R/C Flying - B52 b.jpg (1/1)
Old July 2nd 08, 12:54 PM posted to alt.binaries.pictures.aviation
Mitchell Holman[_2_] Mitchell Holman[_2_] is offline
Banned
First recorded activity by AviationBanter: Jan 2007
Default R/C Flying - B52 b.jpg (1/1)
Click image for larger version
Old July 2nd 08, 01:13 PM posted to alt.binaries.pictures.aviation
Robert Moore
Mitchell Holman wrote
OK Mitchell....where's the video of this event?
Bob Moore
Old July 2nd 08, 01:16 PM posted to alt.binaries.pictures.aviation
Banned
Robert Moore wrote in
. 15.205:
Bob Moore
Good question. If one exists I don't want to see it.
Too sad to see so much work end up as splintered balsa...
Old July 2nd 08, 01:35 PM posted to alt.binaries.pictures.aviation
Mike Proctor
Bob Moore
http://www.youtube.com/watch?v=dxp4qYC9ZtU
Old July 2nd 08, 02:50 PM posted to alt.binaries.pictures.aviation
Rusty Knuckle
Sometimes I just can't help but smile.
RK
Old July 7th 08, 12:34 AM posted to alt.binaries.pictures.aviation
Scubabix
The video of this crash was eerily like the crash of the B-52 at Fairchild
AFB a few years back.
Rob
"Mitchell Holman" wrote in message
Old July 7th 08, 03:30 AM posted to alt.binaries.pictures.aviation
Morgans[_2_]
"Scubabix" wrote in message
That is because the cause for each of the crashes was somewhat the same.
The Buff did not use regular ailerons, as you would normally think of them.
The flexibility of the wing would twist when a normal aileron input was
applied, and would actually give the opposite roll reaction that was
expected. The aileron was acting like a boost tab, in sorts.
The solution was to control roll by having a spoiler instead of an aileron,
so that if you wanted to roll right, the right spoiler went up, that side
lost some lift, and the aircraft rolls. It was also good to prevent adverse
yaw.
The only problem with that type of control roll, was that if a critical bank
angle was exceeded, the roll was unrecoverable. Your were going to crash,
period.
The full sized crash was being piloted by a senior pilot who was known as a
cowboy, and exceeded various flight parameters, frequently. Some crew would
not fly with him. He pulled his steep bank trick one too many times, and
did not get away with it.
The RC model might have gotten too steep, in a normal flight pattern, but I
think what happened was that the overcast sky messed up the pilot's
orientation clues, and he banked steeper, rather that flattening it out.
I've done it, and about anyone who flies RC has also done it, and gotten it
back into control. With the model Buff, getting that steep put you into an
unrecoverable area of the flight envelope. Boom, was the final result.
Jim in NC
Old July 7th 08, 04:00 AM posted to alt.binaries.pictures.aviation
ABLE_1[_2_]
I think what happened was that the overcast sky messed up the pilot's
it back into control. With the model Buff, getting that steep put you
into an unrecoverable area of the flight envelope. Boom, was the final
result.
Jim in NC
Sorry to jump in here.
But as I recall the discussion at the time of the RC crash it was due to the
"dreaded downwind turn" that plagues some RC pilots at times.
But no matter the real reason the outcome is the same.
Les
Old July 7th 08, 04:13 AM posted to alt.binaries.pictures.aviation
Morgans[_2_]
the "dreaded downwind turn" that plagues some RC pilots at times.
Oh no! The dreaded downwind turn!!!
Of course, this is a subject that has been possible the most discussed of
any subject. I tend to go with the aerodynamicist that says that a downwind
turn problem is impossible to be a problem.
I can believe there will be a problem if the pilot does not correctly keep
his speed up when he turns downwind, but if a plane was flying when it
started the turn, and the same airspeed is maintained, there will not be a
crash.
Jim in NC
Old July 7th 08, 09:20 AM posted to alt.binaries.pictures.aviation
Bob Harrington
"Morgans" wrote in
to the "dreaded downwind turn" that plagues some RC pilots at times.
of any subject. I tend to go with the aerodynamicist that says that a
downwind turn problem is impossible to be a problem.
keep his speed up when he turns downwind, but if a plane was flying
when it started the turn, and the same airspeed is maintained, there
will not be a crash.
Indeed, the plane's frame of reference is the atmosphere, not the ground.
Unless it runs into some hellacious shear, the airspeed will not change in
the turn any more than it would in a pefectly static air mass.
Kind of like the plane taking off from a conveyor belt myth that was so
solidly busted on 'Mythbusters'...
Bob ^,,^
Last ever flying Jaguar not flying anymore.... - _07Oct19-36.jpg (0/1) Martin J Hooper Aviation Photos 7 January 15th 08 06:08 PM
Last ever flying Jaguar not flying anymore.... - _07Oct19-36.jpg (1/1) Martin J Hooper Aviation Photos 0 January 7th 08 01:59 PM
Flying Magazine's Instrument Flying 1973 Steven P. McNicoll Aviation Marketplace 9 January 4th 04 02:24 AM
Flying Magazine's Instrument Flying 1973 Steven P. McNicoll General Aviation 9 January 4th 04 02:24 AM
FA: WEATHER FLYING: A PRACTICAL BOOK ON FLYING The Ink Company Aviation Marketplace 0 November 5th 03 12:07 AM
