jet pack
Old August 10th 08, 10:39 PM posted to rec.aviation.homebuilt
Jim Logajan
Default jet pack
Rob Bulaga wrote:
I know I'm opening myself up to all sorts of flaming, but I designed,
built and flew Trek's Solotrek and Springtail aircraft. I think I can
shed some light on your discussion about the "jetpack's" stability.
All hovering aircraft are statically unstable.
Technical nit (not a flame I hope): all lighter-than-air aircraft, many of
which are in the subset of hovering aircraft, are statically stable. At
least so far as I understand these things.
The stability of a high-rotor vs. a low-rotor is a dynamic effect,
analogous to dihedral on a high-wing vs. low-wing aircraft. It does
nothing to promote static (hovering) stability. Hovering these
machines is like trying to stand on a large beachball in the middle of
a swimming pool. Essentially, you're balancing on a column of air.
There is no pendulum effect. When the machine tilts, the force
vectors (columns of air) tilt too. Their relative position to the
c.g. is unchanged. There is no "righting" force.
Now supposing the engine fails - at that point, which in general is easier
to make safer: the high rotor or the low rotor aircraft? (See my reply to
Capt. Geoffrey Thorpe's post on the pendulum fallacy for my reasoning, such
as it is, on why I suspect high rotor is probably safer than low rotor.)
Old August 11th 08, 01:33 AM posted to rec.aviation.homebuilt
Rob Bulaga
Default jet pack
Power off is definitely a different story. With power on, the thrust vector is
always aligned with the vehicle and therefore acts through the c.g. regardless
of the aircraft's attitude. With power off, the drag through the rotor acts
parallel to the direction of travel, which is down. So, with an overhead
rotor, when the vehicle tilts right, the drag vector is shifted to the right
also (relative to the c.g.), creating a left rolling moment, making the
aircraft correct itself. With a low rotor, when the vehicle tilts right, the
drag vector is shifted to the left, creating a right rolling moment, making the
aircraft want to flip over. Either way, in a jetpack-like aircraft you've just
become a giant lawn dart.
You're also right, I had neglected to consider lighter-than-air aircraft in my
statements..
Old August 11th 08, 01:50 AM posted to rec.aviation.homebuilt
Default jet pack
"Jim Logajan" wrote in message
easier
Ducted fans "jet packs" don't autorotate - they fall like a brick (at least
stuff like the one that was flown at Oshkosh). So it really doesn't matter,
eh?
(yes, they have / plan to have a balistic 'chute to slow the brick down
from what I've read)
Looking back up this thread a ways to review the original claim:
"It's supposed to be fairly stable because the thrust reaction point is
well above the CG, so there is a strong pendulum effect. They claim
it's better than a helicopter."
Complete and utter bull droppings.
Geoff
P-61 belly gun pack Dave Kearton Aviation Photos 0 March 2nd 07 09:19 AM
Power pack for camping? LincTex General Aviation 2 June 26th 06 12:40 PM
Jet pack Bob C Soaring 14 January 12th 06 07:11 PM
Jet pack Bob C Soaring 0 January 10th 06 07:21 AM
Pack guns in your little airplane Rich S. Home Built 17 July 13th 03 05:45 PM
