Alan Minyard wrote in message . ..
On Tue, 9 Dec 2003 00:29:04 +0000, "Paul J. Adam" wrote: In message , Alan Minyard writes Much better to go with an M-61 variant that actually works, is combat proven, and has a useful rate of fire. Trouble is, this gets you back where the US was in 1950; the M3 .50" was a superb gun in terms of reliability, ballistics and rate of fire and was a thoroughly proven weapon. Trouble is, nobody convinced the MiG-15s of that fact, so they soaked up a _lot_ of hits where a larger-calibre weapon would have made the F-86 versus MiG-15 kill ratio even _more_ impressive. And who out there is going to use significant numbers of unreliable, heavy, slow cannon to oppose a US Force? The rate of fire of the .50 was not enough to make up for the somewhat smaller calibre, that is not the case with the M-61. Possibly, possibly not. The bigger the target is, the more damage you have to inflict to down it. A MiG-15 weighed under 3,800 kg empty, a Su-27 around 18,000 kg - nearly five times as much. A 20mm shell weighs only just over twice as much as a .50 bullet. You can double its effectiveness in recognition of the HEI content, but even so you are still left with a pretty even match between the .5/MiG-15 and 20mm/Su-27 in terms of destructive effect compared with target weight. Tony Williams Military gun and ammunition website: http://www.quarry.nildram.co.uk Discussion forum at: http://forums.delphiforums.com/autogun/messages/ |
![]() "Alan Minyard" wrote in message news ![]() On 9 Dec 2003 13:40:45 -0800, (Tony Williams) wrote: Alan Minyard wrote in message . .. On Tue, 9 Dec 2003 00:29:04 +0000, "Paul J. Adam" wrote: In message , Alan Minyard writes Much better to go with an M-61 variant that actually works, is combat proven, and has a useful rate of fire. Trouble is, this gets you back where the US was in 1950; the M3 .50" was a superb gun in terms of reliability, ballistics and rate of fire and was a thoroughly proven weapon. Trouble is, nobody convinced the MiG-15s of that fact, so they soaked up a _lot_ of hits where a larger-calibre weapon would have made the F-86 versus MiG-15 kill ratio even _more_ impressive. And who out there is going to use significant numbers of unreliable, heavy, slow cannon to oppose a US Force? The rate of fire of the .50 was not enough to make up for the somewhat smaller calibre, that is not the case with the M-61. Possibly, possibly not. The bigger the target is, the more damage you have to inflict to down it. A MiG-15 weighed under 3,800 kg empty, a Su-27 around 18,000 kg - nearly five times as much. A 20mm shell weighs only just over twice as much as a .50 bullet. You can double its effectiveness in recognition of the HEI content, but even so you are still left with a pretty even match between the .5/MiG-15 and 20mm/Su-27 in terms of destructive effect compared with target weight. Tony Williams Military gun and ammunition website: http://www.quarry.nildram.co.uk Discussion forum at: http://forums.delphiforums.com/autogun/messages/ Are you familiar with the concept of guided missiles? If you get into gun range you have already screwed the pooch. The gun is a last ditch, desperation weapon in ACM, wasting airframe volume and weight on a honking great, slow, unreliable gun is not a wise trade off. Yeah, a terrible tradeoff...right up to the point where you (or, more accurately those you are supporting below who are locked in a very nasty "knife" fight that precludes use of JDAM or an LGB) need it, as was found during Anaconda. Brooks Al Minyard |
On Wed, 10 Dec 2003 14:53:47 GMT, "Kevin Brooks"
wrote: "Alan Minyard" wrote in message news ![]() Are you familiar with the concept of guided missiles? If you get into gun range you have already screwed the pooch. The gun is a last ditch, desperation weapon in ACM, wasting airframe volume and weight on a honking great, slow, unreliable gun is not a wise trade off. Yeah, a terrible tradeoff...right up to the point where you (or, more accurately those you are supporting below who are locked in a very nasty "knife" fight that precludes use of JDAM or an LGB) need it, as was found during Anaconda. Brooks The more things change, the more they remain the same. I've only opined once in this long thread, but thought I'd jump in again after this. Some points: 1. The M-61, with roughly fifty years of experience is a reliable gun. It's been modded and carried in a lot of different systems and made a number of A/A kills. A.) It doesn't jam. (It is possible, but it definitely isn't common.) B.) The the internal gun and several pod variants are linkless feed. Some pods are link-fed. C.) Spin-up time is virtually negligible. Consider that in the F-105, the barrel in which the cartridge was sparked was still internal, meaning the gun must rotate to the exposed barrel position before the bullet leaves the barrel. Pass through of unfired rounds on spin-up/down was usually counted as six. On scored strafe, the rounds limiter was traditionally set at 150 round. With that, you could get four or five strafe passes. A good shooter could score 80% or higher out of rounds fired and every pass counted those six unfired rounds. That means spin up is virtually instantaneous. Trigger squeeze to release on strafe was taught to be .5 seconds. Good strafers could get a shorter burst. Spin up is negligible. D.) Projectile size/payload is important, but a trade-off. Yes, a kill with a 37mm hit is more likely than a 20mm hit. But, if I can't carry enough projectiles to give me a good density or chance to hit, then the higher Pk is meaningless. 2. Dogfighting, meaning one-v-one maneuvering to a gun kill is a foolish endeavor. You might wind up there, but you should studiously avoid it. Once there, shoot and scoot. This isn't an airshow display and no one but the survivor will recount the aeronautical skill displayed. Shoot with missiles. Shoot at the maximum range. Get the kill confirmed by AWACS. 3. The final insert by Brooks is irrelevant to the discussion. The question has been about guns and air/air. The question of optimum CAS weapon isn't trivial and my reply shouldn't be taken as one more evidence of the AF aversion to support of ground troops. There is NOTHING more important. But: A.) First, support of ground troops involves keeping enemy aircraft from being a player. We've done that successfully in every conflict since WW II. B.) CAS does not have to be fifty feet overhead with snake/nape on "enemy in the wire". It can evolve to that scenario but doesn't happen as often as common perception would think. C.) Modern stand-off weapons provide equal or greater accuracy than close-in laydown and without either jeopardizing the delivery aircraft or warning the target to hunker down. D.) While no one can put a value on the life of one American soldier, a cost/benefit analysis of what strafe can do compared to the risk involved usually mitigates against strafe being a primary tactic. It's great for SAR and can be effective on close-in CAS, but it's better done with an A-10 type system than an A/A optimized platform (which was what the thread has been talking about.) E.) While the guy on the ground may be firmly (and rightly) convinced that his battle is the most important, the commanders must allocate resources based on priorities which often don't have as much emotion attached. Getting strafe to the troops in Anaconda wasn't a readily available option. F.) Good Forward Observers (FACs or AOs) should be calling early for support. Good FOs should be GPS and Laser equipped and getting the job done well before the more spectacular troops in the wire scenario occurs. JDAMs et. al. are a much better choice. Bigger payload, greater effect, better accuracy than strafe, more economical, etc. At least, those are some of my impressions on the argument. |
![]() "Ed Rasimus" wrote in message ... On Wed, 10 Dec 2003 14:53:47 GMT, "Kevin Brooks" wrote: "Alan Minyard" wrote in message news ![]() Are you familiar with the concept of guided missiles? If you get into gun range you have already screwed the pooch. The gun is a last ditch, desperation weapon in ACM, wasting airframe volume and weight on a honking great, slow, unreliable gun is not a wise trade off. Yeah, a terrible tradeoff...right up to the point where you (or, more accurately those you are supporting below who are locked in a very nasty "knife" fight that precludes use of JDAM or an LGB) need it, as was found during Anaconda. Brooks The more things change, the more they remain the same. I've only opined once in this long thread, but thought I'd jump in again after this. Some points: snip good info 3. The final insert by Brooks is irrelevant to the discussion. When the comment is made quite emphatically that no gun should be included in the newer aircraft, by more than one poster, I disagree with your conclusion of irrelevance. The question has been about guns and air/air. The question of optimum CAS weapon isn't trivial and my reply shouldn't be taken as one more evidence of the AF aversion to support of ground troops. There is NOTHING more important. But: A.) First, support of ground troops involves keeping enemy aircraft from being a player. We've done that successfully in every conflict since WW II. That is only one aspect of support of ground troops. And if anything an increasingly *less* important one at that--note that we have not faced a significant air threat to our ground troops since WWII, Ed. B.) CAS does not have to be fifty feet overhead with snake/nape on "enemy in the wire". It can evolve to that scenario but doesn't happen as often as common perception would think. But it does happen, period. Did it happen during Anaconda or not? The reports I read said it did--feel free to correct that representation. C.) Modern stand-off weapons provide equal or greater accuracy than close-in laydown and without either jeopardizing the delivery aircraft or warning the target to hunker down. And what about when the threat you are engaging is well within the danger close margin? If it comes down to the gun as the best available support option versus having the CAS folks say, "Sorry, we can't do anything since we don't have guns, but we wish you the best of luck and will be thinking kind thoughts of you...", I'd take the former, thank you. Luckily, the USAF seems to share that view. D.) While no one can put a value on the life of one American soldier, a cost/benefit analysis of what strafe can do compared to the risk involved usually mitigates against strafe being a primary tactic. Nobody has said it should be a *primary* tactic. It's great for SAR and can be effective on close-in CAS, but it's better done with an A-10 type system than an A/A optimized platform (which was what the thread has been talking about.) As to "what this thread has been talking about", this thread has also the comment, "Air-to-ground, guns pull you into IR-SAM range and even for A-10s that isn't healthy." And the fact is that the majority of CAS missions are being flown by F-15E's, F-16's, F/A-18's, and most likely in the future by platforms like the F-35 and even (gasp!) the F/A-22, not by A-10's. See below for the types of aircraft flying strafe during Anaconda. E.) While the guy on the ground may be firmly (and rightly) convinced that his battle is the most important, the commanders must allocate resources based on priorities which often don't have as much emotion attached. Getting strafe to the troops in Anaconda wasn't a readily available option. It wasn't?! Reports I read indicated it actually occurred, so I wonder how you determine it "wasn't a readily available option"? "I had an aircraft overhead carrying 500-pound bombs, but the 'bad guys' were too close to our position to drop that much ammo without risking our lives. I waved the pilot off the bomb run. I had him come around and strafe the area with guns," said the sergeant. (www.af.mil/news/May2002/n20020529_0868.shtml ) "Then F-15s were overhead and the combat controller was directing them to the enemy according to my instructions. I told the combat controller to have the F-15s to strafe the bunker and have them come in from our right to our left....I told him to clear them and the rounds hit right by the bunker. I told him to have them do that over and over again. I think the gun runs were made by both F-15s and F-16s." (globalspecops.com/sts.html ) Go to Google and search based upon "Operation Anaconda strafe" and you can find quite a few specific reports. F.) Good Forward Observers (FACs or AOs) should be calling early for support. Good FOs should be GPS and Laser equipped and getting the job done well before the more spectacular troops in the wire scenario occurs. JDAMs et. al. are a much better choice. Bigger payload, greater effect, better accuracy than strafe, more economical, etc. That is all great and is what we'd *like* to see happen--but as we saw in Anaconda, it doesn't always flesh out that way. One of the best qualities of a first-class military is recognition of the importance of flexibility--taking the strafe capability away from the aircraft that perform most of the CAS does little to enhance that quality. I hope you are not arguing that would be the way to go. Brooks At least, those are some of my impressions on the argument. |
On Wed, 10 Dec 2003 17:49:17 GMT, "Kevin Brooks"
wrote: "Ed Rasimus" wrote in message .. . The more things change, the more they remain the same. I've only opined once in this long thread, but thought I'd jump in again after this. Some points: snip good info 3. The final insert by Brooks is irrelevant to the discussion. When the comment is made quite emphatically that no gun should be included in the newer aircraft, by more than one poster, I disagree with your conclusion of irrelevance. The thread title is "Best Dogfight Gun". The relevance of the comment is to tactical aircraft employment in support of ground forces, and I freely conceded the importance in follow-on comments. The question has been about guns and air/air. The question of optimum CAS weapon isn't trivial and my reply shouldn't be taken as one more evidence of the AF aversion to support of ground troops. There is NOTHING more important. But: A.) First, support of ground troops involves keeping enemy aircraft from being a player. We've done that successfully in every conflict since WW II. That is only one aspect of support of ground troops. And if anything an increasingly *less* important one at that--note that we have not faced a significant air threat to our ground troops since WWII, Ed. The prosecution should rest with that acknowledgement. It is my point exactly. The historic result should not be attributed to wishing and hoping. It's a result of proper allocation of resources. B.) CAS does not have to be fifty feet overhead with snake/nape on "enemy in the wire". It can evolve to that scenario but doesn't happen as often as common perception would think. But it does happen, period. Did it happen during Anaconda or not? The reports I read said it did--feel free to correct that representation. It happened. But, anecdotal evidence does not necessarily lead to good conclusions. C.) Modern stand-off weapons provide equal or greater accuracy than close-in laydown and without either jeopardizing the delivery aircraft or warning the target to hunker down. And what about when the threat you are engaging is well within the danger close margin? If it comes down to the gun as the best available support option versus having the CAS folks say, "Sorry, we can't do anything since we don't have guns, but we wish you the best of luck and will be thinking kind thoughts of you...", I'd take the former, thank you. Luckily, the USAF seems to share that view. Modern warfare is a mix of sophistication and crudity. Can you say "Claymore"? Seriously, I'm not belittling nor minimizing. There's a mix of weapons. Some you have available, some you don't. Some are better than others. CAS strafe is exhilarating to say the least. But, it isn't the only weapon for danger close situations. Mortars, proper fortifications, Army aviation assets, etc. all can be considered in the right time and the right place. I'm a believer in guns in airplanes. But, I'll freely acknowledge that the gun isn't the best choice in a lot of scenarios. I'm not willing to forego the gun in current or future tactical aircraft. However, I've seen a lot of airplanes lost while shooting trucks. Modern jets cost a lot more than trucks. Going nose to nose with superior weapons with a pea-shooter isn't always prudent. It may be necessary, but not wise. D.) While no one can put a value on the life of one American soldier, a cost/benefit analysis of what strafe can do compared to the risk involved usually mitigates against strafe being a primary tactic. Nobody has said it should be a *primary* tactic. Prosecution rest time again. E.) While the guy on the ground may be firmly (and rightly) convinced that his battle is the most important, the commanders must allocate resources based on priorities which often don't have as much emotion attached. Getting strafe to the troops in Anaconda wasn't a readily available option. It wasn't?! Reports I read indicated it actually occurred, so I wonder how you determine it "wasn't a readily available option"? It wasn't a readily available option when initially called for. Remember that Afghanistan is a long way from anywhere. At the time of Anaconda, the primary tactical assets were carrier based and flying extremely long duration, multiple refueling sorties. The flexibility for immediate on-call CAS was not available. "I had an aircraft overhead carrying 500-pound bombs, but the 'bad guys' were too close to our position to drop that much ammo without risking our lives. I waved the pilot off the bomb run. I had him come around and strafe the area with guns," said the sergeant. (www.af.mil/news/May2002/n20020529_0868.shtml ) The sergeant has an extremely optimistic view of the strafing accuracy of the average F-15/16/18 operator, and extremely pessimistic one of the reliability of PGMs. Interestingly, the report you cite says the fighters fired til "winchester" but the enemy continued to operate and then...drum roll, please...he targeted the bunker with the 500 pound bombs. Which took out the bunker. Might I suggest that the sergeant's account might be sensationalized for effect and that he was not an experienced forward air controller. I don't know. F.) Good Forward Observers (FACs or AOs) should be calling early for support. Good FOs should be GPS and Laser equipped and getting the job done well before the more spectacular troops in the wire scenario occurs. JDAMs et. al. are a much better choice. Bigger payload, greater effect, better accuracy than strafe, more economical, etc. That is all great and is what we'd *like* to see happen--but as we saw in Anaconda, it doesn't always flesh out that way. One of the best qualities of a first-class military is recognition of the importance of flexibility--taking the strafe capability away from the aircraft that perform most of the CAS does little to enhance that quality. I hope you are not arguing that would be the way to go. Not at all, but I argue regularly that strafe is a weapon of last resort in modern aircraft. |
![]() "Ed Rasimus" wrote in message ... On Wed, 10 Dec 2003 17:49:17 GMT, "Kevin Brooks" wrote: "Ed Rasimus" wrote in message .. . The more things change, the more they remain the same. I've only opined once in this long thread, but thought I'd jump in again after this. Some points: snip good info 3. The final insert by Brooks is irrelevant to the discussion. When the comment is made quite emphatically that no gun should be included in the newer aircraft, by more than one poster, I disagree with your conclusion of irrelevance. The thread title is "Best Dogfight Gun". The relevance of the comment is to tactical aircraft employment in support of ground forces, and I freely conceded the importance in follow-on comments. Threads drift. FYI, the introduction of the air-to-ground issue was from another poster. The question has been about guns and air/air. The question of optimum CAS weapon isn't trivial and my reply shouldn't be taken as one more evidence of the AF aversion to support of ground troops. There is NOTHING more important. But: A.) First, support of ground troops involves keeping enemy aircraft from being a player. We've done that successfully in every conflict since WW II. That is only one aspect of support of ground troops. And if anything an increasingly *less* important one at that--note that we have not faced a significant air threat to our ground troops since WWII, Ed. The prosecution should rest with that acknowledgement. It is my point exactly. The historic result should not be attributed to wishing and hoping. It's a result of proper allocation of resources. Uhmmm...do you or do you not agree that the air-to-ground role has consumed the vast majority of USAF (and for that matter USN aviation) missions since WWII? B.) CAS does not have to be fifty feet overhead with snake/nape on "enemy in the wire". It can evolve to that scenario but doesn't happen as often as common perception would think. But it does happen, period. Did it happen during Anaconda or not? The reports I read said it did--feel free to correct that representation. It happened. But, anecdotal evidence does not necessarily lead to good conclusions. I'd consider disparate and repeated "anecdotal evidence" of the sort provided below to be rather compelling. According to what our resident current Strike eagle driver has posted in a similar thread, the USAF apparently agrees. C.) Modern stand-off weapons provide equal or greater accuracy than close-in laydown and without either jeopardizing the delivery aircraft or warning the target to hunker down. And what about when the threat you are engaging is well within the danger close margin? If it comes down to the gun as the best available support option versus having the CAS folks say, "Sorry, we can't do anything since we don't have guns, but we wish you the best of luck and will be thinking kind thoughts of you...", I'd take the former, thank you. Luckily, the USAF seems to share that view. Modern warfare is a mix of sophistication and crudity. Can you say "Claymore"? Seriously, I'm not belittling nor minimizing. There's a mix of weapons. Some you have available, some you don't. Some are better than others. CAS strafe is exhilarating to say the least. But, it isn't the only weapon for danger close situations. Mortars, proper fortifications, Army aviation assets, etc. all can be considered in the right time and the right place. Mortars have to have a dedicated logistics effort behind them--during Anaconda that feature was somewhat stretched, from what I have read. Fortifications in an offensive operation? Hey, survivability enhancement was one of our primary considerations as combat engineers, but we rarely plan for such near the LC during an offensive operation--that sort of went out with the days of scientific seige warfare with its "circumvalation" and what not. Army aviation assets are great, but as we saw in Anaconda (and during OIF as well) there are environments where its capabilities are challenged such that fixed wing CAS provides a better alternative. Yes, we plan for the use of all of these whenever possible--but maintaining the strafe capability in the collective bag of tricks can still come in handy. I'm a believer in guns in airplanes. But, I'll freely acknowledge that the gun isn't the best choice in a lot of scenarios. Agreed. My argument is not that the gun is the paramount, or in most cases even an "equally important" component of the overall weapons suite, but that it can be of valuable use in the CAS arena in some circumstances, and that deletion of gun armament accomplishes little for the loss of some valuable flexibility. I'm not willing to forego the gun in current or future tactical aircraft. However, I've seen a lot of airplanes lost while shooting trucks. Modern jets cost a lot more than trucks. Going nose to nose with superior weapons with a pea-shooter isn't always prudent. It may be necessary, but not wise. Agreed again. Taking the fight into the other guy's "backyard", so to speak, should only be done when the gain is assessed as being worth the additional risk. During Anaconda that was a no brainer--the Taliban/AQ folks had not demonstrated any capability with MANPADS (and there had always been significant doubt as to the viability of those Stingers we heard so much about due to the storage limits on their batteries, not to mention their cooling system for the seeker), so the additional risk was marginal, while the payoff was reportedly quite valuable, in terms of actual target effects and, likely just as important, I'd imagine the morale of those guys pinned down in some shallow wadi under close engagement proabably improved every time one of the fast movers passed overhead. D.) While no one can put a value on the life of one American soldier, a cost/benefit analysis of what strafe can do compared to the risk involved usually mitigates against strafe being a primary tactic. Nobody has said it should be a *primary* tactic. Prosecution rest time again. E.) While the guy on the ground may be firmly (and rightly) convinced that his battle is the most important, the commanders must allocate resources based on priorities which often don't have as much emotion attached. Getting strafe to the troops in Anaconda wasn't a readily available option. It wasn't?! Reports I read indicated it actually occurred, so I wonder how you determine it "wasn't a readily available option"? It wasn't a readily available option when initially called for. Remember that Afghanistan is a long way from anywhere. At the time of Anaconda, the primary tactical assets were carrier based and flying extremely long duration, multiple refueling sorties. The flexibility for immediate on-call CAS was not available. I have not gotten that impression. Yeah, there was a distance to be covered (not sure it applied to all CAS assets, as IIRC there were A-10's forward based in Afghanistan proper rather early, and a couple of airfields located just north of Afghanistan in one of the other -stans). But there was apparently a CAS stack of sorts available, which is why these examples of timely support are evident. I'd be careful about using MG Hagenbach's after action criticisms of CAS in such a vein. "I had an aircraft overhead carrying 500-pound bombs, but the 'bad guys' were too close to our position to drop that much ammo without risking our lives. I waved the pilot off the bomb run. I had him come around and strafe the area with guns," said the sergeant. (www.af.mil/news/May2002/n20020529_0868.shtml ) The sergeant has an extremely optimistic view of the strafing accuracy of the average F-15/16/18 operator, and extremely pessimistic one of the reliability of PGMs. Interestingly, the report you cite says the fighters fired til "winchester" but the enemy continued to operate and then...drum roll, please...he targeted the bunker with the 500 pound bombs. Which took out the bunker. Might I suggest that the sergeant's account might be sensationalized for effect and that he was not an experienced forward air controller. I don't know. From reading the full account (see http://www.robins.af.mil/pa/revup-on...y31-02-all.pdf ), it is apparent that they went to a rather nasty danger-close bomb effort only when things were even worse in terms of their situation. What about the other account? Can you discount it as readily? Or... "According to the citation, Captain Russell's flight, call sign Twister 52, made contact with an American ground forward air controlling team that was taking fire from enemy troops 75 meters away. The ground team restricted Twister flight to strafe passes due to a "danger close" condition. This condition meant friendly troops were within minimal risk distances of injury or death from friendly weapons on enemy locations...Twister flight made six strafe passes while firing 20-mm rounds from an altitude of 1,500 feet over the target area. This was well within the threat zone of small arms fire and surface to air missiles. The ground team reported enemy fire was suppressed on each pass, but requested more passes to kill steadily increasing numbers of reinforced Taliban and al Qaeda forces. Out of 20-mm ammunition, Twister 51, the aircraft manned by Maj. Chris Short and Lt. Col. Jim Fairchild, became the airborne forward air controller and targeted Captain Russell's jet on four additional low-altitude strafe passes. Due to radio failure, Twister 51 then passed the tactical lead to Captain Russell's aircraft. With the ground team's concurrence, Twister flight began employing laser-guided bombs. The two aircrews attempted to guide each successive bomb closer to enemy forces without injuring American service members. The aircrews were able to drop bombs as close as 200 meters from friendly forces." www2.acc.af.mil/accnews/dec02/02414.ht Then there is the following from an F-16 pilot who flew some of these missions during Anaconda: "When Burt and his wingman arrived, the first words they heard from Slick 01, the ground controller on the scene, were "Danger close, seventy-five meters." The words sent a chill down Burt's spine. The ground controller relayed they had two casualties and two critically wounded. Burt made two passes over the enemy position and emptied all 500 rounds. His wingman then came in and emptied all his 500 rounds. "We realized how close we were firing to the helicopter on the ground when we reviewed the cockpit tapes," Burt said. Though the F-16 pilots couldn't see exactly where their rounds were hitting, the troops on the ground indicated that they were getting good results. With their ammunition spent and the soldiers on the ground still coming under enemy fire, Burt talked to Slick 01 about bringing in some heavy ordnance. The enemy's close proximity, however, made a strike dangerous, even with laser-guided munitions. Burt had to be extremely careful not to drop his 500-pound bombs too close to the ground troops." [It goes on to describe how they did subsequently bring the bombs in by walking them ever closer, but not without at least one close call that caused the CCT to admonish them for having almost hit their own location] http://www.codeonemagazine.com/archi.../jul_02/354th/ So it appears there were numerous occasions of strafe missions being requested from the ground folks. F.) Good Forward Observers (FACs or AOs) should be calling early for support. Good FOs should be GPS and Laser equipped and getting the job done well before the more spectacular troops in the wire scenario occurs. JDAMs et. al. are a much better choice. Bigger payload, greater effect, better accuracy than strafe, more economical, etc. That is all great and is what we'd *like* to see happen--but as we saw in Anaconda, it doesn't always flesh out that way. One of the best qualities of a first-class military is recognition of the importance of flexibility--taking the strafe capability away from the aircraft that perform most of the CAS does little to enhance that quality. I hope you are not arguing that would be the way to go. Not at all, but I argue regularly that strafe is a weapon of last resort in modern aircraft. No disagreement there. Brooks |
Ed Rasimus wrote in message
It wasn't a readily available option when initially called for. Remember that Afghanistan is a long way from anywhere. At the time of Anaconda, the primary tactical assets were carrier based and flying extremely long duration, multiple refueling sorties. The flexibility for immediate on-call CAS was not available. Ed, I take issue with your last statement, unless you're limiting the scope of your answer to tacair only. My wing flew 300 sorties during Anaconda and dropped 845 JDAM's and 24 Mk84's providing excellent on call air power. Granted we're a heavy bomber and could fly 1000 miles and then loiter for a few hours, which the fighter guys couldn't do. I'm sure BUFDRVR can chime in with the BUFF's contribution to CAS in Afghanistan. It only goes to back up what you've been saying, methods of delivering CAS are changing. Cheers, Michael Kelly, Bone Maintainer |
"Alan Minyard" wrote in message news ![]() On 9 Dec 2003 13:40:45 -0800, (Tony Williams) wrote: Alan Minyard wrote in message ... On Tue, 9 Dec 2003 00:29:04 +0000, "Paul J. Adam" wrote: In message , Alan Minyard writes Much better to go with an M-61 variant that actually works, is combat proven, and has a useful rate of fire. Trouble is, this gets you back where the US was in 1950; the M3 .50" was a superb gun in terms of reliability, ballistics and rate of fire and was a thoroughly proven weapon. Trouble is, nobody convinced the MiG-15s of that fact, so they soaked up a _lot_ of hits where a larger-calibre weapon would have made the F-86 versus MiG-15 kill ratio even _more_ impressive. And who out there is going to use significant numbers of unreliable, heavy, slow cannon to oppose a US Force? The rate of fire of the .50 was not enough to make up for the somewhat smaller calibre, that is not the case with the M-61. Possibly, possibly not. The bigger the target is, the more damage you have to inflict to down it. A MiG-15 weighed under 3,800 kg empty, a Su-27 around 18,000 kg - nearly five times as much. A 20mm shell weighs only just over twice as much as a .50 bullet. You can double its effectiveness in recognition of the HEI content, but even so you are still left with a pretty even match between the .5/MiG-15 and 20mm/Su-27 in terms of destructive effect compared with target weight. Tony Williams Military gun and ammunition website: http://www.quarry.nildram.co.uk Discussion forum at: http://forums.delphiforums.com/autogun/messages/ Are you familiar with the concept of guided missiles? If you get into gun range you have already screwed the pooch. The gun is a last ditch, desperation weapon in ACM, wasting airframe volume and weight on a honking great, slow, unreliable gun is not a wise trade off. Yeah, a terrible tradeoff...right up to the point where you (or, more accurately those you are supporting below who are locked in a very nasty "knife" fight that precludes use of JDAM or an LGB) need it, as was found during Anaconda. Brooks In which case an M-61 works quite well. Al Minyard |
Alan Minyard wrote: Are you familiar with the concept of guided missiles? If you get into gun range you have already screwed the pooch. The gun is a last ditch, desperation weapon in ACM, wasting airframe volume and weight on a honking great, slow, unreliable gun is not a wise trade off. Comments nearly identical to the one above were very popular in the early 1960s. And then we got into a real shooting war, and pilots suddenly needed guns again. Yep, McNamara is still influencing military thought. I was sure we'd gotten over that, but what goes around, comes around. It's funny to hear someone call a gun "unreliable," since the failure rate for modern aircraft guns is *miniscule*... -- cirby at cfl.rr.com Remember: Objects in rearview mirror may be hallucinations. Slam on brakes accordingly. |
AIM-54 Phoenix missile | Sujay Vijayendra | Military Aviation | 89 | November 3rd 03 09:47 PM |
P-39's, zeros, etc. | old hoodoo | Military Aviation | 12 | July 23rd 03 05:48 AM |
