#101
On Jul 3, 8:19 am, BradGuth wrote:
On Jun 30, 7:19 pm, BradGuth wrote: On Jun 30, 6:58 am, "Hagar" wrote: "BradGuth" wrote in message ... On Jun 18, 3:32 pm, wrote: On Jun 17, 10:13 pm, BradGuth wrote: snip drivel Sorry I'd missed this reply of yours. All that I'm saying is that a sufficient composite rigid airship can be created for at least robotics to stay aloft for months and even years while cruising efficiently below them acidic clouds of Venus. Yearning for those good old Horse and Buggy days, Bradwurst ?? As long as those are not Zionist/Nazi horse and buggy days, why the hell not. Just wondering, what's horse and buggy about a composite rigid airship as intended for the planet Venus? Isn't this just another topic diversion tactic of yours? But then, isn't this exactly what being a brown-nosed minion/clown for the Zionist Third Reich is all about? - Brad Guth Brad_Guth Brad.Guth BradGuth For such a downright nifty R&D topic, seems a touch odd that our all- knowing public servants of DARPA haven't been into helping out. What the hell is it about Venus that's so unusually dark and scary? - Brad Guth Brad_Guth Brad.Guth BradGuth Notice how the DARPA resident rabbi is into topic/author stalking and trying to continually trash this topic. - BG |
#103
Unlike doing Mars or most any other planet or moon, at least my
composite rigid airships of Venus are perfectly doable, and even humanly survivable as floating cities. The POOF City outpost or Oasis/gateway at Venus L2 is also technically doable. The surface of Venus itself is also withinn our technological expertise, and there's certainly no shortage of local energy or mineral resources. Our frail DNA would also be fully protected from solar and cosmic radiation while cruising about under those thick and robust clouds. Getting safely to/from Venus is relatively easy and thus affordable, as compared to most other off-world alternatives (including easier than our pesky Selene/moon). - Brad Guth Brad_Guth Brad.Guth BradGuth On Jun 12, 5:19 am, BradGuth wrote: If robotics simply isn’t offering sufficient exploration risk or otherwise DARPA/NASA spendy enough, there’s always a fully manned mission of the very least 100 fold more spendy, plus their having to navigate well above the hot geothermal surface of Venus for roughly 18 months before eventually upward exiting and returning to Earth. The AI/robotic consideration would not only cost at least 100 fold less than any manned mission, but it also doesn’t have to ever return to Earth, and thereby could stay on its mission throughout several 19 month cycles, as well as multiple surface landings becomes technically doable without risk of harming a single strand of human DNA. So therefore, a robotic rigid-airship is actually a good thousand fold cheaper than any kind of manned mission (perhaps even if POOF City were set up at Venus L2 would likely still be 100 fold less spendy). The Venus environment at one of the likely rigid-airship cruising altitudes of 25 km is only a bit 500K (440F) toasty warm by season of day, and otherwise somewhat considerably cooler by season of night, perhaps drawn down to as low as 400K (260F). The closer you get to that geothermally hot surface the less day/night thermal differential you’ve got to work with. Increasing the operational altitude to 35 km by season of nighttime is almost humanly tolerable, although you’re also getting into that lower acidic cloud haze. Much above 35 km by season of nighttime you may need to consider navigating by radar, as well as remain submarine like fully enclosed within the rigid composite airship. By season of day should allow cruising as high as 45 km, although there too is that pesky acidic cloud haze to deal with. - Brad Guth Brad_Guth Brad.Guth BradGuth On May 4, 1:31 pm, BradGuth wrote: Being a little hot, buoyant and having 10% less gravity is actually a darn good thing if you were a Venusian airship, even if limited as to an oven-wrap or KetaSpire PEEK polyetheretherketone and fiber reinforced balloon. Such fiber reinforced composites do exist, although an outer skin of something in basic titanium shouldn’t be excluded for this rigid airship configuration. For this topic I have this unusual airship to R&D, as intended for a rather toasty dry and calm environment. Think of this application as a floating city if you like, or consider this one as merely a small or as large as need be robotic probe that can remain efficiently aloft for nearly unlimited time without much energy demand while drifting or even when cruising along at perhaps an average air-speed of less than 10 m/s, as such wouldn’t demand but a few kw for managing a good sized airship. Taking into account the 1.75 kg/m3 by day and perhaps 2.5 kg/m3 of nighttime buoyancy at 50 km is roughly worth twice that of any terrestrial airship application, and for the most part it’s actually fairly calm, kind of inert nice enough and even relatively cool because it’s at such a good deal of altitude away from that geothermal radiating planet, and otherwise operating within the nighttime season, and still situated well enough below the bulk of those otherwise thick and nasty acidic clouds. Because the inert infrastructure of this rigid airship doesn’t change per given altitude means that its hauling capacity or payload is capable of becoming downright impressive, getting much better as one operates at lower altitudes, such as below 35 km by season of day and below 25 km by season of nighttime is where that robust S8/CO2 atmosphere is nearly crystal dry and otherwise clear for as far as you can see (depending on terrain, roughly 500 km in all directions). Initially, this is a very rigid composite and robust kind of mostly robotic airship, intended as an extended expedition probe. It’s somewhat of a conventional blimp like craft, except using a rigid composite hull with a 6:1 L/W ratio instead of the more common terrestrial 5:1. In my way of thinking, it has a rather thick outer composite hull that’s nicely insulative (critical science instrument/components area being insulated by R-100 or better) as obviously acidic proof, not to mention melt proof, not that its failsafe hydrogen gas displacement or that of its vacuum worth of artificial buoyancy need be all that acid proof or even having to be excessively cooled, because the bulk of this airship can be rated for 811 K (1000°F). There are four rather over-sized longitudinal stabilizer fins, used for obvious flight stability, but also utilized for their heat- exchanging functions, and otherwise a pair of midship underbelly landing skids (just in case). Its configuration might incorporate one fully ducted set of large diameter counter-rotating pusher fans, plus four other fully rotatable thrusters (two on either forward/aft side for a total boost of 10% main engine thrust), that collectively can also be utilized as forward/ reverse motion thrusters. The maximum velocity potential of 100 m/s need not be necessary, and certainly not one of those all or nothing considerations, because 10 m/s is more than good enough unless striving to migrate though those acidic clouds in order to cruise essentially above the 75 km nighttime worth of those fast moving clouds (80~85 km by day) . This craft is not going to be your average Hindenburg, much less flammable or otherwise combustible, although intended for efficiently cruising about Venus where size and mass are of little concern when having 64+ kg/m3 worth of buoyancy, and only 90.5% gravity to work with is certainly going to avoid all sorts of inert mass considerations that would have more than grounded the Hindenburg. In addition to certain liquid fuels that can be safely incorporated, there will be a pair of custom RTGs running at more than hot enough to melt aluminum, and a likely Stirling thermal dynamic process of utilizing that heat at roughly 25+% efficiency for all of the onboard systems and main propulsion. Getting rid of 75% worth of RTG heat shouldn’t be all that insurmountable, especially with such a thermally conductive flow of that toasty Venusian atmosphere flowing past, as worthy of roughly 10% the density of water, in that the closer we cruise to the geothermally active surface the more dense and thermally conductive becomes the surrounding S8 and CO2 atmosphere. Once again, on behalf of Usenet/Group diehard naysayers, this topic is not about our having to terraform Venus, or that of our having to prance ourselves about in the buff, at least not without our trusty OveGlove jumpsuit and portable CO2--co/o2 plus heat-exchanging unit. Instead, we’re talking mostly about a fully robotic craft that really doesn’t care how hot and nasty it is outside, and may never have to land for the next hundred years, with a future human flight configured version that’s clearly scaled in sufficient volume in order to suit the applications of sustaining human our frail life for extended periods of time while cruising extensively at or below 25 km. Even though Geoffrey Landis wisely publishes most everything of his expertise as science fiction, it’s based entirely upon the regular laws of physics, and for the most part using the best available science. This doesn’t mean that I’d worship each and every published word of Landis or from others of his kind, although it does fully demonstrate that I’m not the one and only wise enough individual that’s deductively thinking constructively and thus positively about accomplishing those Venus expeditions. Venus exploration papers / Geoffrey A. Landis http://www.sff.net/people/geoffrey.landis/papers.html Evaluation of Long Duration Flight on Venus / by Anthony J. Colozza and Geoffrey A. Landis http://gltrs.grc.nasa.gov/reports/20...006-214452.pdf This paper was for the most part generated long after my having insisted that such a mission via aircraft/airship was technically doable, although this Geoffrey and Anthony version focused mostly on behalf of solar powered and RTG as necessary, whereas such there’s nothing much innovative or all that ground breaking to report, especially since much of their airship application is operated within a terrestrial like environment by way of keeping good altitude. This is not saying that my ideas are of the one and only do-or-die alternatives, as I’m not the least bit opposed to incorporating viable alternatives, or having to share most of the credits with those having contributed their honest expertise. In other words, I’m not the bad guy here, nor am I interested in hearing from those having ulterior motives or counter intentions of merely topic/author stalking and bashing for all the grief they can muster. . – Brad Guth Notice how the DARPA mainstream status quo doesn't like this topic. Sending in their brown-nosed goons and clowns in order to topic/author stalk and trash is their typical faith-based form of a damage-control tactic. Intellectual cartel bigotry and racism via their pretend- Atheism is their second hidden card they like to play. If their Hitler were alive, he'd be grinning from ear to ear. - Brad Guth Brad_Guth Brad.Guth BradGuth |
#104
That's extremely odd, when the all-knowing gods and wise old wizards
of these DARPA saturated Usenet/newsgroups have become so unusually dead quiet on any topic the least bit related to Venus. Of course that's only because of what I'd uncovered that even a 5th grader should have figured out as of 8+ years ago, if not a whole lot before then. - Brad Guth Brad_Guth Brad.Guth BradGuth On Jun 12, 5:19 am, BradGuth wrote: If rigged airship robotics isn’t offering sufficient exploration risk or otherwise DARPA/NASA spendy enough, there’s always a fully manned mission of the very least 100 fold more spendy, plus their having to navigate well above the hot geothermal surface of Venus for roughly 18 months before eventually upward exiting and returning to Earth. The AI/robotic consideration would not only cost at least 100 fold less than any manned mission, but it also doesn’t have to ever return to Earth, and thereby could stay on its mission throughout several 19 month cycles, as well as multiple surface landings becomes technically doable without risk of harming a single strand of human DNA. So therefore, a robotic rigid-airship is actually a good thousand fold cheaper than any kind of manned mission (perhaps even if POOF City were set up atVenusL2 would likely still be 100 fold less spendy). The Venus environment at one of the likely rigid-airship cruising altitudes of 25 km is only a bit 500K (440F) toasty warm by season of day, and otherwise somewhat considerably cooler by season of night, perhaps in places of negative draft getting drawn down to as low as 400K (260F). The closer you get to that geothermally hot surface the less day/night thermal differential you’ve got to work with. Increasing upon the operational altitude to 35 km by season of nighttime is almost humanly tolerable, although you’re also getting into that lower acidic cloud haze. Much above 35 km by season of nighttime you may need to consider navigating by radar, as well as remain submarine like fully enclosed within the rigid composite airship. By season of day should allow cruising as high as 45 km, although there too is that pesky acidic/S8 cloud haze to deal with. - BradGuthBrad_Guth Brad.GuthBradGuth On May 4, 1:31 pm, BradGuth wrote: Being a little hot, buoyant and having 10% less gravity is actually a darn good thing if you were a Venusian airship, even if limited as to an oven-wrap or KetaSpire PEEK polyether etherketone and fiber reinforced balloon. Such fiber reinforced composites do exist, although an outer skin of something in basic titanium shouldn’t be excluded for this rigid airship configuration. For this topic I have this unusual airship to R&D, as intended for a rather toasty dry and calm environment. Think of this application as a floating city if you like, or consider this one as merely a small or as large as need be robotic probe that can remain efficiently aloft for nearly unlimited time without much energy demand while drifting or even when cruising along at perhaps an average air-speed of less than 10 m/s, as such wouldn’t demand but a few KW for managing a good sized robotic managed rigid airship. Taking into account the 1.75 kg/m3 by day and perhaps 2.5 kg/m3 of nighttime buoyancy at 50 km is roughly worth twice that of any terrestrial airship application, and for the most part it’s actually fairly calm, kind of dry inert and nice enough and even relatively cool because it’s at such a good deal of altitude away from that geothermal radiating planet, and otherwise operating within the nighttime season, and still situated well enough below the bulk of those otherwise thick and perfectly nasty acidic clouds. Because the inert infrastructure of this rigid airship doesn’t change per given altitude means that its hauling capacity or usable payload is capable of becoming downright impressive, getting much better as one operates at lower altitudes, such as below 35 km by season of day and below 25 km by season of nighttime is where that robust S8/CO2 atmosphere is nearly crystal dry and otherwise clear for as far as you can see (depending on terrain, roughly 500 km in all directions). Initially, this is a very rigid composite and robust kind of mostly robotic airship, intended as an extended expedition probe. It’s somewhat of a conventional blimp like craft, except using a rigid composite hull with a 6:1 L/W ratio instead of the more common terrestrial 5:1. In my way of thinking, this has a rather thick outer composite hull that’s nicely insulative (critical science instrument/components area being insulated by R-128 or better) as obviously acidic proof, not to mention melt proof, not that its failsafe hydrogen gas displacement or that of its vacuum worth of artificial buoyancy need be all that acid proof or even having to be excessively cooled, because the bulk of this airship can be rated for 811 K (1000°F). There are four rather over-sized longitudinal stabilizer fins, used for obvious flight stability, but also utilized for their heat- exchanging functions, and otherwise a pair of midship underbelly landing skids (just in case). Its configuration might incorporate one fully ducted set of large diameter counter-rotating pusher fans, plus four other fully rotatable thrusters (two on either forward/aft side for a total boost of 10% main engine thrust), that collectively can also be utilized as forward/ reverse motion thrusters. The maximum velocity potential of 100 m/s need not be necessary, and certainly not one of those all or nothing considerations, because 10 m/s is more than good enough unless striving to migrate though those acidic clouds in order to cruise essentially above the 75 km nighttime worth of those fast moving clouds (solar elevated to 80~85 km by day) . This craft is not going to be your average Hindenburg, much less flammable or otherwise combustible, although intended for efficiently cruising about Venus where size and mass are of little concern when having 64+ kg/m3 worth of buoyancy, and only 90.5% gravity to work with is certainly going to avoid all sorts of various inert mass related considerations that would have more than grounded the Hindenburg. In addition to certain liquid fuels that can be safely incorporated, there will be a pair of custom RTGs running at more than hot enough to melt aluminum, and a likely Stirling thermal dynamic added process of utilizing that heat at roughly 25+% efficiency for all of the onboard systems and main propulsion. Getting rid of 75% worth of RTG heat shouldn’t be all that insurmountable, especially with such a thermally conductive flow of that toasty Venusian atmosphere flowing past, as worthy of roughly 10% the density of water, in that the closer we cruise above that geothermally active surface the more dense and thermally conductive becomes the surrounding S8 and CO2 atmosphere. Once again, on behalf of Usenet/Group diehard naysayers, this topic is not about our having to terraform Venus, or that of our having to prance ourselves about in the buff, at least not without our trusty OveGlove jumpsuit and portable CO2--co/o2 plus heat-exchanging unit. Instead, we’re talking mostly about a fully robotic craft that really doesn’t care how hot and nasty it is outside, and may never have to land for the next hundred years, with a future human flight configured version that’s clearly scaled in sufficient volume in order to suit the applications of sustaining human our frail life for extended periods of time while cruising extensively at or below 25 km. Even though Geoffrey Landis wisely publishes most everything of his expertise as science fiction, it’s based entirely upon the regular laws of physics, and for the most part using the best available science. This doesn’t mean that I’d worship each and every published word of Landis or from others of his kind, although it does fully demonstrate that I’m not the one and only wise enough individual that’s deductively thinking constructively and thus positively about accomplishing those Venus expeditions. Venus exploration papers / Geoffrey A. Landis http://www.sff.net/people/geoffrey.landis/papers.html Evaluation of Long Duration Flight on Venus/ by Anthony J. Colozza and Geoffrey A. Landis http://gltrs.grc.nasa.gov/reports/20...006-214452.pdf This paper was for the most part generated long after my having insisted that such a mission via aircraft/airship was technically doable, although this Geoffrey and Anthony version focused mostly on behalf of solar powered and RTG as necessary, whereas such there’s nothing much innovative or all that ground breaking to report, especially since much of their airship application is operated within a terrestrial like environment by way of keeping good altitude. This is not saying that my ideas are of the one and only do-or-die alternatives, as I’m not the least bit opposed to incorporating viable alternatives, or having to share most of the credits with those having contributed their honest expertise. In other words, I’m not the bad guy here, nor am I interested in hearing from those having ulterior motives or counter intentions of merely topic/author stalking and bashing for all the grief they can muster. If other intelligent life existing/coexisting on Venus is too much for your pathetic, snookered and dumbfounded brain to fathom, then don’t bother with most other reality issues because, you’ll only get those annoying headaches once realizing how your government and of its faith- basted Zionist/Nazi puppet masters have been screwing you and most everyone else over for decades. - Brad Guth Brad_Guth Brad.Guth BradGuth |
#105
Still not one soul of rigid airship expertise to behold, or that of
any applied technology on behalf of robotics or us frail humans accomplishing any such extended Venus mission of 19.5 months (plus their return commute should push this one well past 24 months, but not likely more than 36 months). Is this DARPA Usenet/newsgroup snookered and dumbfounded itself past the point of no return, or what? (most likely afraid of their own shadow, plus whatever those pesky MIB might have to offer) - Brad Guth Brad_Guth Brad.Guth BradGuth On Jul 20, 4:06 pm, BradGuth wrote: That's extremely odd, when the all-knowing gods and wise old wizards of these DARPA saturated Usenet/newsgroups have become so unusually dead quiet on any topic the least bit related toVenus. Of course that's only because of what I'd uncovered that even a 5th grader should have figured out as of 8+ years ago, if not a whole lot before then. - BradGuthBrad_Guth Brad.GuthBradGuth On Jun 12, 5:19 am, BradGuth wrote: If rigged airship robotics isn’t offering sufficient exploration risk or otherwise DARPA/NASA spendy enough, there’s always a fully manned mission of the very least 100 fold more spendy, plus their having to navigate well above the hot geothermal surface ofVenusfor roughly 18 months before eventually upward exiting and returning to Earth. The AI/robotic consideration would not only cost at least 100 fold less than any manned mission, but it also doesn’t have to ever return to Earth, and thereby could stay on its mission throughout several 19 month cycles, as well as multiple surface landings becomes technically doable without risk of harming a single strand of human DNA. So therefore, a robotic rigid-airship is actually a good thousand fold cheaper than any kind of manned mission (perhaps even if POOF City were set up atVenusL2 would likely still be 100 fold less spendy). TheVenusenvironment at one of the likely rigid-airship cruising altitudes of 25 km is only a bit 500K (440F) toasty warm by season of day, and otherwise somewhat considerably cooler by season of night, perhaps in places of negative draft getting drawn down to as low as 400K (260F). The closer you get to that geothermally hot surface the less day/night thermal differential you’ve got to work with. Increasing upon the operational altitude to 35 km by season of nighttime is almost humanly tolerable, although you’re also getting into that lower acidic cloud haze. Much above 35 km by season of nighttime you may need to consider navigating by radar, as well as remain submarine like fully enclosed within the rigid composite airship. By season of day should allow cruising as high as 45 km, although there too is that pesky acidic/S8 cloud haze to deal with. - BradGuthBrad_Guth Brad.GuthBradGuth On May 4, 1:31 pm, BradGuth wrote: Being a little hot, buoyant and having 10% less gravity is actually a darn good thing if you were a Venusian airship, even if limited as to an oven-wrap or KetaSpire PEEK polyether etherketone and fiber reinforced balloon. Such fiber reinforced composites do exist, although an outer skin of something in basic titanium shouldn’t be excluded for this rigid airship configuration. For this topic I have this unusual airship to R&D, as intended for a rather toasty dry and calm environment. Think of this application as a floating city if you like, or consider this one as merely a small or as large as need be robotic probe that can remain efficiently aloft for nearly unlimited time without much energy demand while drifting or even when cruising along at perhaps an average air-speed of less than 10 m/s, as such wouldn’t demand but a few KW for managing a good sized robotic managed rigid airship. Taking into account the 1.75 kg/m3 by day and perhaps 2.5 kg/m3 of nighttime buoyancy at 50 km is roughly worth twice that of any terrestrial airship application, and for the most part it’s actually fairly calm, kind of dry inert and nice enough and even relatively cool because it’s at such a good deal of altitude away from that geothermal radiating planet, and otherwise operating within the nighttime season, and still situated well enough below the bulk of those otherwise thick and perfectly nasty acidic clouds. Because the inert infrastructure of this rigid airship doesn’t change per given altitude means that its hauling capacity or usable payload is capable of becoming downright impressive, getting much better as one operates at lower altitudes, such as below 35 km by season of day and below 25 km by season of nighttime is where that robust S8/CO2 atmosphere is nearly crystal dry and otherwise clear for as far as you can see (depending on terrain, roughly 500 km in all directions). Initially, this is a very rigid composite and robust kind of mostly robotic airship, intended as an extended expedition probe. It’s somewhat of a conventional blimp like craft, except using a rigid composite hull with a 6:1 L/W ratio instead of the more common terrestrial 5:1. In my way of thinking, this has a rather thick outer composite hull that’s nicely insulative (critical science instrument/components area being insulated by R-128 or better) as obviously acidic proof, not to mention melt proof, not that its failsafe hydrogen gas displacement or that of its vacuum worth of artificial buoyancy need be all that acid proof or even having to be excessively cooled, because the bulk of this airship can be rated for 811 K (1000°F). There are four rather over-sized longitudinal stabilizer fins, used for obvious flight stability, but also utilized for their heat- exchanging functions, and otherwise a pair of midship underbelly landing skids (just in case). Its configuration might incorporate one fully ducted set of large diameter counter-rotating pusher fans, plus four other fully rotatable thrusters (two on either forward/aft side for a total boost of 10% main engine thrust), that collectively can also be utilized as forward/ reverse motion thrusters. The maximum velocity potential of 100 m/s need not be necessary, and certainly not one of those all or nothing considerations, because 10 m/s is more than good enough unless striving to migrate though those acidic clouds in order to cruise essentially above the 75 km nighttime worth of those fast moving clouds (solar elevated to 80~85 km by day) . This craft is not going to be your average Hindenburg, much less flammable or otherwise combustible, although intended for efficiently cruising aboutVenuswhere size and mass are of little concern when having 64+ kg/m3 worth of buoyancy, and only 90.5% gravity to work with is certainly going to avoid all sorts of various inert mass related considerations that would have more than grounded the Hindenburg. In addition to certain liquid fuels that can be safely incorporated, there will be a pair of custom RTGs running at more than hot enough to melt aluminum, and a likely Stirling thermal dynamic added process of utilizing that heat at roughly 25+% efficiency for all of the onboard systems and main propulsion. Getting rid of 75% worth of RTG heat shouldn’t be all that insurmountable, especially with such a thermally conductive flow of that toasty Venusian atmosphere flowing past, as worthy of roughly 10% the density of water, in that the closer we cruise above that geothermally active surface the more dense and thermally conductive becomes the surrounding S8 and CO2 atmosphere. Once again, on behalf of Usenet/Group diehard naysayers, this topic is not about our having to terraformVenus, or that of our having to prance ourselves about in the buff, at least not without our trusty OveGlove jumpsuit and portable CO2--co/o2 plus heat-exchanging unit. Instead, we’re talking mostly about a fully robotic craft that really doesn’t care how hot and nasty it is outside, and may never have to land for the next hundred years, with a future human flight configured version that’s clearly scaled in sufficient volume in order to suit the applications of sustaining human our frail life for extended periods of time while cruising extensively at or below 25 km. Even though Geoffrey Landis wisely publishes most everything of his expertise as science fiction, it’s based entirely upon the regular laws of physics, and for the most part using the best available science. This doesn’t mean that I’d worship each and every published word of Landis or from others of his kind, although it does fully demonstrate that I’m not the one and only wise enough individual that’s deductively thinking constructively and thus positively about accomplishing thoseVenusexpeditions. Venusexploration papers / Geoffrey A. Landis http://www.sff.net/people/geoffrey.landis/papers.html Evaluation of Long Duration Flight onVenus/ by Anthony J. Colozza and Geoffrey A. Landis http://gltrs.grc.nasa.gov/reports/20...006-214452.pdf This paper was for the most part generated long after my having insisted that such a mission via aircraft/airship was technically doable, although this Geoffrey and Anthony version focused mostly on behalf of solar powered and RTG as necessary, whereas such there’s nothing much innovative or all that ground breaking to report, especially since much of their airship application is operated within a terrestrial like environment by way of keeping good altitude. This is not saying that my ideas are of the one and only do-or-die alternatives, as I’m not the least bit opposed to incorporating viable alternatives, or having to share most of the credits with those having contributed their honest expertise. In other words, I’m not the bad guy here, nor am I interested in hearing from those having ulterior motives or counter intentions of merely topic/author stalking and bashing for all the grief they can muster. If other intelligent life existing/coexisting onVenusis too much for your pathetic, snookered and dumbfounded brain to fathom, then don’t .... read more » |
#106
Out of all that's Google/NOVA and DARPA Usenet/newsgroups, apparently
there's not one soul that's airship technology qualified. Gee whiz, why am I not the least bit surprised. * Brad Guth Brad_Guth Brad.Guth BradGuth On Jul 30, 10:57 am, BradGuth wrote: Still not one soul of rigid airship expertise to behold, or that of any applied technology on behalf of robotics or us frail humans accomplishing any such extended Venus mission of 19.5 months (plus their return commute should push this one well past 24 months, but not likely more than 36 months). Is this DARPA Usenet/newsgroup snookered and dumbfounded itself past the point of no return, or what? (most likely afraid of their own shadow, plus whatever those pesky MIB might have to offer) - Brad Guth Brad_Guth Brad.Guth BradGuth On Jul 20, 4:06 pm, BradGuth wrote: That's extremely odd, when the all-knowing gods and wise old wizards of these DARPA saturated Usenet/newsgroups have become so unusually dead quiet on any topic the least bit related toVenus. Of course that's only because of what I'd uncovered that even a 5th grader should have figured out as of 8+ years ago, if not a whole lot before then. - BradGuthBrad_Guth Brad.GuthBradGuth On Jun 12, 5:19 am, BradGuth wrote: If rigged airship robotics isn’t offering sufficient exploration risk or otherwise DARPA/NASA spendy enough, there’s always a fully manned mission of the very least 100 fold more spendy, plus their having to navigate well above the hot geothermal surface ofVenusfor roughly 18 months before eventually upward exiting and returning to Earth. The AI/robotic consideration would not only cost at least 100 fold less than any manned mission, but it also doesn’t have to ever return to Earth, and thereby could stay on its mission throughout several 19 month cycles, as well as multiple surface landings becomes technically doable without risk of harming a single strand of human DNA. So therefore, a robotic rigid-airship is actually a good thousand fold cheaper than any kind of manned mission (perhaps even if POOF City were set up atVenusL2 would likely still be 100 fold less spendy). TheVenusenvironment at one of the likely rigid-airship cruising altitudes of 25 km is only a bit 500K (440F) toasty warm by season of day, and otherwise somewhat considerably cooler by season of night, perhaps in places of negative draft getting drawn down to as low as 400K (260F). The closer you get to that geothermally hot surface the less day/night thermal differential you’ve got to work with. Increasing upon the operational altitude to 35 km by season of nighttime is almost humanly tolerable, although you’re also getting into that lower acidic cloud haze. Much above 35 km by season of nighttime you may need to consider navigating by radar, as well as remain submarine like fully enclosed within the rigid composite airship. By season of day should allow cruising as high as 45 km, although there too is that pesky acidic/S8 cloud haze to deal with. - BradGuthBrad_Guth Brad.GuthBradGuth On May 4, 1:31 pm, BradGuth wrote: Being a little hot, buoyant and having 10% less gravity is actually a darn good thing if you were a Venusian airship, even if limited as to an oven-wrap or KetaSpire PEEK polyether etherketone and fiber reinforced balloon. Such fiber reinforced composites do exist, although an outer skin of something in basic titanium shouldn’t be excluded for this rigid airship configuration. For this topic I have this unusual airship to R&D, as intended for a rather toasty dry and calm environment. Think of this application as a floating city if you like, or consider this one as merely a small or as large as need be robotic probe that can remain efficiently aloft for nearly unlimited time without much energy demand while drifting or even when cruising along at perhaps an average air-speed of less than 10 m/s, as such wouldn’t demand but a few KW for managing a good sized robotic managed rigid airship. Taking into account the 1.75 kg/m3 by day and perhaps 2.5 kg/m3 of nighttime buoyancy at 50 km is roughly worth twice that of any terrestrial airship application, and for the most part it’s actually fairly calm, kind of dry inert and nice enough and even relatively cool because it’s at such a good deal of altitude away from that geothermal radiating planet, and otherwise operating within the nighttime season, and still situated well enough below the bulk of those otherwise thick and perfectly nasty acidic clouds. Because the inert infrastructure of this rigid airship doesn’t change per given altitude means that its hauling capacity or usable payload is capable of becoming downright impressive, getting much better as one operates at lower altitudes, such as below 35 km by season of day and below 25 km by season of nighttime is where that robust S8/CO2 atmosphere is nearly crystal dry and otherwise clear for as far as you can see (depending on terrain, roughly 500 km in all directions). Initially, this is a very rigid composite and robust kind of mostly robotic airship, intended as an extended expedition probe. It’s somewhat of a conventional blimp like craft, except using a rigid composite hull with a 6:1 L/W ratio instead of the more common terrestrial 5:1. In my way of thinking, this has a rather thick outer composite hull that’s nicely insulative (critical science instrument/components area being insulated by R-128 or better) as obviously acidic proof, not to mention melt proof, not that its failsafe hydrogen gas displacement or that of its vacuum worth of artificial buoyancy need be all that acid proof or even having to be excessively cooled, because the bulk of this airship can be rated for 811 K (1000°F). There are four rather over-sized longitudinal stabilizer fins, used for obvious flight stability, but also utilized for their heat- exchanging functions, and otherwise a pair of midship underbelly landing skids (just in case). Its configuration might incorporate one fully ducted set of large diameter counter-rotating pusher fans, plus four other fully rotatable thrusters (two on either forward/aft side for a total boost of 10% main engine thrust), that collectively can also be utilized as forward/ reverse motion thrusters. The maximum velocity potential of 100 m/s need not be necessary, and certainly not one of those all or nothing considerations, because 10 m/s is more than good enough unless striving to migrate though those acidic clouds in order to cruise essentially above the 75 km nighttime worth of those fast moving clouds (solar elevated to 80~85 km by day) . This craft is not going to be your average Hindenburg, much less flammable or otherwise combustible, although intended for efficiently cruising aboutVenuswhere size and mass are of little concern when having 64+ kg/m3 worth of buoyancy, and only 90.5% gravity to work with is certainly going to avoid all sorts of various inert mass related considerations that would have more than grounded the Hindenburg. In addition to certain liquid fuels that can be safely incorporated, there will be a pair of custom RTGs running at more than hot enough to melt aluminum, and a likely Stirling thermal dynamic added process of utilizing that heat at roughly 25+% efficiency for all of the onboard systems and main propulsion. Getting rid of 75% worth of RTG heat shouldn’t be all that insurmountable, especially with such a thermally conductive flow of that toasty Venusian atmosphere flowing past, as worthy of roughly 10% the density of water, in that the closer we cruise above that geothermally active surface the more dense and thermally conductive becomes the surrounding S8 and CO2 atmosphere. Once again, on behalf of Usenet/Group diehard naysayers, this topic is not about our having to terraformVenus, or that of our having to prance ourselves about in the buff, at least not without our trusty OveGlove jumpsuit and portable CO2--co/o2 plus heat-exchanging unit. |
#107
Apparently the regular laws of physics and best available science
isn't good enough these days. Out of all the supposed expertise and first hand talent that's claimed by most every soul within Usenet/newsgroups, yet not a positive/ constructive peep out of anyone as to accomplishing these composite rigid airships. Is this further proof positive that our mainstream faith-based status quo has us firmly by our private parts, or what? ~ Brad Guth Brad_Guth Brad.Guth BradGuth On Jul 20, 4:06 pm, BradGuth wrote: That's extremely odd, when the all-knowing gods and wise old wizards of these DARPA saturated Usenet/newsgroups have become so unusually dead quiet on any topic the least bit related to Venus. Of course that's only because of what I'd uncovered that even a 5th grader should have figured out as of 8+ years ago, if not a whole lot before then. - Brad Guth Brad_Guth Brad.Guth BradGuth On Jun 12, 5:19 am, BradGuth wrote: If rigged airship robotics isn’t offering sufficient exploration risk or otherwise DARPA/NASA spendy enough, there’s always a fully manned mission of the very least 100 fold more spendy, plus their having to navigate well above the hot geothermal surface of Venus for roughly 18 months before eventually upward exiting and returning to Earth. The AI/robotic consideration would not only cost at least 100 fold less than any manned mission, but it also doesn’t have to ever return to Earth, and thereby could stay on its mission throughout several 19 month cycles, as well as multiple surface landings becomes technically doable without risk of harming a single strand of human DNA. So therefore, a robotic rigid-airship is actually a good thousand fold cheaper than any kind of manned mission (perhaps even if POOF City were set up atVenusL2 would likely still be 100 fold less spendy). The Venus environment at one of the likely rigid-airship cruising altitudes of 25 km is only a bit 500K (440F) toasty warm by season of day, and otherwise somewhat considerably cooler by season of night, perhaps in places of negative draft getting drawn down to as low as 400K (260F). The closer you get to that geothermally hot surface the less day/night thermal differential you’ve got to work with. Increasing upon the operational altitude to 35 km by season of nighttime is almost humanly tolerable, although you’re also getting into that lower acidic cloud haze. Much above 35 km by season of nighttime you may need to consider navigating by radar, as well as remain submarine like fully enclosed within the rigid composite airship. By season of day should allow cruising as high as 45 km, although there too is that pesky acidic/S8 cloud haze to deal with. - BradGuthBrad_Guth Brad.GuthBradGuth On May 4, 1:31 pm, BradGuth wrote: Being a little hot, buoyant and having 10% less gravity is actually a darn good thing if you were a Venusian airship, even if limited as to an oven-wrap or KetaSpire PEEK polyether etherketone and fiber reinforced balloon. Such fiber reinforced composites do exist, although an outer skin of something in basic titanium shouldn’t be excluded for this rigid airship configuration. For this topic I have this unusual airship to R&D, as intended for a rather toasty dry and calm environment. Think of this application as a floating city if you like, or consider this one as merely a small or as large as need be robotic probe that can remain efficiently aloft for nearly unlimited time without much energy demand while drifting or even when cruising along at perhaps an average air-speed of less than 10 m/s, as such wouldn’t demand but a few KW for managing a good sized robotic managed rigid airship. Taking into account the 1.75 kg/m3 by day and perhaps 2.5 kg/m3 of nighttime buoyancy at 50 km is roughly worth twice that of any terrestrial airship application, and for the most part it’s actually fairly calm, kind of dry inert and nice enough and even relatively cool because it’s at such a good deal of altitude away from that geothermal radiating planet, and otherwise operating within the nighttime season, and still situated well enough below the bulk of those otherwise thick and perfectly nasty acidic clouds. Because the inert infrastructure of this rigid airship doesn’t change per given altitude means that its hauling capacity or usable payload is capable of becoming downright impressive, getting much better as one operates at lower altitudes, such as below 35 km by season of day and below 25 km by season of nighttime is where that robust S8/CO2 atmosphere is nearly crystal dry and otherwise clear for as far as you can see (depending on terrain, roughly 500 km in all directions). Initially, this is a very rigid composite and robust kind of mostly robotic airship, intended as an extended expedition probe. It’s somewhat of a conventional blimp like craft, except using a rigid composite hull with a 6:1 L/W ratio instead of the more common terrestrial 5:1. In my way of thinking, this has a rather thick outer composite hull that’s nicely insulative (critical science instrument/components area being insulated by R-128 or better) as obviously acidic proof, not to mention melt proof, not that its failsafe hydrogen gas displacement or that of its vacuum worth of artificial buoyancy need be all that acid proof or even having to be excessively cooled, because the bulk of this airship can be rated for 811 K (1000°F). There are four rather over-sized longitudinal stabilizer fins, used for obvious flight stability, but also utilized for their heat- exchanging functions, and otherwise a pair of midship underbelly landing skids (just in case). Its configuration might incorporate one fully ducted set of large diameter counter-rotating pusher fans, plus four other fully rotatable thrusters (two on either forward/aft side for a total boost of 10% main engine thrust), that collectively can also be utilized as forward/ reverse motion thrusters. The maximum velocity potential of 100 m/s need not be necessary, and certainly not one of those all or nothing considerations, because 10 m/s is more than good enough unless striving to migrate though those acidic clouds in order to cruise essentially above the 75 km nighttime worth of those fast moving clouds (solar elevated to 80~85 km by day) . This craft is not going to be your average Hindenburg, much less flammable or otherwise combustible, although intended for efficiently cruising about Venus where size and mass are of little concern when having 64+ kg/m3 worth of buoyancy, and only 90.5% gravity to work with is certainly going to avoid all sorts of various inert mass related considerations that would have more than grounded the Hindenburg. In addition to certain liquid fuels that can be safely incorporated, there will be a pair of custom RTGs running at more than hot enough to melt aluminum, and a likely Stirling thermal dynamic added process of utilizing that heat at roughly 25+% efficiency for all of the onboard systems and main propulsion. Getting rid of 75% worth of RTG heat shouldn’t be all that insurmountable, especially with such a thermally conductive flow of that toasty Venusian atmosphere flowing past, as worthy of roughly 10% the density of water, in that the closer we cruise above that geothermally active surface the more dense and thermally conductive becomes the surrounding S8 and CO2 atmosphere. Once again, on behalf of Usenet/Group diehard naysayers, this topic is not about our having to terraform Venus, or that of our having to prance ourselves about in the buff, at least not without our trusty OveGlove jumpsuit and portable CO2--co/o2 plus heat-exchanging unit. Instead, we’re talking mostly about a fully robotic craft that really doesn’t care how hot and nasty it is outside, and may never have to land for the next hundred years, with a future human flight configured version that’s clearly scaled in sufficient volume in order to suit the applications of sustaining human our frail life for extended periods of time while cruising extensively at or below 25 km. Even though Geoffrey Landis wisely publishes most everything of his expertise as science fiction, it’s based entirely upon the regular laws of physics, and for the most part using the best available science. This doesn’t mean that I’d worship each and every published word of Landis or from others of his kind, although it does fully demonstrate that I’m not the one and only wise enough individual that’s deductively thinking constructively and thus positively about accomplishing those Venus expeditions. Venus exploration papers / Geoffrey A. Landis http://www.sff.net/people/geoffrey.landis/papers.html Evaluation of Long Duration Flight on Venus/ by Anthony J. Colozza and Geoffrey A. Landis http://gltrs.grc.nasa.gov/reports/20...006-214452.pdf This paper was for the most part generated long after my having insisted that such a mission via aircraft/airship was technically doable, although this Geoffrey and Anthony version focused mostly on behalf of solar powered and RTG as necessary, whereas such there’s nothing much innovative or all that ground breaking to report, especially since much of their airship application is operated within a terrestrial like environment by way of keeping good altitude. This is not saying that my ideas are of the one and only do-or-die alternatives, as I’m not the least bit opposed to incorporating viable alternatives, or having to share most of the credits with those having contributed their honest expertise. In other words, I’m not the bad guy here, nor am I interested in hearing from those having ulterior motives or counter intentions of merely topic/author stalking and bashing for all the grief they can muster. If other intelligent life existing/coexisting on Venus is too much for your pathetic, snookered and dumbfounded brain to fathom, then don’t .... read more » |
Homebuilt hot-air airships | Jim Logajan | Home Built | 8 | July 21st 06 06:49 PM |
Airships Flying boat 1934 FA | JaneyP | General Aviation | 0 | August 11th 05 12:21 AM |
Balloons Airships vintage book FA | [email protected] | General Aviation | 0 | July 16th 05 01:12 AM |
Are there any fligh-simulators for Venus ??? | Tristan Beeline | Simulators | 7 | June 28th 05 02:42 PM |
Unmanned airships at FL650! | Roy Smith | General Aviation | 0 | July 6th 04 06:31 PM |
