DG-600 questions
Old July 6th 08, 07:10 PM posted to rec.aviation.soaring
Dan[_6_]
Default DG-600 questions
Recently a set of DG-600 wings have shown up for sale. They are
damaged but don't apear to be beyond repair. I'm considering using a
these wings for an experiment I've been toying with for some time. .
I've never seen a DG-600 in person so I could use some help with a few
basic questions.
What is the weight of DG-600 wings?
What is the max non-lifting weight of a DG-600?
I found the empty weight and max gross weight but not the non-lifting
weight.
Does a DG-600 have automatic control hookups?
Does a DG-600 have a flap/aileron mixer or are the control of the flap
deflection and ailerons separate?
Any other comments would also be useful.
I would not be using the fuselage or tail surfaces, only the wings,
flaps and ailerons.
Thank you in advance.
Dan Rihn
ASW-20 WO
Old July 6th 08, 07:37 PM posted to rec.aviation.soaring
Marc Ramsey[_2_]
basic questions.
I believe mine were around 150 lbs. each.
weight.
246 kg / 542 lbs.
Yes, via two torsion tubes per side.
The DG-600 has flaperons, not separate aileron/flap.
Marc
Old July 6th 08, 07:57 PM posted to rec.aviation.soaring
Martyn Johnson
The non-lifting weight is included he
http://www.gliding.co.uk/bgainfo/tec...60015and18.pdf
I have an electroic copy of the flight manual if you want it - let me
know.
Regards
Martyn
basic questions.
weight.
flaps and ailerons.
Dan Rihn
ASW-20 WO
Martyn Johnson
know.
Regards
Martyn
basic questions.
weight.
flaps and ailerons.
Dan Rihn
ASW-20 WO
Martyn Johnson
know.
Regards
Martyn
basic questions.
weight.
flaps and ailerons.
Dan Rihn
ASW-20 WO
Martyn Johnson
The non-lifting weight is in he
I have an electronic copy of the flight manual if you want it.
Regards
Martyn
basic questions.
weight.
flaps and ailerons.
Dan Rihn
ASW-20 WO
Old July 6th 08, 11:46 PM posted to rec.aviation.soaring
Dan[_6_]
On Jul 6, 11:57*am, Martyn Johnson
Regards
Martyn
Recently a set of DG-600 wings have shown up for sale. *They are
damaged but don't apear to be beyond repair. *I'm considering using a
these wings for an experiment I've been toying with for some time. * .
basic questions.
weight.
flaps and ailerons.
Dan Rihn
ASW-20 WO- Hide quoted text -
- Show quoted text -
Thanks to both Marc and Martyn, this is exactly what I needed.
Flaperons with torsion tubes will make my project easier.
Now all I need is a little more ambition.
Thanks again,
Dan
Old July 7th 08, 02:03 AM posted to rec.aviation.soaring
Udo
Regards
Martyn
Some SZD-55-1 Questions WDM Soaring 13 July 16th 13 04:41 AM
PMA Questions Mike Granby Piloting 24 December 11th 05 11:24 PM
Questions for Jay? mikem Owning 8 February 29th 04 02:09 PM
Mig-29 questions & general aviation questions 2003 Steven Military Aviation 1 October 20th 03 06:06 AM
Seven Questions For Michael Moore from a Blogger (was Questions for Mr. Bush, from Michael Moore) Jim Yanik Military Aviation 2 October 9th 03 09:36 PM
