How much fuel do you prefer to carry?
Old August 13th 08, 08:51 PM posted to rec.aviation.piloting
Mxsmanic
Default How much fuel do you prefer to carry?
Bob F. writes:
There is some room here between VMC and complete loss of outside references
resulting in complete reference to instruments needed.
No, there isn't. That margin is for safety. If you're in IMC, chances are
that you won't be able to use visual references for very long, and things can
change extraordinarily fast. This has caught countless pilots, many of whom
were sure that flying in IMC visually was okay as long as they could see
something out the window.
VMC means that if you roll the dice, you're likely to win. IMC means that if
you roll the dice, you're likely to use. How much of a gambler are you?
Old August 13th 08, 09:30 PM posted to rec.aviation.piloting
Bob F.[_2_]
"Mxsmanic" wrote in message
Bob F. writes:
references
are
can
whom
if
When I said "some room here" I meant in terms of the definition not in a
practical sense. Secondly this is all moot. Having several thousand
instrument hours and going on and off the gauges is second nature after a
while. When you sense outside references in your peripheral vision you
start to use them, and slowly transition. I've always had warning when
going back on the gauges so the transition was easy that way also. Never
had any kind of problem.
Regards, BobF.
One More Reason I Prefer GA Kyle Boatright Piloting 19 December 27th 06 11:53 PM
Is it a habit we prefer mechnical instruments? [email protected] Home Built 80 April 28th 06 04:05 AM
Does V-22 Go Twices as Far, carry Twice as Much? Nick Lappos Rotorcraft 26 October 12th 05 08:11 PM
Headset wanted - prefer David Clark Marty from Sunny Florida Aviation Marketplace 0 October 5th 04 02:54 PM
things to carry Gary Drescher Piloting 62 July 20th 04 03:08 AM
