate freedom to incarceration
By Dave Hirschman
This year, Strub became the first U.S. pilot jailed for a domestic
aircraft accident. He pleaded guilty to reduced charges of
negligent operation of a motor vehicle and disorderly conduct and
was sentenced to 30 days in jail, 150 days home confinement,
fines, court costs, and two years probation during which he won't
be allowed to fly. ...
snip
Sounds like an unfortunate accident caused by just flying to damn low.
Unfortunately if you screw around it can bite you, whether you're flying an
airplane or driving a car.
Old June 20th 08, 08:38 PM posted to rec.aviation.piloting
Here's a timely story about piloting and the law. *While I might
harm flying low over the river created.. *That said, you can bet the
assured.
* *http://www.aopa.org/members/files/pi...ident0807.html
* *July 2008 *Volume 51 / Number 7
* *After the Accident
* *From ultimate freedom to incarceration
* *By Dave Hirschman
* *This year, Strub became the first U.S. pilot jailed for a domestic
* *aircraft accident. He pleaded guilty to reduced charges of
* *negligent operation of a motor vehicle and disorderly conduct and
* *was sentenced to 30 days in jail, 150 days home confinement,
* *fines, court costs, and two years probation during which he won't
* *be allowed to fly. ...
snip
airplane or driving a car.- Hide quoted text -
- Show quoted text -
From what I read of the accident, I'd say he was being irresponsible.
Taking someone on a sight seeing flight that low to the ground is not
safe. He got off fairly light considering he was responsible for
causing someone's death.
Old June 20th 08, 10:37 PM posted to rec.aviation.piloting
Larry Dighera
On Fri, 20 Jun 2008 12:38:21 -0700 (PDT), wrote in
safe.
Just out of curiosity, what do you consider unsafe about it?
Old June 21st 08, 04:41 AM posted to rec.aviation.piloting
safe.
Oh, I don't know, power lines???
Old June 21st 08, 04:42 AM posted to rec.aviation.piloting
safe.
Trees?
Engine failure at 20 feet?
Bird strike at low altitude?
Old June 21st 08, 10:45 AM posted to rec.aviation.piloting
Mxsmanic
Larry Dighera writes:
A flight that low should be considered unsafe by default, unless the entire
route has been recently scouted in advance (and in person, not by consulting
charts) to verify that no obstacles exist anywhere near the planned altitude
above ground of the flight. There will be no time or space to deal with such
obstacles during the flight itself.
Old June 20th 08, 11:39 PM posted to rec.aviation.piloting
Larry Dighera
On Fri, 20 Jun 2008 15:40:14 -0400, "Darkwing"
theducksmail"AT"yahoo.com wrote in
I wonder if those power lines are charted or NOTAMed.
Here's a chart centered on Alexander Field South Wood County (ISW):
http://skyvector.com/perl/code?id=KISW&scale=1
Here's a satellite image:
http://maps.google.com/maps?f=q&hl=e...91231&t=h&z=13
Current NOTAMs:
https://pilotweb.nas.faa.gov/geo/ica...=KISW&radius=2
I don't find any mention of power lines across the river. How is a
pilot to know they are there?
Perhaps there is some culpability on the part of the owner of the
presumably unmarked power lines that cross the river:
Here's the Advisory Circular AC 70/7460-1K Obstruction Marking and
Lighting:
http://www.airweb.faa.gov/Regulatory_and_Guidance_Library/rgAdvisoryCircular.nsf/0/b993dcdfc37fcdc486257251005c4e21/$FILE/AC70_7460_1K.pdf
a. Spherical Markers. Spherical markers are used
to identify overhead wires. Markers may be of
another shape, i.e., cylindrical, provided the projected
area of such markers will not be less than that
presented by a spherical marker.
1. Size and Color.
The diameter of the markers used on extensive
catenary wires across canyons, lakes, rivers, etc.,
should be not less than 36 inches (91cm). Smaller
20-inch (51cm) spheres are permitted on less
extensive power lines or on power lines below 50 feet
(15m) above the ground and within 1,500 feet (458m)
of an airport runway end. Each marker should be a
solid color such as aviation orange, white, or yellow.
2. Installations.
(a) Spacing. Markers should be spaced
equally along the wire at intervals of approximately
200 feet (61m) or a fraction thereof. Intervals
between markers should be less in critical areas near
runway ends (i.e., 30 to 50 feet (10m to 15m)). They
should be displayed on the highest wire or by another
means at the same height as the highest wire. Where
there is more than one wire at the highest point, the
markers may be installed alternately along each wire
if the distance between adjacent markers meets the
spacing standard. This method allows the weight and
wind loading factors to be distributed.
(b) Pattern. An alternating color scheme
provides the most conspicuity against...
Operating an aircraft without adequate preflight planning is ALWAYS a
bad idea. In this case, it's not clear if there was adequate
information available to the pilot about the hazard of wires strung
across the river.
Old June 21st 08, 03:30 AM posted to rec.aviation.piloting
More_Flaps
Here's a chart centered on Alexander Field South Wood County (ISW):http://skyvector.com/perl/code?id=KISW&scale=1
Here's a satellite image:http://maps.google.com/maps?f=q&hl=e...dwards,+wi&ie=...
Current NOTAMs:https://pilotweb.nas.faa.gov/geo/ica...=KISW&radius=2
I don't find any mention of power lines across the river. *How is a
Lighting:http://www.airweb.faa.gov/Regulatory...ry/rgAdvisoryC...
* * a. Spherical Markers. Spherical markers are used
* * to identify overhead wires. Markers may be of
* * another shape, i.e., cylindrical, provided the projected
* * area of such markers will not be less than that
* * presented by a spherical marker.
* * 1. Size and Color.
* * The diameter of the markers used on extensive
* * catenary wires across canyons, lakes, rivers, etc.,
* * should be not less than 36 inches (91cm). Smaller
* * 20-inch (51cm) spheres are permitted on less
* * extensive power lines or on power lines below 50 feet
* * (15m) above the ground and within 1,500 feet (458m)
* * of an airport runway end. Each marker should be a
* * solid color such as aviation orange, white, or yellow.
* * 2. Installations.
* * (a) Spacing. Markers should be spaced
* * equally along the wire at intervals of approximately
* * 200 feet (61m) or a fraction thereof. Intervals
* * between markers should be less in critical areas near
* * runway ends (i.e., 30 to 50 feet (10m to 15m)). They
* * should be displayed on the highest wire or by another
* * means at the same height as the highest wire. Where
* * there is more than one wire at the highest point, the
* * markers may be installed alternately along each wire
* * if the distance between adjacent markers meets the
* * spacing standard. This method allows the weight and
* * wind loading factors to be distributed.
* * (b) Pattern. An alternating color scheme
* * provides the most conspicuity against...
bad idea. *In this case, it's not clear if there was adequate
across the river. *
Old June 21st 08, 03:33 AM posted to rec.aviation.piloting
More_Flaps
across the river. *
He would not have hit them if he had not been low flying in an area
NOT approved for low flight. Since they are well below 500' and not
near an airfield they don't need markings or notams to avoid them,
just for the pilot obey the FARs
Cheers
Old June 23rd 08, 06:13 PM posted to rec.aviation.piloting
Gig 601Xl Builder
Current NOTAMs:
The key word in the AC below is in a.1. "extensive." Is one set of wires
considered extensive?
Lighting:
1. Size and Color.
2. Installations.
across the river.
Then he should not have been site seeing with a passenger there until he
knew what was there.
When I got my helicopter rating I was taught to assume wires were every
where.
Comair Accident pilot sues... [email protected] Piloting 38 August 30th 07 10:26 PM
Female pilot accident rates NoPoliticsHere Piloting 132 January 23rd 05 03:07 PM
Winch accident in New Zealand, can low time student pilot be blamed? Andre Volant Soaring 18 December 7th 04 02:26 PM
Website of Aircraft Accident Video Cockpit Colin Piloting 1 August 20th 04 10:57 AM
Coming soon to the US Domestic airspace nearest you... A Guy Called Tyketto Piloting 0 June 24th 04 01:20 AM
