Take the alternator off and have your local alternator shop check the
"diodes" in it. They are not certified to repair it but they can sure check it out for you. Bad diodes will cause a hum that changes in pitch with rpm. They can also cause the alternator output to be unstable as seen in a quivering amp meter. |
I had a problem like this and it turned out to be a bad ground on the
ptt. On Jun 29, 2:34*pm, wrote: Take the alternator off and have your local alternator shop check the "diodes" in it. *They are not certified to repair it but they can sure check it out for you. *Bad diodes will cause a hum that changes in pitch with rpm. *They can also cause the alternator output to be unstable as seen in a quivering amp meter. |
Micro Air transmission-garbled | [email protected] | Soaring | 7 | June 17th 07 03:50 PM |
C206 rental - KS, OK, noth TX - where? | grumman_driver | Piloting | 3 | April 10th 06 06:12 PM |
Subaru flywheel pto without transmission | [email protected] | Home Built | 2 | November 26th 05 08:00 AM |
JPI 800 & GMA 340 into C206 in EASA countries? | Jouni Laukkanen | Owning | 3 | August 4th 05 07:30 AM |
Transmission design? | Otto Gyro | Rotorcraft | 1 | November 7th 03 04:41 PM |
