On Jul 20, 1:22 pm, Reggie wrote:
On Jul 20, 9:04 am, " wrote: VW Engine Wear Factors The exhaust valves are the weak link in any air cooled Otto Cycle engine using poppet valves. ************************************************* ********** Is there a larger diam stem, Porsche, valve, spring, keeper,guide assy that could be placed in the VW head ??? Or even hot rod "kiddie" (after market) stuff ...... Reggie The Fuel Injected 1600 cc engines (Type I) produced after 1975 had larger valve stems, 9mm vice the 8mm used up to that point. The valve itself, however, was smaller, which reduced the valve seat area, which governs heat transfer from the valve to the head. In other words, the smalled seats in theory offset the benefit of the larger stems. It's not clear that this combination gave any longer valve life, and these heads and valves, while allegedly available, are pretty rare. I have no personal experience with them. Veeduber has discussed in his blog using ceramic coatings to increase exhaust valve life. Lots of potential there. I'm building an engine with coated pistons and valves but it hasn't even run yet, let alone flown, let alone proven itself with hundreds of flight hours. |
Standards for H.P. corr. factors ?? | Jerry Wass | Home Built | 25 | July 8th 07 01:36 AM |
Human factors RECKLESSNESS | private | Aerobatics | 60 | May 10th 05 05:52 AM |
Human factors RECKLESSNESS | private | Piloting | 68 | May 10th 05 05:52 AM |
Human factors RECKLESSNESS | private | Soaring | 72 | May 10th 05 05:52 AM |
Strike Fighter Squadron OPTEMPO factors | [email protected] | Naval Aviation | 4 | March 3rd 05 12:14 PM |
