Gig 601Xl Builder wrote:
Kloudy via AviationKB.com wrote: Kloudy wrote: Big up on that cat. Dang, I wonder what the measured glide is on an F-16? : - @ Just ask the mighty interwebs. http://findarticles.com/p/articles/m...12/ai_n6100350 1:1? jeezuz..might as well strap yourelf to a washing machine. At least it makes the math easy. There is something funny here. He said he started out at 24,000 feet, but then later says he established the 1:1 glide 12-15 nm from the field. A 1:1 glide ratio at 12 nm out would mean he was 12 nm high, or about 72,000 feet. That 1:1 has to be something other than a traditional glide ratio. Matt |
Matt Whiting wrote:
Big up on that cat. Dang, I wonder what the measured glide is on an F-16? : - @ [quoted text clipped - 6 lines] At least it makes the math easy. That 1:1 has to be something other than a traditional glide ratio. Matt 'xactly. didn't make sense to me either. Oh well. -- Message posted via AviationKB.com http://www.aviationkb.com/Uwe/Forums...ation/200808/1 |
![]() "Kloudy via AviationKB.com" u33403@uwe wrote in message news:8809a1f297c34@uwe... Matt Whiting wrote: Big up on that cat. Dang, I wonder what the measured glide is on an F-16? : - @ [quoted text clipped - 6 lines] At least it makes the math easy. That 1:1 has to be something other than a traditional glide ratio. Matt 'xactly. didn't make sense to me either. Oh well. -- Message posted via AviationKB.com http://www.aviationkb.com/Uwe/Forums...ation/200808/1 What I get from that article is not that the F-16 will only glide at 1:1, but that the pilot "established a 1:1 glide ratio and dropped the nose to capture my computed FO airspeed" at some point(s) along the approach as may be required/suggested in the F-16 user's manual in the event of a flameout. BS, TP |
On Aug 2, 8:57*am, "muff528" wrote:
"Kloudy via AviationKB.com" u33403@uwe wrote in messagenews:8809a1f297c34@uwe... Matt Whiting wrote: Big up on that cat. Dang, I wonder what the measured glide is on an F-16? *: - @ [quoted text clipped - 6 lines] At least it makes the math easy. *That 1:1 has to be something other than a traditional glide ratio. Matt 'xactly. didn't make sense to me either. Oh well. -- Message posted via AviationKB.com http://www.aviationkb.com/Uwe/Forums...ation/200808/1 What I get from that article is not that the F-16 will only glide at 1:1, but that the pilot "established a 1:1 glide ratio and dropped the nose to capture my computed FO airspeed" at some point(s) along the approach as may be required/suggested in the F-16 user's manual in the event of a flameout. |
On Aug 2, 9:26*am, wrote:
On Aug 2, 8:57*am, "muff528" wrote: "Kloudy via AviationKB.com" u33403@uwe wrote in messagenews:8809a1f297c34@uwe... Matt Whiting wrote: Big up on that cat. Dang, I wonder what the measured glide is on an F-16? *: - @ [quoted text clipped - 6 lines] At least it makes the math easy. *That 1:1 has to be something other than a traditional glide ratio. Matt 'xactly. didn't make sense to me either. Oh well. -- Message posted via AviationKB.com http://www.aviationkb.com/Uwe/Forums...ation/200808/1 What I get from that article is not that the F-16 will only glide at 1:1, but that the pilot "established a 1:1 glide ratio and dropped the nose to capture my computed FO airspeed" at some point(s) along the approach as may be required/suggested in the F-16 user's manual in the event of a flameout. BS, TP Just looking at how clean that airplane is without the external tanks, it must have at least a 10 to 1 glide ratio. The shuttle with it's little wings is not that good, but far from 1 to 1 For what it's worth, at subsonic speeds the shuttle is 4.5 to 1. Not quite a brick, but close! |
![]() Matt You can hear very clear he was reported at 7 miles and 9K which in round figures is 3.5 to 1 needed to make field. Since he made it he at least made that glide ratio. If he was high when close to field he may have dumped it and picked up a 1 to 1 to burn off excess altitude??? Bottom line. Excellent job and he made it and saved the Governmet $50 Mil +/-. Big John ************************************************** ****************** On Fri, 01 Aug 2008 17:31:58 -0400, Matt Whiting wrote: Gig 601Xl Builder wrote: Kloudy via AviationKB.com wrote: Kloudy wrote: Big up on that cat. Dang, I wonder what the measured glide is on an F-16? : - @ Just ask the mighty interwebs. http://findarticles.com/p/articles/m...12/ai_n6100350 1:1? jeezuz..might as well strap yourelf to a washing machine. At least it makes the math easy. There is something funny here. He said he started out at 24,000 feet, but then later says he established the 1:1 glide 12-15 nm from the field. A 1:1 glide ratio at 12 nm out would mean he was 12 nm high, or about 72,000 feet. That 1:1 has to be something other than a traditional glide ratio. Matt |
![]() "Big John" wrote in message ... Matt You can hear very clear he was reported at 7 miles and 9K which in round figures is 3.5 to 1 needed to make field. Since he made it he at least made that glide ratio. If he was high when close to field he may have dumped it and picked up a 1 to 1 to burn off excess altitude??? Bottom line. Excellent job and he made it and saved the Governmet $50 Mil +/-. Big John I guess he is lucky he did not drop the tanks on top of someone... It was a good job but relatively easy with chase, etc... |
On Aug 2, 10:10*am, "Blueskies" wrote:
"Big John" wrote in messagenews:7ko7945tt77e0spq0cjj47t7udhcdr2p3d@4ax .com... Matt You can hear very clear he was reported at 7 miles and 9K which in round figures is 3.5 to 1 needed to make field. Since he made it he at least made that glide ratio. If he was high when close to field he may have dumped it and picked up a 1 to 1 to burn off excess altitude??? Bottom line. Excellent job and he made it and saved the Governmet $50 Mil +/-. Big John I guess he is lucky he did not drop the tanks on top of someone... It was a good job but relatively easy with chase, etc... To say it was relatively easy is one thing, but even if these guys train for it, a glider doing 250 knots would be a handful. His peers say he did an excellent job and in my world peer review is pretty much the defining criteria for measuring performance. The award he got said it was the best demonstration of airmanship for the year, and he flies with others who are known to be pretty good. |
![]() wrote in message ... On Aug 2, 10:10 am, "Blueskies" wrote: "Big John" wrote in messagenews:7ko7945tt77e0spq0cjj47t7udhcdr2p3d@4ax .com... Matt You can hear very clear he was reported at 7 miles and 9K which in round figures is 3.5 to 1 needed to make field. Since he made it he at least made that glide ratio. If he was high when close to field he may have dumped it and picked up a 1 to 1 to burn off excess altitude??? Bottom line. Excellent job and he made it and saved the Governmet $50 Mil +/-. Big John I guess he is lucky he did not drop the tanks on top of someone... It was a good job but relatively easy with chase, etc... To say it was relatively easy is one thing, but even if these guys train for it, a glider doing 250 knots would be a handful. His peers say he did an excellent job and in my world peer review is pretty much the defining criteria for measuring performance. The award he got said it was the best demonstration of airmanship for the year, and he flies with others who are known to be pretty good. What powers up the hydraulics during an engine out? The whole trick to flying is controlling how quickly you stop ;-) |
![]() "Blueskies" wrote in message ... What powers up the hydraulics during an engine out? Towards the end of the clip, there was mention of a hydrazine powered APU. Vaughn |
AUDIO: Bush jewish. Blair jewish. Howard jewish. Sarkozy jewish. 1.2 million muslims dead. Thousands of Americans dead. Trillion$ missing. | [email protected] | Naval Aviation | 0 | November 2nd 07 05:56 PM |
Big Stick | R. J. \(Bob\) Van Horn | Piloting | 5 | September 4th 07 06:54 PM |
Dead Stick Landings | Gene Seibel | Piloting | 24 | August 1st 03 12:46 AM |
Dead stick landings - follow up question | John | Piloting | 3 | July 31st 03 10:51 AM |
Stick grips | John Nicholson | Home Built | 17 | July 23rd 03 10:13 AM |
