Conventional v tricycle gear
Old July 10th 08, 02:52 PM posted to rec.aviation.piloting
Default Conventional v tricycle gear
On Jul 10, 9:06*am, Stealth Pilot
On Thu, 10 Jul 2008 07:54:50 +0000 (UTC), Bertie the Bunyip
wrote in
On Jul 9, 1:24 pm, Bertie the Bunyip wrote:
I still don't see it shortening the landing roll. Can't see the
physics that would make a wheel landing shorter. I'll just have to
try it!
* Here are the physics:
* * The trike, to get maximum weight on its mains for braking
traction, has to keep its weight off the nose. We can use full up-
elevator, but the presence of the nosewheel assures us that it will
take some of the weight and that we cannot get the wing's AOA low
enough to stop it lifting. The only advantage we have in the trike is
the elevator's downforce added to the airplane's weight. Electric flas
make it worse, since we can't retract them instantly to dump their
lift.
* * * The taildragger can get its tail way up high. If you sit in the
airplane while its tail is on a jack or some other support so that the
airplane is in level attitude, you will be astounded at how nose-low
it feels. Observe the propeller clearance in this position, too, and
make some allowance for bouncing that might lower the prop closer to
the runway. I used to do this with students who were afraid to raise
the tail to level attitude, and they always amazed at the picture out
the front.
* * *A taildragger with long legs, like a 185, can get its tail even
higher than level. I've seen a shot of a Helio Courier with its tail
up so that the fuselage was pointed downward at 5 or 10 degrees, and
the pilot was braking hard. No lift at all in that scenario, and
manual flaps can be retracted quickly to get even more weight on the
wheels. Most taildraggers will have the main axles 15 degrees ahead of
the airplane's CG, meaning that if you pick up the tail you can raise
it until the airplane is at that 15 degree nose-low attitude and it
will be balanced there. You'd better have lots of skill if you're
going to try this in the rollout. Pilots of another humanitarian
outfit that operated Helios did this all the time, since the Helio's
short-field takeoff capabilities are of no use if you can't get into
that short little strip and get stopped in the first place.
Oh, I can do it, but I don't see it giving you any more braking. Quite
the contrary. A given braking force will apply a rotational force around
the airplane's gear. In the three point attitude, you've got more of the
airpane sitting behind the gear, so more braking should be available.
Also, if you touch down in the same spot three point as opposed to doing
a wheel landing, you should have touched down with less airspeed.
Therefore less energy to kill.
For the sake of argument, let's say that you touched down at the same
speed, though, and that you are now tail high. It would want to be very
high indeed to contribute the same amount of aerodynamic drag as the
three point attitude. OK, your Cf is a bit better because of the extra
weight on the wheels, but since the limiting factor is nosing the
airplane over as opposed to achieving max Cf that's irrelevant.
Bertie
the wings stop an aircraft more effectively than tiny brake pucks.
thats why 3 pointing it achieves the shortest landing.
the actual landing speed is lower and the wing is generating lotsa
induced drag on the backside of the performance curve.
I dont believe that getting rid of flaps shortens the landing.
Stealth Pilot
In something like a Mooney, full flaps into the flare, flying the
airplane until it's out of airspeed, then sucking in the flaps just at
touchdown does shorten the landing roll -- weight gets onto the mains
a lot sooner, so frictional braking works when there's not airspeed
left to keep the nosewheel high. On the other hand, I'd not be
surprised to learn the difference is stopping distance from touchdown,
keeping the flaps extended vs retracting them, is less than 30 feet.
My goal is to touch down close enough to where I want to exit the
active so that it doesn't take much engine, or much braking, to make
the turn.
It drives me nuts to see the 172 I'm following touch down on the
numbers when the turn off is 3000 feet down the runway
Tricycle gear Cub? Ken Finney Piloting 8 September 17th 07 11:43 PM
Hiroshima/Nagasaki vs conventional B-17 bombing zxcv Military Aviation 55 April 4th 04 07:05 AM
Tricycle Midget Thought Dick Home Built 4 March 26th 04 11:12 PM
WarPac War Plans-any conventional? Matt Wiser Military Aviation 1 December 8th 03 09:29 PM
tricycle undercarriage G. Stewart Military Aviation 26 December 3rd 03 02:10 AM
