The EW Microrecorder doesn't have a hard drive.
Mike Schumann "Edward Lockhart" wrote in message ... At 14:45 27 July 2008, nimbus wrote: I have the new model (bought in January 2008). I did remove the "battery" cap. I found an assembly of 3 metal ion sub batteries. These batteries are made by GBS in UK. I contacted them in order to have spare batteries. I hope that opening the battery cap will not make my flights invalid. I am a little disappointed about the weakness of this battery assembly (only after 6 months, I got already problems !). Bruno I had a similar problem with my EW Microrecorder a few months ago - in my case the hard drive was frozen. Let the battery run flat (24 hours) and when you recharge, the recorder resets. As yours is one of the newer models, you can also reset the unit by shorting two of the pins in the RJ45 connector. Sounds drastic but it is a design feature on the newer units. You'll have to ask Graham which pins. Hope this helps, Edward ** Posted from http://www.teranews.com ** |
Digital airspace data question -- any FAA data gurus out there? | Tuno | Piloting | 2 | December 27th 07 05:06 PM |
Flight Data recorders on a 757 - What data? | Al Dykes | General Aviation | 0 | January 1st 07 05:09 PM |
Ted, your LX logger......... | [email protected] | Soaring | 6 | June 26th 06 04:21 PM |
Cambridge 302 -or- Borgelt B50 plus data logger | Romeo Delta | Soaring | 25 | May 30th 04 09:50 AM |
Colibri Data Logger reviewed | TOM RENT | Soaring | 18 | April 16th 04 10:47 PM |
