C-152 Leaseback: what's the scoop?
Old July 10th 08, 05:01 PM posted to rec.aviation.piloting
gatt[_5_]
Default C-152 Leaseback: what's the scoop?
Martin Hotze wrote:
if there is so much expected business than he won't need you for a
leaseback. What's the cost of a usable C150/152?
http://www.aso.com/ lists them from USD 16,500 to USD 65,500. I'd say
for 30 AMU you'll get a usable plane. Why does he want a leaseback?
He just purchased the entire fuel operation for the airport, plus two or
three C-172s and a $250K flight simulator. There was a C-152 on
leaseback but the owner sold it for a larger airplane, so there's an
empty tiedown marked "RESERVED FOR FLIGHT SCHOOL" where the second C-152
used to be.
-c
Old July 10th 08, 05:24 PM posted to rec.aviation.piloting
RST Engineering
The hot setup is where you provide an aluminum tube and the lessee provides
fuel, scheduled maintenance, and insurance. That way if the aircraft isn't
used much, all you are out is the cost of the airplane which you should be
able to recover if you bought it right.
"It is the mark of an educated mind to be able to entertain a thought
without accepting it."
--Aristotle
"gatt" wrote in message
http://www.aso.com/ lists them from USD 16,500 to USD 65,500. I'd say for
three C-172s and a $250K flight simulator. There was a C-152 on leaseback
but the owner sold it for a larger airplane, so there's an empty tiedown
marked "RESERVED FOR FLIGHT SCHOOL" where the second C-152 used to be.
-c
What's the scoop on Headsets Inc? Jim Carter[_1_] Piloting 11 April 17th 07 03:48 AM
What's the scoop on Headsets Inc? Jim Carter[_1_] Owning 11 April 17th 07 03:48 AM
Is there any new scoop on the LS-10? John Bojack Soaring 16 September 28th 05 09:52 AM
Air scoop for Russia Serge Serfaty Soaring 2 July 14th 05 04:20 PM
Reverse scoop Paul Lee Home Built 9 April 13th 04 01:58 AM
