On Jul 15, 12:09 pm, wrote:
We are told, Vaughn, that engine failures sometimes happen when power is first reduced after take off. I don't know what the statistics are, but think failures in the downwind/base/final portions of flight are not very common. Failures at power reduction are no more common than any other sort, except perhaps in ultralights with their two-strokes that tend to seize up if they're not fully warmed up before takeoff, and they'll sometimes stop when power is reduced but they were going to quit soon anyway. Failures can happen anywhere. I've had an engine fail in the glide and another busted its crankshaft on climbout. Most common failures, by a wide margin, are attributed to carb ice, and it will get you anywhere at all if you're not educated enough to be aware of (A) what causes it, (B) when the risk is highest, (C) and what is sounds like. Every so often I hear of another airplane that had its engine quit, the conditions were perfect for carb ice, and the engine ran fine for the accident investigators. Carb ice could cause engine failure on power reduction, as the ice will be closing off the carb throat and the closing throttle valve will finish it. Maybe that's where the OWT comes from? Next most common cause is fuel starvation, more commonly called running out of gas or, sometimes, mismanaging tanks. Water in the fuel is third, then practice forced landings (when the thing iced up or got cold enough it didn't wake up for the overshoot), and the fifth is oil starvation. Not very common, that one. Catastrophic mechanical failure is rare (like the broken crank) and is usually found in airplanes that are poorly maintained or maybe abused. Dan |
More flaps? | WingFlaps | Piloting | 36 | May 26th 08 07:33 AM |
flaps again | Kobra | Piloting | 107 | January 5th 08 04:31 PM |
flaps again | Kobra | Owning | 84 | January 5th 08 04:32 AM |
flaps | Kobra[_4_] | Piloting | 84 | July 16th 07 06:16 PM |
flaps | Kobra[_4_] | Owning | 85 | July 16th 07 06:16 PM |
