Rocket Racing League First Exhibition Race August 1st and August 2nd, 2008
Old June 29th 08, 05:27 PM posted to rec.aviation.homebuilt
Default Rocket Racing League First Exhibition Race August 1st and August 2nd, 2008
On Sat, 28 Jun 2008 14:19:07 -0700, "Rich S."
"Larry Dighera" wrote in message
Pylon racing and now Rocket Racing!
I'm sure there will now appear those who choose to sit on the sidelines and
mock those who are trying something new. It is easier and less risky to be a
critic instead of a playwright.
Wouldn't want to disappoint you, Rich! :-)
I'm looking forward to seeing it. The Red Bull events are very entertaining.
Certainly. But there's a lot of differences between Red Bull and the RRL. For
instance, the RRL pilots follow instructions from an autopilot in order to
follow an invisible course. If they vary from the course, only the spectators
following the "video game" on the big-screen TVs will know. For Red Bull, a
"Cut Pylon" is not only a literal event, it's totally obvious to every
spectator! :-)
I don't argue that the RRL isn't *spectacle*. But so was "jet truck" racing at
Oshkosh.
The race at Oshkosh is listed as an 'Exhibition'...with no definition of what
that means. I'm guessing it means two or three airplanes (probably including
XCOR's Rocket EZ) zipping around until their fuel runs out, no pit stops, and
limited video screens.
No doubt folks will enjoy the spectacle. But...consider whether you'll ever be
willing to pay good money *just* to see a rocket race. I enjoyed seeing the
Rocket EZ fly. But how many people would pay $100 just to watch it fly again?
If a full-up RRL race would displace, say, 100 homebuilts from show-center
Oshkosh parking to allow room for their video screens, pit areas, and luxury
boxes for VIP guests...would it be worth it?
Here's an interesting bit of information. As of 1 January 2008, there were two
Velocities registered to the RRL (N246RR and N216MR). Both were licensed as
Experimental Amateur-Built, and still are in that category today.
The RRL could have just as easily licensed them as Experimental Racing.
*Somebody* had to sign an affidavit stating that these aircraft were constructed
for education or recreation.
Keep that in mind the next time the kit airplane companies cry about the FAA
tightening up the Experimental Amateur-Built rules....
Old June 29th 08, 06:34 PM posted to rec.aviation.homebuilt
On Sun, 29 Jun 2008 09:27:51 -0700, Ron Wanttaja
Looks like one of them (N216MR) might be a Velocity purchased from a previous
builder. The other was built by Velocity and lists a Lycoming, so it may be a
conversion as well.
But, obviously, the next question arises: Have these Experimental Amateur-Built
aircraft completed their 40 hours since major alterations (conversion to rocket
power)? With a fifteen-minute flight time per fuel load, that's 160 flights.
If you consider that even that many flights would constitute less than 15 hours
with the motor running.....
So...is RRL going to do a hurried transfer of these airplanes to some other
Experimental category, or is some of their time for flying off their
restrictions going to in front of 500,000 people at Oshkosh?
Old June 30th 08, 01:50 PM posted to rec.aviation.homebuilt
DABEAR
Default Rocket Racing League First Exhibition Race August 1st and August2nd, 2008
Saw one in ground test at Mojave many months ago so its aerial work
should be well underway. The progress of the second aircraft will be
an issue.
Their two top pilots including Rick Searfoss are tagged with the
demonstration flights based on a previous press release.
Reno is a dangerous location to fly. Folks may have to get up early
to witness any flying there due to the Sierra Wave factor. Mornings
are usually calm.
They'll be trying to put gliders down on fixed runways when those
aircraft need something more in the way of a dry lake. Unless they
found a way to put power on for landing, they're at the whim of
turbulence and winds in the area, and a few years back (2002), Brent
Hisey got pushed off the runway centerline during a landing attempt
and nearly got himself killed in the North American P-51D Mustang
"Miss America." They aircraft was technically "destroyed," yet Hisey
managed to rebuild her and by the following year, won the Silver at
Stead. Two miracles in one year from that guy.
If the idea is to turn those aircraft around within one hour for the
racing they have planned, and if their designs accomodate such a slow
"Pit Stop" feature, then they should be able to accumulate enough
hours if their are no mishaps during the flight test and performance
period.
However, those craft will need the most experienced pilots in the
World because in my opinion, what they're planning to do in the
landing phase without an open area like a Dry Lake in a Desert Region
(known for unpredictable dust devils [tore an International Formula
One air racer apart in flight killing the pilot], tremendous heat,
severe crosswinds, headwinds and tailwinds, dangerous updrafts and
downdrafts and Wave-produced turbulence) could prove to be the most
dangerous issue of their flights; moreso than the climb to altitude
under full power.
Old June 30th 08, 03:17 PM posted to rec.aviation.homebuilt
On Mon, 30 Jun 2008 05:50:48 -0700 (PDT), DABEAR
period.
Got an email that makes me believe they've solved many of the "pit stop" issues,
at least. They're not as fast as NASCAR, but they're anticipated to be
considerably shorter than the 15-minute estimate I had. Still, their easiest
solution to the "flying off the test period time" issue would be a transition to
another category where the FSDO doesn't require the traditional Ex-AB flyoff
period.
I guess unlimited air racing survives with just one or two events per year, so
the RRL can probably get by with the same. Hard for the owners to break even
that way, though....
Old June 30th 08, 06:06 PM posted to rec.aviation.homebuilt
Dan[_12_]
period.
period.
I wonder if they could race before the magic 40 hours if they based
the aircraft at Reno and flew the hours there.
Dan, U.S. Air Force, retired
Old July 2nd 08, 05:38 AM posted to rec.aviation.homebuilt
should be well underway. �The progress of the second aircraft will be
an issue.
Reno is a dangerous location to fly. �Folks may have to get up early
to witness any flying there due to the Sierra Wave factor. �Mornings
are usually calm.
aircraft need something more in the way of a dry lake. �Unless they
"Miss America." �They aircraft was technically "destroyed," yet Hisey
Stead. �Two miracles in one year from that guy.
period.
under full power.
i would love to know just what Stead Field you have been going to over
the last years. You are certainly not describing the one I know.
Old July 1st 08, 02:09 AM posted to rec.aviation.homebuilt
ChuckSlusarczyk
In article , Ron Wanttaja says...
conversion as well.
capt zoom will fly the 40hrs off in 4 one hour flights and call anyone a liar
and threaten to sue anyone who disputes his claims. LOL!!! Because as zoom once
told me if I wrote it I did it...
Chuck S RAH 14/1 ret.
P.S. I notice zoomy wasn't mentioned as one of the pilots.
Old July 2nd 08, 01:22 AM posted to rec.aviation.homebuilt
Charlie[_2_]
conversion as well.
Hmmm...
Must be different rules in other parts of the country, or maybe time
flows at a different rate.
Down here in the backwater states, you only need 5 hours test time after
a major alteration.
Charlie
Slobovia Outernational
Rocket Racing League First Exhibition Race August 1st and August 2nd, 2008 Larry Dighera Piloting 15 July 3rd 08 07:56 AM
$300,000 Flight Competition August 2-10, 2008 Larry Dighera Piloting 0 January 3rd 08 11:31 AM
Rocket Racing League/Zzzz Kyle Boatright Home Built 4 May 7th 07 04:17 AM
Rocket racing at Reno raptor Home Built 2 November 3rd 05 02:48 AM
Rocket Racing League John Ousterhout Home Built 34 October 7th 05 06:30 AM
