![]() "Chad Irby" wrote (Tony Williams) wrote: We know the Mauser works, too - it's been in service in large numbers for two decades. The initial assessments by the JSF team concluded that the Mauser was the most cost-effective choice, and they knew all about the GAU-12/U then. Part of that "cost effectiveness" appeared to be a lowball pricing structure that fell through on closer examination. Here's the prospective from a contractor's point of view: non-incumbents bidding into a new requirement have the advantage of the valor of ignorance. Because the contract is cost plus, in the absence of experience, a new bidder can make bidding assumptions that erm turn out to be different from reality. The_incumbent_has to know more about the real costs and as a result, often bids a higher price. Bidding to fixed price is different. A contractor's management with make sure the bid price is high enough that they_will_make money. Then there are disasters like BAE's Nimrod rebuild which scar a generation of managers (the ones that don't get taken out back and shot). I suspect that BAE will not bid a fixed price contract again for twenty years. |
Chad Irby wrote in message . com...
In article , (Tony Williams) wrote: We know the Mauser works, too - it's been in service in large numbers for two decades. The initial assessments by the JSF team concluded that the Mauser was the most cost-effective choice, and they knew all about the GAU-12/U then. Part of that "cost effectiveness" appeared to be a lowball pricing structure that fell through on closer examination. Do you have a source to support that? You may be right, but I like to work on hard info rather than forum gossip. Tony Williams Military gun and ammunition website: http://www.quarry.nildram.co.uk Discussion forum at: http://forums.delphiforums.com/autogun/messages/ |
Chad Irby wrote in message m...
(Tony Williams) wrote: Chad Irby wrote: Part of that "cost effectiveness" appeared to be a lowball pricing structure that fell through on closer examination. Do you have a source to support that? You may be right, but I like to work on hard info rather than forum gossip. This talks about the cost issue: http://stage.defensedaily.com/VIP/ddi/previous/ddi0927.htm#A1 "We had a cost-growth problem that forced a recompetition," he said. "Affordability is a prime concern of the program. Based on that we were forced to recompete the gun system integration. We selected our supplier on a best-value case." Thanks for that link. I had to smile at: "GD had initially offered its GAU-12 25mm gatling cannon for the JSF in July 1999, but withdrew its proposal in February 2000." since that was only after L-M had selected the BK 27 - in the UK, we call that 'spin' ![]() A "cost-growth problem" for an established weapon like the Mauser means "they tried to stick us for some more cash after they got the contract." The usual response in that case is to tell the supplier to keep the price down or lose the contract. With a potentially huge market for the F-35, Mauser would have to have been mad to throw it away. There is no inherent reason that I am aware of that the BK 27 should have been more expensive to make than the GAU-12/U, particularly since both would have been made in the USA (unless they're planning to save money on the initial batch by re-using guns from the AV8-B). I remain suspicious that GD was both the gun integrator and the supplier of the GAU-12/U; they weren't exactly innocent bystanders. Tony Williams Military gun and ammunition website: http://www.quarry.nildram.co.uk Discussion forum at: http://forums.delphiforums.com/autogun/messages/ |
![]() "Tony Williams" wrote in message m... Chad Irby wrote in message m... (Tony Williams) wrote: Chad Irby wrote: Part of that "cost effectiveness" appeared to be a lowball pricing structure that fell through on closer examination. Do you have a source to support that? You may be right, but I like to work on hard info rather than forum gossip. This talks about the cost issue: http://stage.defensedaily.com/VIP/ddi/previous/ddi0927.htm#A1 "We had a cost-growth problem that forced a recompetition," he said. "Affordability is a prime concern of the program. Based on that we were forced to recompete the gun system integration. We selected our supplier on a best-value case." Thanks for that link. I had to smile at: "GD had initially offered its GAU-12 25mm gatling cannon for the JSF in July 1999, but withdrew its proposal in February 2000." since that was only after L-M had selected the BK 27 - in the UK, we call that 'spin' ![]() A "cost-growth problem" for an established weapon like the Mauser means "they tried to stick us for some more cash after they got the contract." The usual response in that case is to tell the supplier to keep the price down or lose the contract. With a potentially huge market for the F-35, Mauser would have to have been mad to throw it away. There is no inherent reason that I am aware of that the BK 27 should have been more expensive to make than the GAU-12/U, particularly since both would have been made in the USA (unless they're planning to save money on the initial batch by re-using guns from the AV8-B). I remain suspicious that GD was both the gun integrator and the supplier of the GAU-12/U; they weren't exactly innocent bystanders. Do you remember the American production of Roland? Each and every drawing had to be reproduced with SAE equivalents of all the metric dimensions. That kind of "Americanization" ran the price up to the point that the AF choked. |
"Paul F Austin" wrote in message . ..
"Tony Williams" wrote in message m... Chad Irby wrote in message m... (Tony Williams) wrote: Chad Irby wrote: Part of that "cost effectiveness" appeared to be a lowball pricing structure that fell through on closer examination. Do you have a source to support that? You may be right, but I like to work on hard info rather than forum gossip. This talks about the cost issue: http://stage.defensedaily.com/VIP/ddi/previous/ddi0927.htm#A1 "We had a cost-growth problem that forced a recompetition," he said. "Affordability is a prime concern of the program. Based on that we were forced to recompete the gun system integration. We selected our supplier on a best-value case." Thanks for that link. I had to smile at: "GD had initially offered its GAU-12 25mm gatling cannon for the JSF in July 1999, but withdrew its proposal in February 2000." since that was only after L-M had selected the BK 27 - in the UK, we call that 'spin' ![]() A "cost-growth problem" for an established weapon like the Mauser means "they tried to stick us for some more cash after they got the contract." The usual response in that case is to tell the supplier to keep the price down or lose the contract. With a potentially huge market for the F-35, Mauser would have to have been mad to throw it away. There is no inherent reason that I am aware of that the BK 27 should have been more expensive to make than the GAU-12/U, particularly since both would have been made in the USA (unless they're planning to save money on the initial batch by re-using guns from the AV8-B). I remain suspicious that GD was both the gun integrator and the supplier of the GAU-12/U; they weren't exactly innocent bystanders. Do you remember the American production of Roland? Each and every drawing had to be reproduced with SAE equivalents of all the metric dimensions. That kind of "Americanization" ran the price up to the point that the AF choked. Yes, something like that is what I assumed in the first place. Tony Williams Military gun and ammunition website: http://www.quarry.nildram.co.uk Discussion forum at: http://forums.delphiforums.com/autogun/messages/ |
AIM-54 Phoenix missile | Sujay Vijayendra | Military Aviation | 89 | November 3rd 03 09:47 PM |
P-39's, zeros, etc. | old hoodoo | Military Aviation | 12 | July 23rd 03 05:48 AM |
