Winch operations in MN?
Old June 26th 08, 10:08 PM posted to rec.aviation.soaring
Tom Gardner
Default Winch operations in MN?
On Jun 26, 7:56*pm, Frank Whiteley wrote:
Don Ingraham has shared some pictures of the winch clinic herehttp://www.crosscountrysoaring.com/welcome22.html
A video of some of the launches is herehttp://www.soaringchapters.org/minnesota/mn_winch.wmv
Frank Whiteley
Can I suggest that the people taking the video might like to consider
what would happen to the cable when it breaks under tension at just
the wrong height. I've watched the cable snake along the ground
alongside and (say) 40ft behind our winch. Quite entertaining (and
even pretty), but I was glad I was off the ground in another vehicle!
Tom Gardner
Old June 26th 08, 10:19 PM posted to rec.aviation.soaring
John Smith
Just another advantage of Dyneema over steel.
Old June 26th 08, 11:28 PM posted to rec.aviation.soaring
Bill Daniels
"John Smith" wrote in message
Yes, the safety difference between Dyneema (or Spectra) and the old steel
cable is dramatic. By comparison, steel cable is just ugly, dangerous
stuff. If you break Dyneema under tension, it just falls. It never snaps
back or tangles like steel.
However, even though Dyneema is very light and extremely well behaved, it's
still very strong. I wouldn't want to get it wrapped around me while it's
being pulled by a big engine. I've seen the results of it cutting through
half inch steel plate like a laser with no apparent damage to the Dyneema.
Bill D
Old June 27th 08, 02:14 AM posted to rec.aviation.soaring
Frank Whiteley
Frank Whiteley
alongside and (say) 40ft behind our winch. *Quite entertaining (and
Tom Gardner
You bring up a valid point. Solid steel wire is the worst and needs a
wide clear zone for auto tow, reverse pulley, or winching. 7/7 (and
7/19 to a slightly lesser extent) needs a clear zone also, especially
on the drum side and aft. I wouldn't have my truck attached with any
steel, even with drum covers. The dyneema and spectra ropes have no
recoil and negligible mass. Even then, when I put the camcorder on
the drum side, it was left unattended on a tripod, nor would I allow
anyone on that side during launching. When winching, we need folks
switched on, at both ends of the rope, to what's happening on, above,
and in the traffic vicinity of the airfield. As this was a new
activity there, it was NOTAMed. At one point, we had a large tractor,
towing a tank and spray gear cross the airport. Bill announced
holding for heavy equipment on the runway. The FBO replied what heavy
equipment? Then took a look. The treads of the tractor actually
flicked the winch rope, but didn't snatch it fortunately. We
explained things as he passed by.
Frank Whiteley
9/11 ATC operations Everett M. Greene Instrument Flight Rules 1 September 13th 06 12:16 PM
9/11 ATC operations Everett M. Greene Instrument Flight Rules 4 September 12th 06 08:30 PM
Winch operations Edward Winchester Soaring 7 April 13th 06 12:24 PM
LIppmann reports a 950 meter winch launch with their Dynatec winch line - anything higher? Bill Daniels Soaring 20 December 27th 04 01:33 AM
Winch Operations Frank Smith Soaring 19 February 14th 04 12:28 PM
