Alternator noise on Xmit only
Old July 1st 08, 06:31 PM posted to rec.aviation.owning
Mike Noel
Default Alternator noise on Xmit only
So running a grounding wire from the jack to the radio tray is not enough?
I installed a jack to run the audio from my 496 to the audio panel in the
radio stack and at first just used the instrument panel as ground. I did
get a significant amount of noise. Then I added a ground wire from the plug
to the radio tray and got rid of the extra sound effects.
Best Regards,
Mike
http://photoshow.comcast.net/mikenoel
"David Lesher" wrote in message
MikeMl writes:
Short from microphone connector ground to chassis.
Bingo,
Proper installation of aircraft mic and headphone jacks requires the
use of insulating bushing where the threaded sleeve on the jack would
otherwise come in electrical contact with the airframe.
And those those who've not seen them, you need shoulder washers.
PANEL| |****PANEL
The outer [here lower] washer is two-step; the inner part centers the
jack in the panel hole. Sometimes the inner [here upper] washer is flat,
sometimes it's the same as the lower. Both are usually made of phenolic
or such; but could be any insulator.
And note that if any mike jack wiggles loose/gets off-center, you can get
a short. It's an easy thing to inspect.
And if the jack is mounted on a plastic panel; you can skip the whole
issue. I don't know how many are.
A host is a host from coast to
& no one will talk to a host that's close........[v].(301) 56-LINUX
Unless the host (that isn't close).........................pob 1433
is busy, hung or dead....................................20915-1433
Old July 2nd 08, 01:34 AM posted to rec.aviation.owning
David Lesher
"Mike Noel" writes:
You want to isolate the jack from the panel ground.
Old July 2nd 08, 08:22 PM posted to rec.aviation.owning
On Jul 1, 6:34*pm, David Lesher wrote:
"Mike Noel" writes:
He's right you know. Otherwise, small alternator induced voltage
drops in the airframe will show up in series
with the mic. You puny little wire won't change that picture.
Isolation washers are the answer!!
Should be on the phones too.
Bill Hale
FAA paper Noise Attenuation Properties of Noise-Canceling Headsets Jim Macklin Piloting 26 January 13th 07 12:06 AM
FAA paper Noise Attenuation Properties of Noise-Canceling Headsets Jim Macklin Instrument Flight Rules 15 January 13th 07 12:06 AM
Alternator Noise -- Part 2 Jonathan Goodish Owning 0 December 11th 04 04:10 AM
Alternator Noise Jonathan Goodish Owning 17 December 10th 04 04:29 AM
Alternator field cycling & alternator damage Nathan Young Owning 7 November 14th 04 09:02 PM
