#221
On 2008-06-26, Le Chaud Lapin wrote:
74HC138? You EE too? No, nothing so grand - merely a hobbyist, although I do some fairly advanced hobbyist stuff (the current hardware project is an ethernet card for one of my old 8 bit computers, the hardware is done and works - all fine pitch SMD on a 4 layer PCB. But the real engineers did all the hard work packaging a MAC and PHY in a chip, I just had to lay out the PCB well enough, along with some glue logic and memory). -- From the sunny Isle of Man. Yes, the Reply-To email address is valid. |
#222
On Jun 26, 11:19*am, Dylan Smith wrote:
On 2008-06-26, Le Chaud Lapin wrote: 74HC138? You EE too? No, nothing so grand - merely a hobbyist, although I do some fairly advanced hobbyist stuff (the current hardware project is an ethernet card for one of my old 8 bit computers, the hardware is done and works - all fine pitch SMD on a 4 layer PCB. But the real engineers did all the hard work packaging a MAC and PHY in a chip, I just had to lay out the PCB well enough, along with some glue logic and memory). Hah...what a coincindence. I have been reading the 802.11-2007 spec for past few nights. I am about to buy this: http://us.zyxel.com/web/product_fami...No=PDCA2007080 Turns a PC into instant access point, which I will need to recreate a DHCP-like server for new type of addressing scheme that is different from IPv4 and IPv6 using a standard PC. Otherwise, would have to hack WRT54G from Linksys and port my software to Linux or run two Wi-Fi adapters in ad-hoc mode, which would have worked, but since would have had to buy an adapter in addition to the one I already have... Your computer sounds very compact. What are the specs? Which chip? Zydas? Prism? OS? I am always interesed to see how spartan requirements get for such devices. I am particularly interested in knowing the delays for association and reasociation. I read yesterday: http://www.smallbusinesscomputing.co...le.php/3600486 ...that re-association from one acess point to another by a moving node can be as low as 68 milliseconds, which is not bad, but obviously, the lower the better. [This is for MAC/PHY only, not higher layers like DHCP] I need ultra-low-handover-delay to help solve the mobility problem in computer networking. ![]() these dongles, and set them up in a line spaced 100 meters apart, then walk with laptop in hand and check that a streaming-video session from hard disk of one of the computers is not broken as laptop moves 500 meters as it associates and reassociates with the 5 pseudo-access- points. -Le Chaud Lapin- |
#223
Dylan Smith wrote:
On 2008-06-26, Le Chaud Lapin wrote: He also showed me a miniature camera with 700+x400+ (forget exact resolution). Cost was about $100. I asked him if such a device could be mounted on GA aircraft If it's small duct tape will do as a mounting :-) I've used a similar camera (it's about the size of a large thing of lipstick, hence is called a 'lipstick camera') on planes and racing motorcycles. Some examples (although the quality will be somewhat degraded by youtube): http://www.youtube.com/user/74HC138 I also now have a completely self contained camera which cost (in US money) about $70. Records to an SD card. It's not as good quality as the lipstick camera, but it weighs only 35 grams and fits on a radio controlled helicopter. Could you post a link? One of those would probably fit inside the wing tiedown eyebolt on my plane. |
#224
On 2008-06-26, Jim Stewart wrote:
Could you post a link? One of those would probably fit inside the wing tiedown eyebolt on my plane. It's called the FlyCamOne - you can probably get one at your nearest hobby store that deals in RC. Google will find you a supplier on your side of the world if you want to do it online; all my links for it are European (I got it from http://www.heliguy.com) -- From the sunny Isle of Man. Yes, the Reply-To email address is valid. |
#225
Your computer sounds very compact. What are the specs? Which chip? Zydas? Prism? OS? I am always interesed to see how spartan requirements get for such devices. It's wired ethernet (100baseTX and 10baseT autonegotiation) rather than wireless. The chip is the Wiznet W5100 which is aimed at 8 bit/embedded applications. It includes a TCP/IP offload engine too - it's a pretty flexible chip - it gives you the option of using as much of its inbuilt stuff as you want - you can write your own stack and talk straight to the MAC, or you can just use its IP layer, or use the whole thing. The old 8 bit machine it's for is one of these, which were enormously popular over he http://en.wikipedia.org/wiki/Zx_spectrum Quite a lot of the work is software. It's different to write a DHCP client in Z80 assembler :-) -- From the sunny Isle of Man. Yes, the Reply-To email address is valid. |
FA: 1-Day-Left: 3 Advanced AVIATION Books: Aviation Electronics, Air Transportation, Aircraft Control and Simulation | Mel[_2_] | Aviation Marketplace | 0 | September 8th 07 01:37 PM |
FA: 3 Advanced AVIATION Books: Aviation Electronics, Air Transportation, Aircraft Control and Simulation | Derek | Aviation Marketplace | 0 | September 3rd 07 02:17 AM |
FA: 1-Day-Left: 3 AVIATION Books: Aviation Electronics, Air Transportation, Aircraft Control and Simulation | Jeff[_5_] | Aviation Marketplace | 0 | September 1st 07 12:45 PM |
FA: 3 AVIATION Books: Aviation Electronics, Air Transportation, Aircraft Control and Simulation | Jon[_4_] | Aviation Marketplace | 0 | August 24th 07 01:13 AM |
FA: 3 ADVANCED AVIATION Books: Aviation Electronics, Air Transportation, Aircraft Control and Simulation | Larry[_3_] | Aviation Marketplace | 0 | August 6th 07 02:23 AM |
