Bertie the Bunyip wrote:
E Z Peaces wrote in : Bertie the Bunyip wrote: More_Flaps wrote in news:0390ffd1-a85e-4ae3-8971- : On Jun 26, 3:00 pm, E Z Peaces wrote: The man said the problem was that he had failed to keep the stick back after touchdown. Does his recollection make sense? Nope Does actually. Little tailfraggers, and big ones, come to think of it, bounce along of you dont get the stick back after three pointing. the mains will thrust it back up into the air a bit and then the nose comes back down again repeating the cycle. Bertie Doesn't a three-point landing occur at stall speed? Not always. Isn't the plane going too slowly to lift off again? Besides, if the tail is that low, touching down won't increase the angle of attack, will it? If the tail is that low, you have th estick all the way back. The man said it was after touchdown that he'd quit holding the stick back. You say the mains will thrust it back up into the air and the cycle will repeat. In a three-point landing, it seems it would take springs to make a plane rise. Aren't shock absorbers supposed to prevent that? Shock absorbers are for cars and they'r emade to dampen cycles such as that. Bertie I've read about oleo aircraft struts at least as early as the 1920s. Sorry about my multiple posts this morning. Each time I sent it, my newsreader said the news server had not responded, so I'd try again. |
E Z Peaces wrote in
: Bertie the Bunyip wrote: E Z Peaces wrote in : Bertie the Bunyip wrote: More_Flaps wrote in news:0390ffd1-a85e-4ae3-8971- : On Jun 26, 3:00 pm, E Z Peaces wrote: The man said the problem was that he had failed to keep the stick back after touchdown. Does his recollection make sense? Nope Does actually. Little tailfraggers, and big ones, come to think of it, bounce along of you dont get the stick back after three pointing. the mains will thrust it back up into the air a bit and then the nose comes back down again repeating the cycle. Bertie Doesn't a three-point landing occur at stall speed? Not always. Isn't the plane going too slowly to lift off again? Besides, if the tail is that low, touching down won't increase the angle of attack, will it? If the tail is that low, you have th estick all the way back. The man said it was after touchdown that he'd quit holding the stick back. Yes, I know. I read your post. You say the mains will thrust it back up into the air and the cycle will repeat. In a three-point landing, it seems it would take springs to make a plane rise. Aren't shock absorbers supposed to prevent that? Shock absorbers are for cars and they'r emade to dampen cycles such as that. Bertie I've read about oleo aircraft struts at least as early as the 1920s. Theyre not dampers, they're oleos and provide no damping. Shock absorbers are something different and have a different function, though tey're misnamed in any case, since its the springs that absorb and the shicks, as they;'re called, prevent the energy stored in the spring from rebounding the wheel off the road. Airplanes don't have shock absorbers. |
E Z Peaces wrote in : I've read about oleo aircraft struts at least as early as the 1920s. Theyre not dampers, they're oleos and provide no damping. Shock absorbers are something different and have a different function, though tey're misnamed in any case, since its the springs that absorb and the shicks, as they;'re called, prevent the energy stored in the spring from rebounding the wheel off the road. Airplanes don't have shock absorbers. Here's an example: http://www.hangar9aeroworks.com/Aero...oncastrut.html |
E Z Peaces wrote in
: Bertie the Bunyip wrote: E Z Peaces wrote in : I've read about oleo aircraft struts at least as early as the 1920s. Theyre not dampers, they're oleos and provide no damping. Shock absorbers are something different and have a different function, though tey're misnamed in any case, since its the springs that absorb and the shicks, as they;'re called, prevent the energy stored in the spring from rebounding the wheel off the road. Airplanes don't have shock absorbers. Here's an example: http://www.hangar9aeroworks.com/Aero...oncastrut.html Yeah, I know,. I was flying one a couple of days ago and I've had them apart, too. It does little or nothing to stop a bounce in spite of it's name. I can also stater that categorically since I was training two ab-initio tailwheel pilots in it. Bertie |
E Z Peaces wrote in : Bertie the Bunyip wrote: E Z Peaces wrote in : I've read about oleo aircraft struts at least as early as the 1920s. Theyre not dampers, they're oleos and provide no damping. Shock absorbers are something different and have a different function, though tey're misnamed in any case, since its the springs that absorb and the shicks, as they;'re called, prevent the energy stored in the spring from rebounding the wheel off the road. Airplanes don't have shock absorbers. Here's an example: http://www.hangar9aeroworks.com/Aero...oncastrut.html Yeah, I know,. I was flying one a couple of days ago and I've had them apart, too. It does little or nothing to stop a bounce in spite of it's name. I can also stater that categorically since I was training two ab-initio tailwheel pilots in it. Have you stood by the wing tip and rocked the wing like a seesaw? If you can get it to rock higher and higher and it keeps rocking after you let go, then I guess the landing gear doesn't have effective shock absorbers. I remember touchdown bounces from my days with balsa, tissue and dope. None of my models would have bounced even slightly from a stationary drop because all had rigid landing gear. None had a movable elevator. I could climb and dive by changing thrust, which would move the center of lift by slightly changing the speed. If I wanted a plane to fly faster, I would move the center of gravity by weighting the nose so the model would balance at a higher speed. Without elevator control I couldn't make three-point landings. My Curtis Hawk had the biggest bounce, but the airspeed was low enough that it would rise only about five inches before mushing elegantly to the ground. My Corsair would bounce about two inches. My Spitfire landed much faster than the others because I weighted the nose with two flashlight batteries. With that much airspeed, it might have risen disastrously high if it had bounced on touchdown. It didn't bounce at all. The three models were different in the position of the main gear. The wheels of the Hawk were well forward of the center of gravity; apparently the Army plane was designed that way to counter the tendency of a short, high plane to nose over when landing on a rough field at low speed. When the wheels of my model touched down, the center of mass would continue to fall, lowering the tail and increasing the angle of attack. Naturally, it bounced. The problem wasn't as bad with the Corsair because the wheels weren't so far forward. The wheels of the Spitfire were farther back, and the weights brought the center of gravity forward as well as increasing inertia about the horizontal axis. This way, the tail didn't sink fast enough for the plane to lift off after touchdown. With my balsa models, bouncing came from the rapid sinking of the tail after touchdown. If I'd had elevator control, I might have managed three-point landings with the Hawk. I don't see how the model could have bounced in that case. (A neighbor used to fly his father's Stearman under his brother's instruction. He says he sometimes touched down tail first.) |
E Z Peaces wrote in
: Bertie the Bunyip wrote: E Z Peaces wrote in : Bertie the Bunyip wrote: E Z Peaces wrote in : I've read about oleo aircraft struts at least as early as the 1920s. Theyre not dampers, they're oleos and provide no damping. Shock absorbers are something different and have a different function, though tey're misnamed in any case, since its the springs that absorb and the shicks, as they;'re called, prevent the energy stored in the spring from rebounding the wheel off the road. Airplanes don't have shock absorbers. Here's an example: http://www.hangar9aeroworks.com/Aero...oncastrut.html Yeah, I know,. I was flying one a couple of days ago and I've had them apart, too. It does little or nothing to stop a bounce in spite of it's name. I can also stater that categorically since I was training two ab-initio tailwheel pilots in it. Have you stood by the wing tip and rocked the wing like a seesaw? If you can get it to rock higher and higher and it keeps rocking after you let go, then I guess the landing gear doesn't have effective shock absorbers. I remember touchdown bounces from my days with balsa, tissue and dope. None of my models would have bounced even slightly from a stationary drop because all had rigid landing gear. None had a movable elevator. I could climb and dive by changing thrust, which would move the center of lift by slightly changing the speed. If I wanted a plane to fly faster, I would move the center of gravity by weighting the nose so the model would balance at a higher speed. Without elevator control I couldn't make three-point landings. My Curtis Hawk had the biggest bounce, but the airspeed was low enough that it would rise only about five inches before mushing elegantly to the ground. My Corsair would bounce about two inches. My Spitfire landed much faster than the others because I weighted the nose with two flashlight batteries. With that much airspeed, it might have risen disastrously high if it had bounced on touchdown. It didn't bounce at all. The three models were different in the position of the main gear. The wheels of the Hawk were well forward of the center of gravity; apparently the Army plane was designed that way to counter the tendency of a short, high plane to nose over when landing on a rough field at low speed. When the wheels of my model touched down, the center of mass would continue to fall, lowering the tail and increasing the angle of attack. Naturally, it bounced. The problem wasn't as bad with the Corsair because the wheels weren't so far forward. The wheels of the Spitfire were farther back, and the weights brought the center of gravity forward as well as increasing inertia about the horizontal axis. This way, the tail didn't sink fast enough for the plane to lift off after touchdown. With my balsa models, bouncing came from the rapid sinking of the tail after touchdown. If I'd had elevator control, I might have managed three-point landings with the Hawk. I don't see how the model could have bounced in that case. (A neighbor used to fly his father's Stearman under his brother's instruction. He says he sometimes touched down tail first.) Wonderful, you should write a book. Bertie |
Runway | J.F. | Aviation Photos | 14 | September 14th 07 04:24 PM |
Runway ID | Lakeview Bill | Piloting | 55 | October 18th 05 12:53 AM |
Runway needs of F4U and F-4 ???? | vincent p. norris | Naval Aviation | 8 | October 6th 05 07:18 PM |
Bouncing ammeter hand on 76 Warrior | Leo | Owning | 5 | December 5th 04 08:24 PM |
Runway in Use | Sniper@SDU | Simulators | 11 | October 8th 03 10:57 AM |
