Ed Rasimus wrote in message
It wasn't a readily available option when initially called for. Remember that Afghanistan is a long way from anywhere. At the time of Anaconda, the primary tactical assets were carrier based and flying extremely long duration, multiple refueling sorties. The flexibility for immediate on-call CAS was not available. Ed, I take issue with your last statement, unless you're limiting the scope of your answer to tacair only. My wing flew 300 sorties during Anaconda and dropped 845 JDAM's and 24 Mk84's providing excellent on call air power. Granted we're a heavy bomber and could fly 1000 miles and then loiter for a few hours, which the fighter guys couldn't do. I'm sure BUFDRVR can chime in with the BUFF's contribution to CAS in Afghanistan. It only goes to back up what you've been saying, methods of delivering CAS are changing. Cheers, Michael Kelly, Bone Maintainer |
On Sat, 13 Dec 2003 17:06:33 GMT, Ed Rasimus wrote:
Dale Brown will probably install swiveling M-61s in the swing-wing for his next fictional foray. "Flight of the Young Pup." ROFLMAO!!!!! greg -- Once you try my burger baby,you'll grow a new thyroid gland. I said just eat my burger, baby,make you smart as Charlie Chan. You say the hot sauce can't be beat. Sit back and open wide. |
Ed Rasimus wrote: Absolutely correct, and a remarkable effort. But, the discussion was regarding the call for strafe. The image that conjures up of a Bone rolling in and lining up for a blast of maybe eight internal wing-mounted 20mm Vulcans delivered at 1800 feet slant range..... Well, if you're looking at serious ground-attack work, why not just put in some GAU-8s in the mix? Or if you're really going to be mean, fly a C-5 over at 40,000 feet and drop a few hundred pallets of lawn darts out the back... -- cirby at cfl.rr.com Remember: Objects in rearview mirror may be hallucinations. Slam on brakes accordingly. |
On Sat, 13 Dec 2003 12:33:04 -0800, Lyle wrote:
Ed, What is the difference between direct close airsupport, and close airsupport, or is it just all lumped together and called close air support. Sounds like some sort of semantic argument. I never heard the term "direct close air support" used in any official context. Close Air Support is the employment of tac air assets in direct support of ground units. It would, by its very nature be "direct". With regard to fire support of ground units, there is the distinction between direct and indirect fire. That's the difference between aimed large-bore guns such as tank cannon and parabolic lobbed shells such as artillery and mortar. Maybe someone more current than I am in the latest nomenclature can contribute to the discussion. |
Ed Rasimus wrote in message . ..
On Sat, 13 Dec 2003 12:33:04 -0800, Lyle wrote: Ed, What is the difference between direct close airsupport, and close airsupport, or is it just all lumped together and called close air support. Sounds like some sort of semantic argument. I never heard the term "direct close air support" used in any official context. Close Air Support is the employment of tac air assets in direct support of ground units. It would, by its very nature be "direct". The only distinctions I am aware of are between CAS (i.e. hitting the enemy's front line) and BAI (Battlefield Air Interdiction) which is hitting the enemy's assets slightly behind their front line to get supplies, units moving up etc. Of course, since some elements of 'CAS' are now delivered from bombers cruising at altitude, perhaps they've added to the nomenclature! Tony Williams Military gun and ammunition website: http://www.quarry.nildram.co.uk Discussion forum at: http://forums.delphiforums.com/autogun/messages/ |
![]() "Tony Williams" wrote in message ... Ed Rasimus wrote in message . .. On Sat, 13 Dec 2003 12:33:04 -0800, Lyle wrote: Ed, What is the difference between direct close airsupport, and close airsupport, or is it just all lumped together and called close air support. Sounds like some sort of semantic argument. I never heard the term "direct close air support" used in any official context. Close Air Support is the employment of tac air assets in direct support of ground units. It would, by its very nature be "direct". The only distinctions I am aware of are between CAS (i.e. hitting the enemy's front line) and BAI (Battlefield Air Interdiction) which is hitting the enemy's assets slightly behind their front line to get supplies, units moving up etc. There are two types of CAS--immediate and preplanned. Preplanned icludes CAS sorties integrated into the ground maneuver plan and submitted IAW the ATO. Immediate CAS is not included in the ATO (at least not specifically; CAS sorties can be included in the ATO without specifications, from what I gather, sort of a "CAS reserve") and addresses those situations not foreseen in the planning process. According to CGSC ST 100-3 (1996 edition), immediate CAS provides the commander with flexibility, and can be used to exploit success, reinforce or retain momentum, deal with enemy counterattacks, and provide security. Either Buffdriver or the resident Strike eagle Driver might be able to shed light on any doctrinal changes in the CAS arena that have occurred since the publication of that text. Brooks Of course, since some elements of 'CAS' are now delivered from bombers cruising at altitude, perhaps they've added to the nomenclature! Tony Williams Military gun and ammunition website: http://www.quarry.nildram.co.uk Discussion forum at: http://forums.delphiforums.com/autogun/messages/ |
Ed,
What is the difference between direct close airsupport, and close airsupport, or is it just all lumped together and called close air support. I think what you might be referring to is Close Air Support and Troops In Contact. Troops In Contact is a type of CAS where the troops are in direct fire with the enemy. General rule of thumb is if the bad guys are one kilometer or less from the good guys, it's a TIC situation. That range can be a lot greater depending on the situation (i.e. - tank v. tank engagement). Sounds like some sort of semantic argument. I never heard the term "direct close air support" used in any official context. Close Air Support is the employment of tac air assets in direct support of ground units. It would, by its very nature be "direct". The only distinctions I am aware of are between CAS (i.e. hitting the enemy's front line) and BAI (Battlefield Air Interdiction) which is hitting the enemy's assets slightly behind their front line to get supplies, units moving up etc. There are two types of CAS--immediate and preplanned. Preplanned icludes CAS sorties integrated into the ground maneuver plan and submitted IAW the ATO. Immediate CAS is not included in the ATO (at least not specifically; CAS sorties can be included in the ATO without specifications, from what I gather, sort of a "CAS reserve") and addresses those situations not foreseen in the planning process. According to CGSC ST 100-3 (1996 edition), immediate CAS provides the commander with flexibility, and can be used to exploit success, reinforce or retain momentum, deal with enemy counterattacks, and provide security. This is old stuff. Pre-planned CAS still exists largely as you describe it, but the other type of CAS which used to be 'immediate' CAS (as it exists on an ATO) is X-CAS, or 'Push' CAS. The idea is to have a predetermined number of assets airborne for a particular Vul period, either in a CAS stack or in kill boxes. These assets can then be assigned to do a variety of tasks, such as striking a TST (time sensitive target), immediate CAS request from a FAC forwarded to the ASOC, emergency CAS for non-FAC qualified troops, etc. The new book on JCAS is the 3-09.3, and while it doesn't deal with the ATO aspects (in the Air Force the reference for that would be the 3-1), it is very much the TT&P on how to do CAS today. Either Buffdriver or the resident Strike eagle Driver might be able to shed light on any doctrinal changes in the CAS arena that have occurred since the publication of that text. Brooks Give me a second while I stow my used barf-bag. I realize that CAS is a mission, not an aircraft, but there is an aircraft in the inventory that does the mission better than any other. Dropping a JDAM on coordinates just isn't going to work for TIC situations, for starters. Of course, since some elements of 'CAS' are now delivered from bombers cruising at altitude, perhaps they've added to the nomenclature! *BARF*!!! |
AIM-54 Phoenix missile | Sujay Vijayendra | Military Aviation | 89 | November 3rd 03 09:47 PM |
P-39's, zeros, etc. | old hoodoo | Military Aviation | 12 | July 23rd 03 05:48 AM |
