Glider Cockpit with 4 Varios! Why?
Old July 16th 08, 04:57 PM posted to rec.aviation.soaring
ContestID67
Default Glider Cockpit with 4 Varios! Why?
http://www.canadabizmart.com/bootstr...ockpit-photos/
This web site has some nice pictures of aircraft cockpits, including
two gliders. If you scroll down you will find an LS-4 flying
inverted.
What caught my eye is that there appears to be four (4) varios in the
instrument panel. My soaring friends have been scratching our heads
trying to understand why you would ever need four varios in a single
glider.
Can anyone give some valid reasons why this would be useful?
Thanks, John DeRosa
Old July 16th 08, 05:12 PM posted to rec.aviation.soaring
vontresc
On Jul 16, 10:57*am, ContestID67 wrote:
http://www.canadabizmart.com/bootstr...ectacular-cock...
two gliders. *If you scroll down you will find an LS-4 flying
inverted.
instrument panel. *My soaring friends have been scratching our heads
glider.
Thanks, John DeRosa
Hmm looks like he has a Peschges VP4 installed which would account for
three of the four varios. The VP4 has a vario, and a speed to fly
output. I think those are the 2 top ones. So in essence there are only
2 vario systems installed in the LS. One electronic, and one manual.
Pete
Old July 16th 08, 05:16 PM posted to rec.aviation.soaring
Kloudy via AviationKB.com
instrument panel.
Hmm,
I only see three.
Still, seems a bit much.
I usually fly with the electric and one mechanical.
I'm interested in hearing rationale for more than that.
Message posted via AviationKB.com
http://www.aviationkb.com/Uwe/Forums...aring/200807/1
Old July 16th 08, 05:17 PM posted to rec.aviation.soaring
instrument panel.
Hmm,
I only see three.
Duuuh.
I see the Peschges now.
Message posted via http://www.aviationkb.com
Old July 16th 08, 06:08 PM posted to rec.aviation.soaring
Tuno
I only see three. Still, seems a bit much.
Not at all. I fly with one mechanical (in case of battery failure) and
two electric -- a 302 that is my backup logger, and an LX7007 that is
my primary.
The mechanical uses pure TE compensation, of course. The 302 is set to
netto compensation, the LX's to relative netto. So while there are
three varios, there is no redundant information.
~ted/2NO
Old July 16th 08, 08:37 PM posted to rec.aviation.soaring
Bruce
Just a thought - why would you install a mechanical vario in a new glider? (flame suit on)
Just thinking - you can easily have two completely separate electrical systems. Solar panels are expensive, but not
relative to the cost of all that carbon. It causes all sorts of nasty interference mixing capacity flasks and transducer
varios on a single TE probe.
So why would you not have two electronic varios - there is so much more you can do with them. They have no- or virtually
no moving parts to wear, and they are in my experience faster and more accurate.
So why install mechanical varios in a new high tech glide? Convince me.
Bruce
my primary.
~ted/2NO
Old July 16th 08, 09:14 PM posted to rec.aviation.soaring
Tuno
Well, to tell you the truth, my "mechanical" vario, isn't -- it's a
B40 (electric), that lets me switch to an internal battery if I have a
problem with the main batteries, bus, or fuse.
But it was mechanical in my last glider -- a Sage that came with the
V2C.
2NO
Old July 16th 08, 10:35 PM posted to rec.aviation.soaring
Ian
How well do electric ones react to nearby lightning bolts? Apart from
that, isn't it an awful lot easier to fit a mechanical vario than it
is to fit a complete second electrical system?
Ian "All mechanical cockpit" J
Old July 16th 08, 10:54 PM posted to rec.aviation.soaring
Bruce
Hi Ian
Lightning is best avoided. But in the event it is not avoidable, my limited experience is that a strike that is near
enough to knock out a GPS has no effect on a Tasman vario. Presume this is because of the aerial on the GPS.
My guess would be that - If you get hit hard enough to knock out your electronic varios you will probably not be
particularly worried about thermalling.
Bruce
Old July 16th 08, 10:55 PM posted to rec.aviation.soaring
kirk.stant
I'm totally in the "all electric" camp. Tossed my mechanical 8 years
ago, replaced with a nice Ilec electric backup (with audio), and
haven't had a problem since. Primary is an SN10. Both agree all the
time.
And 2 electrical systems are only slightly more work than one, if done
at the same time.
Given more funds, I would replace the Ilec with something that has
electronic TE, so that losing the probe wouldn't fail both varios - my
current single point of failure...
Mechanical varios belong with barographs - on the shelf behind the
club bar. Especially on club ships, where good varios with audio are
really needed, yet rare (at least in the US).
Cheers,
Kirk
66
Sage Varios-Williams Soaring Tom Hubbard Soaring 0 April 2nd 07 07:12 PM
How about this for computing power in your glider cockpit Gary Emerson Soaring 9 May 17th 06 08:56 PM
What camera for pictures from a glider cockpit? Eric Greenwell Soaring 34 December 10th 05 06:19 AM
Opinions on Varios Bruce Soaring 8 March 1st 05 03:57 PM
Super Varios John Scott Soaring 1 February 25th 05 02:14 AM
