Adjustable Prop for a Cessna 150
Old August 15th 08, 07:46 PM posted to rec.aviation.owning,rec.aviation.piloting
Charles Talleyrand
Default Adjustable Prop for a Cessna 150
I notice that there are Ivoprop makes an in flight adjustable
propeller suitable for a an o-200 engine.
I understand that putting this prop on my C-150 is illegal. But
suppose ...
Suppose I put this prop on my Cessna 150. It only weighs 9.5 pounds,
as compared to the Sensenich weight of 24 pounds. So I save 14.5
pounds.
Can anyone guess how this would effect my performance? How much
better climb and how much better cruise?
-Just curious
See http://www.ivoprop.com/inflightultralightmodel.htm
And http://www2.sensenich.com/misc/c150.htm
Old August 15th 08, 08:10 PM posted to rec.aviation.owning,rec.aviation.piloting
Vaughn Simon
"Charles Talleyrand" wrote in message
as compared to the Sensenich weight of 24 pounds. So I save 14.5 #.
But it will make a largish change in your CG. The fuel and passenger load
for a 150 are both near the CG, so you might end up putting a few pounds of
ballast in the tail to stay within the CG envelope. That would cost you some of
the initial weight advantage.
Nobody can answer that question until you specify a pitch. Any given fixed
pitch prop will be optimized for climb (at the expense of cruise speed) or
cruise (at the expense of takeoff and climb performance) or somewhere in
between.
Vaughn
Nothing personal, but if you are posting through Google Groups I may not receive
your message. Google refuses to control the flood of spam messages originating
in their system, so on any given day I may or may not have Google blocked. Try
a real NNTP server & news reader program and you will never go back. All you
need is access to an NNTP server (AKA "news server") and a news reader program.
You probably already have a news reader program in your computer (Hint: Outlook
Express). Assuming that your Usenet needs are modest, use
http://news.aioe.org/ for free and/or http://www.teranews.com/ for a one-time
$3.95 setup fee.
Will poofread for food.
Old August 15th 08, 08:27 PM posted to rec.aviation.owning,rec.aviation.piloting
Mark Hansen
If you reduce the weight of the prop, won't that move your CG aft?
Requiring less weight in the tail (actually, anywhere behind the CG) to
support the same flight envelope?
between.
Mark Hansen, PP-ASEL, Instrument Airplane, USUA Ultralight Pilot
Cal Aggie Flying Farmers
Sacramento, CA
Old August 15th 08, 10:35 PM posted to rec.aviation.owning,rec.aviation.piloting
Charles Talleyrand
On Aug 15, 3:10 pm, "Vaughn Simon"
between.
Actually, one can assume that it will climb at least as well as the
standard climb prop, and cruise at least as well as the standard
cruise prop.
The difference between the cruise (normal) prop climb performance, and
the climb prop climb performance, will be available to cruise prop
users.
The difference between the climb prop cruise performance, and the
cruise prop cruise performance, will be available to climb prop users.
Anyone know these numbers?
Alternatively, there must be planes that have used both fixed and
constant-speed props. Anyone know the difference?
Old August 15th 08, 11:36 PM posted to rec.aviation.owning,rec.aviation.piloting
Jim Logajan
Don't know about the Cessna 150, but I'm pretty sure some owners of
experimentals (such as the RV series) have tried both fixed and later
constant speed props on the same engine and airframe. If interested, I
suspect one could find numbers mentioned on the forums on this web site:
http://www.vansairforce.net/
Old August 15th 08, 11:44 PM posted to rec.aviation.owning,rec.aviation.piloting
Suppose I put this prop on my Cessna 150. *It only weighs 9.5 pounds,
as compared to the Sensenich weight of 24 pounds. *So I save 14.5 #.
* * But it will make a largish change in your CG. *The fuel and passenger load
ballast in the tail to stay within the CG envelope. *That would cost you some of
Can anyone guess how this would effect my performance? *How much
* *Nobody can answer that question until you specify a pitch. *Any given fixed
between.
Sacramento, CA
Mark is dead right on this one,,, And you might end up with an ill
handling plane with an aft CG that will happen.....
be safe out there.
Old August 16th 08, 12:03 AM posted to rec.aviation.owning,rec.aviation.piloting
Vaughn Simon
"Mark Hansen" wrote in message
(Let's see, how can I gracefully get out of this one...OK, I know...)
Brain fart! Yes, you are 100% correct.
We would need to saw off tail structure to fix the CG. (just kidding)
Worst case, you would need to add weight as far forward as possible, and that
added weight would have to be MORE than the weight that you saved by swapping
the prop because it would necessarily need to be mounted closer to the CG than
where the weight came off (the prop).
Just to add a bit of noise to the discussion, an airplane operating at
maximum allowed aft CG is actually more aerodynamically efficient. Sailplane
pilots often add tail ballast for just this reason.
Vaughn
$3.95 setup fee.
Old August 16th 08, 03:06 AM posted to rec.aviation.owning,rec.aviation.piloting
BT
I would think he would need extra weight in the nose.. not in the tail.
BT
"Vaughn Simon" wrote in message
load for a 150 are both near the CG, so you might end up putting a few
pounds of ballast in the tail to stay within the CG envelope. That would
cost you some of the initial weight advantage.
fixed pitch prop will be optimized for climb (at the expense of cruise
speed) or cruise (at the expense of takeoff and climb performance) or
somewhere in between.
Vaughn
receive your message. Google refuses to control the flood of spam
messages originating in their system, so on any given day I may or may not
have Google blocked. Try a real NNTP server & news reader program and you
will never go back. All you need is access to an NNTP server (AKA "news
server") and a news reader program. You probably already have a news
reader program in your computer (Hint: Outlook Express). Assuming that
your Usenet needs are modest, use http://news.aioe.org/ for free and/or
http://www.teranews.com/ for a one-time $3.95 setup fee.
Old August 16th 08, 03:08 AM posted to rec.aviation.owning,rec.aviation.piloting
BT
Don't forget the CG change.. losing 14# on the nose is a lot.. you are going
to be tail heavy
BT
load
of
some of
fixed
or
between.
cruise prop.
users.
Old August 16th 08, 03:10 AM posted to rec.aviation.owning,rec.aviation.piloting
BT
Actually I think it was determined in the sailplane circles.. that having
the CG at the 85% point was the most efficient..
too far aft was too much and caused nose down stick putting the elevator
down into the slip stream, and not far enough aft caused back stick or up
elevator into the slip stream.
Heavier pilots do add tail ballast which increases the minimum pilot weight
for club gliders.
BT
Sailplane pilots often add tail ballast for just this reason.
Vaughn
Ground adjustable prop [email protected] Home Built 1 January 30th 05 06:15 AM
adjustable prop bearing Joe Home Built 5 October 23rd 04 12:00 PM
Cessna Prop Needed Cy Galley Aviation Marketplace 0 January 23rd 04 01:23 AM
Hydraulic CS prop converting to Adjustable prop? Scott VanderVeen Home Built 0 December 5th 03 05:54 PM
Adjustable prop experience? Richard Lamb Home Built 0 July 1st 03 04:07 AM
