Unpaved Landing areas
Old June 27th 08, 02:54 AM posted to rec.aviation.piloting
Orval Fairbairn[_2_]
Default Unpaved Landing areas
Larry Dighera wrote:
On Thu, 26 Jun 2008 11:06:07 -0700 (PDT), "Ol Shy & Bashful"
wrote in
How often do you get to land or take off from something other than a
paved runway?
Not very often.
Does this count?
http://members.tripod.com/airfields_...oy_CA_02_w.jpg
http://members.tripod.com/airfields_...ernardino_SE.h
tm#amboy
I used to fly my Johnson Rocket out of Frazier Lake, which is the only
irrigated sod airport in California. During the winter it got too soggy
and we used the parallel (paved) 30 ft wide taxiway. That got really
sporting with a 90 deg crosswind!
The best sod I have ever flown into is Leeward Air Ranch, in FL --
smooth as a putting green! I landed there and didn't know I had touched
down until the plane started decelerating on its own.
The hairiest was at Eustis, FL, when I landed there a couple of days
after some heavy rains. The grass was about 6 in. high. Touchdown
deceleration was FAST! It took a fair amount of power to taxi.
I wasn't sure we could take off, but decided to use full flaps to
produce max lift. I figured that, if I could rotate, it would fly; if
not, we had 3000 ft to play with. I must have left ruts on the
threshold, but got rotated and flew out.
Remove _'s from email address to talk to me.
Old June 27th 08, 04:57 AM posted to rec.aviation.piloting
Larry Dighera
On Thu, 26 Jun 2008 21:54:13 -0400, Orval Fairbairn
wrote in
[Interesting stories snipped]
Did you ever land at that old crushed rock strip that used to be at
the north end of the Salton Sea? The one with the big hole at the
approach end, and a white line just beyond the hole as a threshold
marker.
Or how about another gravel field, Sun Hill Ranch Airport near
Adelanto: http://www.airnav.com/airport/CA70 ?
Old June 27th 08, 06:39 AM posted to rec.aviation.piloting
Marty Shapiro
Orval Fairbairn wrote in
news
wrote in
paved runway?
Not very often.
Does this count?
http://members.tripod.com/airfields_..._CA_SanBernard
ino_SE.h tm#amboy
soggy and we used the parallel (paved) 30 ft wide taxiway. That got
really sporting with a 90 deg crosswind!
touched down until the plane started decelerating on its own.
Orval -
Had Columbia (O22) completed their re-sodding of 11/29 before you left
the Bay area? After they finished, it was just like your description of
Leeward Air Ranch.
Marty Shapiro
Silicon Rallye Inc.
(remove SPAMNOT to email me)
Old June 27th 08, 01:10 PM posted to rec.aviation.piloting
Ol Shy & Bashful
On Jun 26, 8:54*pm, Orval Fairbairn
wrote in
paved runway?
Not very often.
Does this count?
http://members.tripod.com/airfields_...s_CA_SanBernar...
tm#amboy
not, we had 3000 ft to play with. *I must have left ruts on the
Remove _'s *from email address to talk to me.
Ummm ... not sure what you were flying but seems to me, FULL FLAPS is
in the drag flap area and not maximum lift. I can think of many
aircraft that state max flap for takeoff at 10 deg or whatever "one
notch" equates to. Now if you "rotate" at less than performance speed,
you're going to be in ground effect and perhaps get airborne but when
you get out of ground effect with that same low speed, you're going to
settle back to the runway with a high vertical velocity and no amount
of power will keep you from getting an enema from the main gear! Look
at airshow crashes when jet aircraft hit the runway trying to stop
that sink rate and they even have afterburner to help them out.
Takes some hard decisions to tell your PAX "we have to wait for better
conditions to get out of this mess I got us into."
Don't let that macho **** get you into a corner you can't get out of.
Trust me, it ain't worth it just to try to prove you are the ace of
the base. Don't let your rep become the "Ass of the base" .....?
Cheers
Ol S&B
Old June 27th 08, 01:56 PM posted to rec.aviation.piloting
Stealth Pilot[_2_]
paved runway? The current books don't give it much thought and I
suspect because the writers are so new at this aviation thing, they
have little or no experience on anything but paved runways.
Part of the reason for this post was the resistance to more than a few
to not land on a great 2000' grass strip that has an Interstate on one
end, and trees on the other. I have no idea why they are afraid to
land on this strip. There are at least three grass strips of 2000'
length in this area and some that are longer (one is about 4000').
What has your experience been? I have no idea how much time I have
operating off strips of 1200' or less, grass, gravel, sand, etc and no
problems. Must be at least thousands of them, both in terms of take
off and landings as well as hours.
Ol S&B
there is nothing quite so sweet as operating a Tailwind from a grass
green runway 100 metres shorter than the manual says you can.
(which I do all the time)
best story re unmade strips is mike flying a tosser as pax in a Cessna
172. they were doing a cross country up north.
mike looks out the window and says to himself 'bugger it that'll do'
which gets picked up over the intercom.
mike pulls off the throttle, applies heat and lowers landing stages of
flaps and wheels it around for an approach to ....nothing.
tosser wannabe works himself up into an appoplexic lather at the
prospect of there being no runway ahead, just ...nothing.
mike pops it in with out any trouble and shuts down to a tosser with
eyes like saucers.
'you cant do that!'
'oh dont worry you dont have to ...back in a mo' '
mike walks to the end of the wing and has a ****.
back in the aircraft the tosser gets himself all worked up at the
prospect of a takeoff ...on nothing.
later mike tells us of all the commotion. it was a perfectly level
grassy area as a flat as a billiard table ...and I needed a ****.
I would suggest that students are taken for a landing in an aluminium
aircraft on a gravel runway. the din can take you by surprise.
but other than that these people are so limited by their fears and
lack of real experience that they are a worry. totally needless
apprehension.
Stealth Pilot
Old June 27th 08, 07:12 PM posted to rec.aviation.piloting
wrote in
marker.
No -- Idid not do much flying in that area. I did land at Giant Rock one
time and talked to one of the saucer people, though.
Old June 27th 08, 07:13 PM posted to rec.aviation.piloting
news
wrote in
paved runway?
Not very often.
Does this count?
ino_SE.h tm#amboy
Orval -
Leeward Air Ranch.
I never landed on 11.29 at Columbia -- I always used the paved runway.
There used to be an "air snake" there that would grab the unwary.
  #28
Old June 27th 08, 07:20 PM posted to rec.aviation.piloting
In article
wrote in
paved runway?
Not very often.
Does this count?
tm#amboy
Cheers
Ol S&B
I used full flaps, as I indicated, to create max lift, as the field was
very soggy, and I have a 5.00X4 nosewheel and 6.00X6 mains, on a 2550#
plane with 18#/ft2 wing loading. The Rocket will fly (and climb) with 45
deg barndoor split flaps.
Once rotated and airborne, I was able to start flaps and gear up, but
the problem at hand was to break free of the soggy runway.
BTW -- my pax was test pilot for the Lunar Module training vehicle. He
voiced no objections, as we had plenty of start/stop distance.
  #29
Old June 27th 08, 08:32 PM posted to rec.aviation.piloting
Larry Dighera
On Fri, 27 Jun 2008 14:12:24 -0400, Orval Fairbairn
wrote in
I did land at Giant Rock one time and talked to one of the saucer people, though.
I over flew Giant Rock once in the late '90s, but thought better of
landing in the deep sand. I'd want to walk the "strip" before
intentionally landing there.
There's lots of "saucer people" out in the desert:
http://www.lucernevalley.net/giantrock/
http://www.labyrinthina.com/rock.htm
http://www.integratron.com/2History/History.html
http://www.elfis.net/rnr/rnrx/giantrock.htm
http://www.crawford2000.co.uk/hopisplit.htm
Good recent and historic Giant Rock photos he
http://havewebsiteswilltravel.com/co...Airport12.html
http://www.mbhs.net/more_photos.htm
I once did a low pass at the unpaved WWII USAAF tactical airstrip at
Essex, CA (scroll down):
http://members.tripod.com/airfields_....htm#campessex
The weeds were too high for the PA28-235 however.
  #30
Old June 27th 08, 08:55 PM posted to rec.aviation.piloting
Bertie the Bunyip[_24_]
"Ol Shy & Bashful" wrote in
Oh, you'll get more lift, but as you say it's the cost in drag that usually
makes this not such a good idea. HoweverI got stuck in snow in a 150 when I
was a student and my instructor came to the airport I was stuck at and took
off in well over 6 inches of fluff using 30 degrees to get off. Gets you
out of the muck faster but at the expense of climbe performance.
I can think of many
notch" equates to.
Well, it depends on what you're loking for and how much runway and gradient
you have to spare. Yo'll get an aiplane off the ground more quickly,
generally speaking, at a higher flap setting, but it will cost you in
climb.
Also, it's not bad technique to get airborne a little on the slow side in
ground effect on a soft field as long as you dont try to climb out of it at
the same speed you came off the ground. Best technique for performance is
to get the attitude right to allow the airplane to come off as early as it
can solidly do so and then to rotate to your climb attitude as smoothly as
you can at such a rotation speed to ensure you reach climb attitude and
your climb speed simultaneously. This ensures you have close to the optimum
alpha at all times as you accelerate in and then climb out of ground
effect.
Bertie
How do you find the limits of areas on a chart? Mxsmanic Piloting 203 November 29th 06 09:22 PM
Flying Thru Congested Areas O. Sami Saydjari Instrument Flight Rules 64 January 9th 04 04:58 PM
GPS Degradation in ZDC/ZNY areas Jay Somerset Instrument Flight Rules 3 November 30th 03 04:30 PM
GPS Degradation in ZDC/ZNY areas Jay Somerset Piloting 3 November 30th 03 04:30 PM
Low flying over built up areas Martin Evans General Aviation 9 October 8th 03 08:25 AM
