![]() "Copperhead144" wrote in message ... On Aug 6, 2:16 pm, " wrote: It was bound to happen sooner or later Dog-leg Deburring Tool, $8, item# 98262-0AZH 4-piece countersink set, $15, item# 98263-0AZG Microstop Countersink cage adapter, $15, item# 98264-0AZG (The above items may be found on page 36 of Catalog 163-B) Cleco Pliers, $4.50, item# 97346-1NYH (see pg 21 of Catalog 663-B) However... (you knew that was coming, right? :-) When I tried to order the deburring tool Harbor Freight said it didn't recognize the number. So I sent a message to their Customer Service people to make sure they knew there was a market for virtually any aircraft-related tools they might care to offer. The squeaking wheel DOES get the grease... eventually. If enough of you guys will follow suit we could probably get Harbor Freight to offer virtually everything needed to fill an aviation metalsmith's toolbox. Yeah, I know what you're thinking -- I'm not a big fan of Harbor Freight''s quality either. But in some cases Good Enough is all you need. For example, I've found that a Chinese cleco costing a nickel works just as well as one costing six-bits. -R.S.Hoover I couldn't agree with you more on the HF tool assessment Bob and I've purchased more than a few tool's and such from HF for that very reason. To my way of thinking if I've done my homework and know how the tool should be made than I can make a selection and purchase that leaves me with money for other materials. The more nickle's and dime's I save equal's dollar's saved or better spent on other material's or tool's. My drill press, clamps and many of my lathe tools have HF part numbers. Joe I'll add my 2 cents worth. A friend re-built a 35' Jason sailboat right along side my shop. He used HF drills and had a bunch of SS to drill, mostly 1/8" and thicker.. Still has the same drill set. I would have bet my butt that that set wouldn't last one day... Changed my opinion of HF drill bits. Stu |
Stuart & Kathryn Fields wrote:
Joe I'll add my 2 cents worth. A friend re-built a 35' Jason sailboat right along side my shop. He used HF drills and had a bunch of SS to drill, mostly 1/8" and thicker.. Still has the same drill set. I would have bet my butt that that set wouldn't last one day... Changed my opinion of HF drill bits. Stu Anybody know where I can get a cheap rivet setting tool? The one I want is $210 and I can't squeeze that out (sorry about the pun.) The one I want it the TP-888-3 on this page. http://www.rivetsinstock.com/rivet62.htm Tony |
On Aug 6, 2:21 pm, Anthony W wrote:
Anybody know where I can get a cheap rivet setting tool? The one I want is $210 and I can't squeeze that out (sorry about the pun.) ----------------------------------------------------------------------- If it's cheap, you don't want it. Call the guys at the Yardstore, see if they'v got any used ones. http://www.yardstore.com/ A good squeezer, a couple of heads and full range of sets makes up a good part of your tool kit. If the only way to get one is to poke your change in a sock until you can afford it, then do it. -R.S.Hoover |
"AW" == Anthony W Anthony writes:
AW Thanx for the feedback. I've been having a hard time locating AW a rivet squeezer. Stay away from Cal Aero Supply on eBay; they sell really old stuff. Got a squeezer from them that needed significant overhaul and sure didn't save money on that deal. -- If I could be a bird, I'd be a Flying Purple People Eater because then people would sing about me and I could fly down and eat them because I hate that song. - Jack Handey |
CAD Tools For Aircraft Design | Le Chaud Lapin | Piloting | 9 | September 26th 07 01:47 PM |
LA Times : Freight Dogs | G Farris | Instrument Flight Rules | 1 | January 13th 05 12:02 PM |
Freight Dogs | Dennis O'Connor | Piloting | 6 | January 29th 04 02:37 AM |
Air liner (air freight) hit by MANPAD | Token | Military Aviation | 24 | December 2nd 03 04:36 AM |
