At what point is "builder" status conferred?
Old July 9th 08, 02:38 PM posted to rec.aviation.homebuilt
es330td
Default At what point is "builder" status conferred?
In the thread I started about the 700 mile commuter airplane someone
suggested getting a used Long-EZ. (I would like to point out that my
dream of flying began the day I was much younger when I saw picture in
a late '80's National Geographic of two EZ's and a Viggen flying in
formation so Rutan's designs are dear to my heart.) I started looking
around and found several Long-EZ's for sale or sold recently that
could be had very affordably. I also noticed a number of planes that
would require work that varied from as little as needing an annual to
others that needed an engine/prop to others that were only partially
constructed.
For a homebuilt, is builder status conferred on the person who buys
the kit/plans and starts it or if I buy a partially built plane and do
the rest am I now the builder of the plane?
In addition, what happens if I buy a VFR plane and then replace the
engine and avionics and make it a IFR platform? Am I the builder for
the parts I put on it or does the fact that I bought an already
airworthy plane make it in essence little different than buying a 172?
BTW...I'm joining EAA this week. I have a strong feeling that a lot
of these answers (and a whole bunch of questions I haven't asked yet)
are available on their members only website. I've already told my
wife that Kitplane is to never be recycled but it is also clear that
other resources are required before I spend a dime on anything.
As an aside, thanks for everyone's responses on all these. I
appreciate that nobody complains about my lack of knowledge and that
the discussions here remain civil (thus far, anyway.) I learned a
good deal just reading the discussion following my previous post.
Old July 9th 08, 07:02 PM posted to rec.aviation.homebuilt
Jim Logajan
FAA Advisory Circular AC 20-27F "Certification and Operation of
Amateur-Built Aircraft" should address that and some of your other
questions - you may want to review it since it discusses the paperwork
angle and steps needed for certification. It is online he
http://www1.airweb.faa.gov/Regulatory_and_Guidance_Library/rgAdvisoryCircular.nsf/0/0ca2845e2aafffbb86256dbf00640cb2/$FILE/AC20-27F.pdf
There may be multiple builders, but only one of the builders can get the
repairman's certificate for that aircraft: the "primary builder" who can
prove to the FAA that they know how to determine whether the aircraft is
in a condition for safe operation. The repairman certificate merely adds
annual condition inspection to your list of privileges.
Old July 9th 08, 09:21 PM posted to rec.aviation.homebuilt
Gig 601Xl Builder
constructed.
Anyone can work on an Am-HB aircraft. And I mean anyone, you, your
mother, the old guy down the street and his granddaughter. The builder
is the person that is listed as the aircraft builder when the plane gets
it's airworthiness and that person is the only person who can get the
repairman's certificate associated with that plane and what it does is
bestows on the owner the ability to do his own annual condition
inspections. This is important, because while anyone can do any work on
the plane every year somebody either an A&P or the guy with the
repairman's certificate for the plane is going to have to sign off on
what has been done on the plane.
If you buy an aircraft that has been completed by someone else you will
be able to work on it but you will never be able to do the annuals.
One thing to remember. The FAA is probably about to start really
cracking down on these places that build homebuilts for you. So if you
do buy a semi-completed airplane make sure you can prove that it was
semi-completed by someone other than a place doing it commercially.
My bet is by the end of the year we will start hearing stories about
people that used the "builder assistance programs" and then when it
comes time to get the plane inspected no AW certificate is granted.
For more info Google FAA Advisory Circular AC 20-27F.
Old July 10th 08, 12:36 AM posted to rec.aviation.homebuilt
150flivver
Bryan Martin
N61BM, CH 601 XL, Ram Subaru, Stratus redrive.
There is only one builder and that is established when the
Airworthiness
Certificate gets issued. Modifications afterwards may require the FAA
to issue additional operational limitations depending on the nature of
the modifications. An example would be a VFR limitation that you want
changed to allow for IFR operations. Installing a different engine
will generate a subsequent flight test period similar to the hours
that had to be flown off initially. Minor mods do not need anyone to
sign off on as there is no "return to service" signature needed as in
normal category aircraft. This is a primary advantage of the Amateur
Built Experimental--no STCs, no 337s, no return to service--much
different than the rules pertaining to a 172,
Old July 10th 08, 01:07 PM posted to rec.aviation.homebuilt
Peter Dohm
"150flivver" wrote in message
Bryan Martin
Airworthiness
Actually, it can be both a primary advantage and a primary dissadvantage.
It is hypothetically possible modify the aircraft such that a new flight
test period will be required, determine during the test period that the
modification is inferior to the original, and then find that you can not
simply return to the original equipment or configuration--possibly due to
something that reportedly occurred on another aircraft. I have no idea
whether such a thing has ever occurred in practice; but it was told to me as
an illustration of one of the differences between a type certificate and a
one time approval of operating limitations.
Old July 10th 08, 01:51 PM posted to rec.aviation.homebuilt
Stealth Pilot[_2_]
On Thu, 10 Jul 2008 08:07:24 -0400, "Peter Dohm"
Bryan Martin
Airworthiness
that is the answer to the guys question
snip
I doubt that that is entirely correct.
what they are mixing up is the regimen of the certified aircraft and
the total absense of the regimen for amateur built experimentals.
an amateur built experimental can be modified ad infinitum since ad's
and such never apply to experimental. they are part of the certified
environment.
mods from the original signoff can invalidate the original C of A and
require it to be reissued, sending the owner through the proof of
structural integrity period again.
in the worst case where no one will issue new paperwork the owner
could surrender the registration then assemble a new aircraft from
various parts and ask for it to be registered.
if he can prove 51% then he is the builder for the new registration.
NEVER mix aspects of certification with aspects of experimental.
experimental is basically an exemption from the certification
requirements. all experimental aircraft are maintained on an
individual basis. a mishap with another similar aircraft only matters
in the certified world. experimentals are not certified aircraft.
Stealth Pilot
Old July 11th 08, 12:45 AM posted to rec.aviation.homebuilt
150flivver
On Jul 10, 7:51 am, Stealth Pilot
Stealth Pilot
51% has nothing to do with the issuance of a repairman certificate or
determining who is the builder.
Old July 11th 08, 11:23 AM posted to rec.aviation.homebuilt
Stealth Pilot[_2_]
On Thu, 10 Jul 2008 16:45:08 -0700 (PDT), 150flivver
Stealth Pilot
I dont believe that that is correct either.
if you fail to establish that you are the builder of 51% of the
aircraft then you wont be eligible for the maint authority.
Stealth Pilot
Old July 11th 08, 01:34 PM posted to rec.aviation.homebuilt
Lou
Stealth Pilot
if that is true, then how do schools, flying clubs, eaa chapter, and
2 or 3 friends getting together to build submit the paper work?
Lou
Old July 11th 08, 01:42 PM posted to rec.aviation.homebuilt
cavelamb himself[_4_]
Stealth Pilot
Lou
It's not true.
The person who gets the repairman's certificate doesn't have to prove
anything. Except that he can spell his name.
CUBI POINT - "CBUBI POINT.jpg" 90.4 KBytes [email protected] Aviation Photos 7 April 9th 08 10:11 AM
Phrase "landing runway" vs. "cleared to land" Robert M. Gary Piloting 168 February 5th 08 05:32 PM
Phrase "landing runway" vs. "cleared to land" Robert M. Gary Instrument Flight Rules 137 February 5th 08 05:32 PM
For Dudley, "Three point reverse roll to knife-edge" what?! gatt[_2_] Piloting 13 December 13th 07 10:26 PM
Old polish aircraft TS-8 "Bies" ("Bogy") - for sale >pk Aviation Marketplace 0 October 16th 06 07:48 AM
