New starter in a 172 2005
Old August 14th 08, 09:20 PM posted to rec.aviation.owning
Mike[_22_]
Default New starter in a 172 2005
On Aug 14, 1:00 pm, passenger 1957
There's a tooth missing.
The ring gear should be replaced at overhaul. If there's a
tooth missing, it's likely pretty old, or the starter had engagement
issues. It should be engaging the ring gear promptly, before the
starter really winds up, and if the starter drive is sticky the teeth
will get worn quickly. On a four-banger there are two places on the
gear that get it the most, both where the prop tends to stop on
shutdown.
The drive bendix on a Lyc needs lubing with silicone spray
lube, and it's really hard to get at. Any other lubricant will attract
dust and create a sticky sludge that sooner or later causes engagement
problems, tearing up the ring gear, and then seizes the drive splines
and the starter won't engage at all.
Many starters (and batteries) get replaced unnecessarily
because the solenoids are old and their contacts are corroded or
burned. Any resistance across those contacts causes a large voltage
drop because of the high current flow, and it can be verified using a
voltmeter across the studs while cranking. There shouldn't be more
than a volt or so of drop. Both the master and starter solenoids
should get replaced if this is noted.
Some pilots just keep cranking if the engine is flooded or
cold or has a bad mag or whatever else is making it reluctant to
start. Good way to bust a starter. Lycoming recommends something like
a ten-minute cooldown after three ten-second cranks. Starters have no
cooling system and use a tremendous amount of current that generates a
lot of heat.The commutator segments are set in plastic which overheats
and throws the segments, and the field and armature windings get hot
and burn off their insulating varnish and short together. Things
really get hot then.
Killing a battery with the starter will often ruin it
permanently; I don't know how many batteries we've replaced after
someone ground them right down, sulfating them so bad they wouldn't
take a charge anymore. Got to think, Pilot: why won't it start? What
should I do besides just cranking and hoping for a miracle?
Dan
Well said. The definition of stupidity is doing the same thing over and
over again and expecting different results.
Old August 15th 08, 11:26 PM posted to rec.aviation.owning
passenger 1957
I'd still like to know if I should push for a better starter or are
they all about the same? (I don't mind spending extra money if it will
help push off a similar problem) Where might I send the fried one to
see if it's either a 'bad unit' or to see if there's some other
problem to look into?
Old August 16th 08, 12:14 AM posted to rec.aviation.owning
Peter Clark
On Fri, 15 Aug 2008 15:26:36 -0700 (PDT), passenger 1957
You want the lightweight, magnetic (non-direct drive, I forget the
make offhand) actuated bendix starter. Spin faster, better starts,
all in all a better unit.
Old August 16th 08, 03:16 AM posted to rec.aviation.owning
Mike[_22_]
"passenger 1957" wrote in message
It all just depends on why your starter failed in the first place. If it
failed because someone is overcranking the starter, I don't know that a
better starter is going to fix your problem. I'm fond of Sky-Tec starters,
but I've had problems with those also. However my problem was related to a
starter adapter which your plane doesn't have. You may already have a
Sky-Tec as I've heard they come as standard equipment on some newer planes,
but I'm not sure if this is true or not.
Old August 16th 08, 03:53 AM posted to rec.aviation.owning
We have four Magnaflite starters used in flight training
(which means frequent and sometimes abusive starts), and had several
more before these four, and *none* of them have ever given trouble.
They all go to the engine's TBO. The Lamar on an O-470 we had in an
older 182, on the other hand, was a pain, lacking cranking torque, and
the old Prestolites can also make life miserable at times, with brush
and bearing issues.
Lycoming sends their engines out with Magnaflites. If they like
them, then I do, too.
Dan
Dust Devil 2005 - South African National Gliding Championships 2005 [email protected] Soaring 0 December 27th 05 09:20 AM
Starter Denny Owning 6 September 27th 05 10:32 PM
C-150 (O-200) Starter Dave Home Built 0 November 25th 04 10:57 AM
C-150 (O-200) Starter Dave Restoration 0 November 25th 04 10:57 AM
Starter Questions Aaron Coolidge Owning 4 June 30th 04 02:52 PM
