![]() "Kevin Brooks" wrote in message .. . "Paul F Austin" wrote in message ... "Kevin Brooks" wrote "Paul F Austin" wrote "Chad Irby" wrote "Paul F Austin" wrote: Now, here's a question: for the 200Kg or so weight budget (I have no idea about volume) of an internal gun and ammo tank, would you rather have 1, 2 or 3 more AIM-9Xs/ASRAAMs? It's not a question of "just weight," or we'd just build C-5s with a big automated missile launcher in them. Nope, I just used weight as an example of the "cost" paid for a gun. And my question stands: At the initial design stage of an aircraft when you're making choices, is a gun worth more than a couple of SRAAMs? Or some of the other goods that you snipped. Those are real choices and a gun has to earn its place on the airframe just like every other piece of gear. You (the customer and systems designers) make choices that affect the aircraft thoughout its life. Yes, the "no-guns" fighter was 'way premature in 1955, the year the F4H configuration was frozen. It's_really_not clear that's still the case now. Minimum range engagement? ASRAAM claim 300m minimum range and with "looks can kill" helmet sights, it's really not clear that a gun brings much to the table.. Strafing? Having 6 SDBs tucked away seems more useful. Minimum safe distance (to friendly troops) for surface targets using the 20mm is 25 meters (according to a USAF chart included in the 1996 edition of CGSC ST 100-3). The same chart indicates minimum distance for bombs under 500 pounds is 145 meters (for protected friendlies, ie., bunkers, trenches, fighting positions) or 500 meters (if friendlies are in the open). Even given a significant reduction in the latter figures for the smaller SDB, it is going to be substantially more than 25 meters. So what do you use to engage bad guys located in the 25 meter to something-under-500 meter gap if you have no gun? This is not a purely hypothetical--it happened during Anaconda. That's a good point and one I can't answer. If it was me though, I'd expect that the answer would lie with more organic fires available at the battalion level rather than depending on CAS for "men in the wire". There is not a soldier around who would disagree with your objective, since groundpounders generally prefer having "their own" support completely in-pocket. But that does not change the fact that there will be situations, like during Anaconda, where the organic support assets are either not available (i.e., no arty tubes were within range) or unable to handle the scope of the mission (i.e., the mortars that the Anaconda troops did have were over-tasked due to the unexpected number of concurrent targets, and ammo resupply was problematic being fully dependent upon helos in what had already become a less-than-helo-friendly environment). That is where the internal gun on the CAS aircraft becomes a means for the commander to remain flexible in how he responds to these "knife fight" situations. If there's enough of a requirement for gun support in CAS to justify guns across the fighter fleet, there's an alternative requirement for a dedicated gun/CAS platform that can live in opposed airspace. We're also splitting into the a cannon with a_very_large tank of ammo to address the many, many soft hostiles application and the few, hard targets that require something like a 30x173. Remember that some of the gun/aircraft combinations discussed on this thread only carried 150 rounds or so. You won't make too many passes with that. |
"Paul F Austin" wrote: If there's enough of a requirement for gun support in CAS to justify guns across the fighter fleet, there's an alternative requirement for a dedicated gun/CAS platform that can live in opposed airspace. But that's going opposite of the trend towards *less* types of airframes. That's why we've only got two near-future fighters in the US (long range fighter/attack and short-range fighter/attack), and why the Europeans are trying to go with *one* plane to do all jobs. We're having enough trouble getting the USAF to keep Warthogs, and those have been proven bloody useful every time they've come into play. -- cirby at cfl.rr.com Remember: Objects in rearview mirror may be hallucinations. Slam on brakes accordingly. |
![]() But that's going opposite of the trend towards *less* types of airframes. That's why we've only got two near-future fighters in the US (long range fighter/attack and short-range fighter/attack), and why the Europeans are trying to go with *one* plane to do all jobs. The navy is going even further, to the point where it only plans on having F-18E/Fs and SH-60s on board carriers. Ron Pilot/Wildland Firefighter |
![]() "Paul F Austin" wrote in message ... "Kevin Brooks" wrote in message .. . "Paul F Austin" wrote in message ... "Kevin Brooks" wrote "Paul F Austin" wrote "Chad Irby" wrote "Paul F Austin" wrote: Now, here's a question: for the 200Kg or so weight budget (I have no idea about volume) of an internal gun and ammo tank, would you rather have 1, 2 or 3 more AIM-9Xs/ASRAAMs? It's not a question of "just weight," or we'd just build C-5s with a big automated missile launcher in them. Nope, I just used weight as an example of the "cost" paid for a gun. And my question stands: At the initial design stage of an aircraft when you're making choices, is a gun worth more than a couple of SRAAMs? Or some of the other goods that you snipped. Those are real choices and a gun has to earn its place on the airframe just like every other piece of gear. You (the customer and systems designers) make choices that affect the aircraft thoughout its life. Yes, the "no-guns" fighter was 'way premature in 1955, the year the F4H configuration was frozen. It's_really_not clear that's still the case now. Minimum range engagement? ASRAAM claim 300m minimum range and with "looks can kill" helmet sights, it's really not clear that a gun brings much to the table.. Strafing? Having 6 SDBs tucked away seems more useful. Minimum safe distance (to friendly troops) for surface targets using the 20mm is 25 meters (according to a USAF chart included in the 1996 edition of CGSC ST 100-3). The same chart indicates minimum distance for bombs under 500 pounds is 145 meters (for protected friendlies, ie., bunkers, trenches, fighting positions) or 500 meters (if friendlies are in the open). Even given a significant reduction in the latter figures for the smaller SDB, it is going to be substantially more than 25 meters. So what do you use to engage bad guys located in the 25 meter to something-under-500 meter gap if you have no gun? This is not a purely hypothetical--it happened during Anaconda. That's a good point and one I can't answer. If it was me though, I'd expect that the answer would lie with more organic fires available at the battalion level rather than depending on CAS for "men in the wire". There is not a soldier around who would disagree with your objective, since groundpounders generally prefer having "their own" support completely in-pocket. But that does not change the fact that there will be situations, like during Anaconda, where the organic support assets are either not available (i.e., no arty tubes were within range) or unable to handle the scope of the mission (i.e., the mortars that the Anaconda troops did have were over-tasked due to the unexpected number of concurrent targets, and ammo resupply was problematic being fully dependent upon helos in what had already become a less-than-helo-friendly environment). That is where the internal gun on the CAS aircraft becomes a means for the commander to remain flexible in how he responds to these "knife fight" situations. If there's enough of a requirement for gun support in CAS to justify guns across the fighter fleet, If you had not noticed, CAS is flown by aircraft "across the fighter fleet", so yes, that gun requirement would be universal. there's an alternative requirement for a dedicated gun/CAS platform that can live in opposed airspace. You are having difficulty with the concept of preserving an admittedly less likely to be used capability (nobody in their right mind is going to argue that the gun strafe attack should be a primary role for fast mover type CAS assets) in order to maintain maximum flexibility and maximize the ability to support the ground force under all conditions as opposed to the "guns are the primary asset" alternative. The latter is unwise, and I have not seen anyone claim the gun should be the primary CAS weapon for fast movers. We're also splitting into the a cannon with a_very_large tank of ammo to address the many, many soft hostiles application and the few, hard targets that require something like a 30x173. Remember that some of the gun/aircraft combinations discussed on this thread only carried 150 rounds or so. You won't make too many passes with that. A few passes when the ground guys' butts are in the crack is a heck of a lot better than no passes at all. And the primary use of the gun in these kind of strafe attacks is *suppression* of the opposing crunchies and their light CSW's that are too close to engage with other more destructive weapons, so the 20mm and 25mm are not going to be significantly worse performers than your 30mm. Brooks |
AIM-54 Phoenix missile | Sujay Vijayendra | Military Aviation | 89 | November 3rd 03 09:47 PM |
P-39's, zeros, etc. | old hoodoo | Military Aviation | 12 | July 23rd 03 05:48 AM |
