#11
![]() "Clark" stillnospam@me wrote in message Do I understand that you don't know? No, you do not understand. Yes he does, Clark is an idiot. |
Two mains products is used correctly:
About 12 minutes of flying time and whole lot a fun! MG "M. J. Powell" wrote in message ... Does anyone know the products of combustion of, say, a ton, of jet fuel? Mike -- M.J.Powell |
![]() "M. J. Powell" wrote in message ... Hydrocarbons have about 2 hydrogens (CnH2n+2 for alkanes, CnH2n for Alkenes, etc.) for every carbon. Using decane (C10) or undecane (C11) to represent jet fuel may be reasonable - the density looks about right. You can figure an average molecular weight somewhere in the large neighborhood of 150 #/#-mole (that'll get you a rough number for molecules in a ton). The chemical balance and actual computation are left as an exercise for the student... Do I understand that you don't know? Actually Mike he just gave you the information you need to work put the answer Knowing the hydrogen/carbon ratio lets you work out the water/co2 balance in the products of combustion and with the atomic weights you can figure out the rough masses , assuming complete conbustion. Keith |
In message , Clark
writes "M. J. Powell" wrote in : In message , Clark writes "M. J. Powell" wrote in news ![]() : In message , Ron Parsons writes In article , "M. J. Powell" wrote: Does anyone know the products of combustion of, say, a ton, of jet fuel? Hmmm.... hydrocarbons plus oxygen.... about two tons of carbon dioxide and water vapor? Oxygen? Yup, that's what "burning" requires. Generally, the atmosphere supplies it in the form of O2. I was asking about the products of combustion. Yup. If you know what goes into the reaction then you know what comes out. How much water vapour for one ton of fuel? Hydrocarbons have about 2 hydrogens (CnH2n+2 for alkanes, CnH2n for Alkenes, etc.) for every carbon. Using decane (C10) or undecane (C11) to represent jet fuel may be reasonable - the density looks about right. You can figure an average molecular weight somewhere in the large neighborhood of 150 #/#-mole (that'll get you a rough number for molecules in a ton). The chemical balance and actual computation are left as an exercise for the student... Do I understand that you don't know? No, you do not understand. Do your homework Mike and you will be able to answer your question. I asked because I don't want to do more homework! I looked up the previously given references and they told me everything except what I want to know. Mike -- M.J.Powell |
In message , Keith Willshaw
writes "M. J. Powell" wrote in message ... Hydrocarbons have about 2 hydrogens (CnH2n+2 for alkanes, CnH2n for Alkenes, etc.) for every carbon. Using decane (C10) or undecane (C11) to represent jet fuel may be reasonable - the density looks about right. You can figure an average molecular weight somewhere in the large neighborhood of 150 #/#-mole (that'll get you a rough number for molecules in a ton). The chemical balance and actual computation are left as an exercise for the student... Do I understand that you don't know? Actually Mike he just gave you the information you need to work put the answer Knowing the hydrogen/carbon ratio lets you work out the water/co2 balance in the products of combustion and with the atomic weights you can figure out the rough masses , assuming complete conbustion. I can't. I was looking for some kind soul to help me. Mike - M.J.Powell |
Clark wrote:
"M. J. Powell" wrote in news:Uj2uRaHhqv2$EwF0 @pickmere.demon.co.uk: In message , Clark writes Do your homework Mike and you will be able to answer your question. I asked because I don't want to do more homework! So, how's that working out for ya? Assume jet fuel is pure decane, to simplify the calculation. C10H22 + 15.5O2 - 11H20 + 10CO2 1 mole C10H22 = 142g 1 mole H2O = 18g 1 mole CO2 = 44g So for every tonne (1000kg) of decane burned, assuming 100% combustion, you will have 1000000/142 * 11 * 18g = 1394360g = 1394kg water 1000000/142 * 10 * 44 = 3098590g = 3098kg carbon dioxide Which comes to about 4492kg of products. Where does the extra weight come from? Obviously from the oxygen used to burn the fuel, which comes to 1000000/142 * 15.5 * 32g = 3492957g = 3492kg The assumptions made won't have much effect on the calculation, and neither will rounding error. The biggest error probably comes from the 100% combustion; from the smell they make, most jets give out quite a bit of unburnt fuel. Right ball park though. HTH John |
In message , John
Mullen writes Clark wrote: "M. J. Powell" wrote in news:Uj2uRaHhqv2$EwF0 @pickmere.demon.co.uk: In message , Clark writes Do your homework Mike and you will be able to answer your question. I asked because I don't want to do more homework! So, how's that working out for ya? Assume jet fuel is pure decane, to simplify the calculation. C10H22 + 15.5O2 - 11H20 + 10CO2 1 mole C10H22 = 142g 1 mole H2O = 18g 1 mole CO2 = 44g So for every tonne (1000kg) of decane burned, assuming 100% combustion, you will have 1000000/142 * 11 * 18g = 1394360g = 1394kg water 1000000/142 * 10 * 44 = 3098590g = 3098kg carbon dioxide Which comes to about 4492kg of products. Where does the extra weight come from? Obviously from the oxygen used to burn the fuel, which comes to 1000000/142 * 15.5 * 32g = 3492957g = 3492kg The assumptions made won't have much effect on the calculation, and neither will rounding error. The biggest error probably comes from the 100% combustion; from the smell they make, most jets give out quite a bit of unburnt fuel. Right ball park though. HTH It does indeed. Thank you very much. Mike -- M.J.Powell |
![]() "M. J. Powell" wrote in message ... In message , John Mullen writes Clark wrote: "M. J. Powell" wrote in news:Uj2uRaHhqv2$EwF0 @pickmere.demon.co.uk: In message , Clark writes Do your homework Mike and you will be able to answer your question. I asked because I don't want to do more homework! So, how's that working out for ya? Assume jet fuel is pure decane, to simplify the calculation. C10H22 + 15.5O2 - 11H20 + 10CO2 1 mole C10H22 = 142g 1 mole H2O = 18g 1 mole CO2 = 44g So for every tonne (1000kg) of decane burned, assuming 100% combustion, you will have 1000000/142 * 11 * 18g = 1394360g = 1394kg water 1000000/142 * 10 * 44 = 3098590g = 3098kg carbon dioxide Which comes to about 4492kg of products. Where does the extra weight come from? Obviously from the oxygen used to burn the fuel, which comes to 1000000/142 * 15.5 * 32g = 3492957g = 3492kg The assumptions made won't have much effect on the calculation, and neither will rounding error. The biggest error probably comes from the 100% combustion; from the smell they make, most jets give out quite a bit of unburnt fuel. Right ball park though. HTH It does indeed. Thank you very much. Just remember not to confuse a metric ton with 2000 lbs. |
In message , Tarver Engineering
writes "M. J. Powell" wrote in message ... In message , John Mullen writes Clark wrote: "M. J. Powell" wrote in news:Uj2uRaHhqv2$EwF0 @pickmere.demon.co.uk: In message , Clark writes Do your homework Mike and you will be able to answer your question. I asked because I don't want to do more homework! So, how's that working out for ya? Assume jet fuel is pure decane, to simplify the calculation. C10H22 + 15.5O2 - 11H20 + 10CO2 1 mole C10H22 = 142g 1 mole H2O = 18g 1 mole CO2 = 44g So for every tonne (1000kg) of decane burned, assuming 100% combustion, you will have 1000000/142 * 11 * 18g = 1394360g = 1394kg water 1000000/142 * 10 * 44 = 3098590g = 3098kg carbon dioxide Which comes to about 4492kg of products. Where does the extra weight come from? Obviously from the oxygen used to burn the fuel, which comes to 1000000/142 * 15.5 * 32g = 3492957g = 3492kg The assumptions made won't have much effect on the calculation, and neither will rounding error. The biggest error probably comes from the 100% combustion; from the smell they make, most jets give out quite a bit of unburnt fuel. Right ball park though. HTH It does indeed. Thank you very much. Just remember not to confuse a metric ton with 2000 lbs. I'm used to 2240 lbs/ton. Mike -- M.J.Powell |
spaceship one | Pianome | Home Built | 169 | June 30th 04 05:47 AM |
Airplane Parts on Ebay Vac Reg Valves, Fuel Floats, O-200 Spider, Fuel Injection Valve | Bill Berle | Home Built | 0 | January 26th 04 07:48 AM |
Airplane Parts on Ebay Vac Reg Valves, Fuel Floats, O-200 Spider, Fuel Injection Valve | Bill Berle | Aviation Marketplace | 0 | January 26th 04 07:48 AM |
Yo! Fuel Tank! | Veeduber | Home Built | 15 | October 25th 03 02:57 AM |
Pumping fuel backwards through an electric fuel pump | Greg Reid | Home Built | 15 | October 7th 03 07:09 PM |
