Lightweight covering of 1/8 inch G1S plywood
Old August 6th 08, 06:07 AM posted to rec.aviation.homebuilt
Ed Sullivan
Default Lightweight covering of 1/8 inch G1S plywood
On Tue, 05 Aug 2008 23:13:44 -0400, Orval Fairbairn
"Morgans" wrote:
Application is exterior on fuselage.
Personally, I would go with the fiberglass and resin. Fabric and dope
works, but glass should last forever.
Oh, I've been told that the surface under the glass must be as smooth as the
finish you want to achieve.
Too heavy! Doped Ceconite (or Stits) essentially last forever, too, as
long as you keep the bird hangared. And -- you can get a mirror finish,
if you desire. The secret is lots of thin coats of dope, sanded between
coats, then polished.
Actually Model airplane glass is probably no heavier than Dacron and
more durable.
Old August 6th 08, 06:59 AM posted to rec.aviation.homebuilt
cavelamb himself[_4_]
more durable.
1/2 ounce per square yard verses 1.7
Richard
(remove the X to email)
lightweight headset John T Piloting 4 July 5th 06 05:44 PM
NEED: Source for 2 pcs Aluminium Plate 1 Inch x 4 inch 5 foot length Spar Home Built 4 March 11th 04 11:31 PM
NEED: Source for 2 pcs Aluminium Plate 1 Inch x 4 inch 5 foot length Spar Aviation Marketplace 4 March 11th 04 11:31 PM
NEED: Source for 2 pcs Aluminium Plate 1 Inch x 4 inch 5 foot length Spar General Aviation 4 March 11th 04 11:31 PM
lightweight helmet Joa Home Built 16 January 14th 04 08:59 PM
