Beech Starship - File 05 of 11 - starship04.jpg (1/1)
Old June 26th 08, 08:51 AM posted to alt.binaries.pictures.aviation
Hans Holbein
Default Beech Starship - File 05 of 11 - starship04.jpg (1/1)
Orval Fairbairn schrieb:
Hans Holbein wrote:
Troy schrieb:
What is the Problem with this design?
Why did they come up with it so late?
It was a significant departure from the way Beech has always built
airplanes -- from metal and -- significantly -- did not deliver the
desired performance.
Most Beech products use similar components, but the Starship was one of
a kind and required too much logistical support, so they bought almost
all of them back and scrapped them.
I was not specifically talking aubout Beech, I meant the canard design.
They had something like this at the end of war in japan, but then again,
aircraft were designed the conventional way until today with few
exceptions like the Typhoon, the Kfir, the Raffale and some Rutans.
Is there anything about the canard layout which makes it improper for
airliners or transport aircraft?
Old June 26th 08, 10:29 AM posted to alt.binaries.pictures.aviation
Andrew Chaplin
"Hans Holbein" wrote in message
If you consider the supporting structures such as spars and the actuation
mechanisms to move the surfaces, canards likely require too many compromises
to be easily worked into concepts for transport aircraft and airliners.
If it doesn't save money or produce a higher return on investment, buyers
aren't going to go for it.
Andrew Chaplin
SIT MIHI GLADIUS SICUT SANCTO MARTINO
(If you're going to e-mail me, you'll have to get "yourfinger." out.)
Old June 26th 08, 04:32 PM posted to alt.binaries.pictures.aviation
Orval Fairbairn[_2_]
Canards generally have a smaller CG range than conventional-tail
configurations. Their perceived advantage is at the low end, where they
produce lift, rather than a down force, thus reducing stall speed.
At high speed, however, a conventional tail actually can produce lift,
while a canard would produce a down force.
The canard's use on some fighters and the Russian SST is to add
maneuverability and transonic stability and does not apply to light
aircraft design.
Remove _'s from email address to talk to me.
Beech Starship - File 08 of 11 - starship07.jpg (1/1) Troy[_2_] Aviation Photos 0 June 25th 08 02:34 AM
Beech Starship - File 04 of 11 - starship03.jpg (1/1) Troy[_2_] Aviation Photos 0 June 25th 08 02:33 AM
Beech Starship - File 03 of 11 - starship02.jpg (1/1) Troy[_2_] Aviation Photos 0 June 25th 08 02:33 AM
Beech Starship - File 01 of 11 - starship12.jpg (2/2) Troy[_2_] Aviation Photos 0 June 25th 08 02:33 AM
Beech Starship? SpaceShipOne? DunxC Military Aviation 7 June 22nd 04 08:03 PM
