Adjustable Prop for a Cessna 150
Old August 15th 08, 11:44 PM posted to rec.aviation.owning,rec.aviation.piloting
Default Adjustable Prop for a Cessna 150
On Aug 15, 1:27*pm, Mark Hansen wrote:
On 08/15/08 12:10, Vaughn Simon wrote:
"Charles Talleyrand" wrote in message
Suppose I put this prop on my Cessna 150. *It only weighs 9.5 pounds,
as compared to the Sensenich weight of 24 pounds. *So I save 14.5 #.
* * But it will make a largish change in your CG. *The fuel and passenger load
for a 150 are both near the CG, so you might end up putting a few pounds of
ballast in the tail to stay within the CG envelope. *That would cost you some of
the initial weight advantage.
If you reduce the weight of the prop, won't that move your CG aft?
Requiring less weight in the tail (actually, anywhere behind the CG) to
support the same flight envelope?
Can anyone guess how this would effect my performance? *How much
better climb and how much better cruise?
* *Nobody can answer that question until you specify a pitch. *Any given fixed
pitch prop will be optimized for climb (at the expense of cruise speed) or
cruise (at the expense of takeoff and climb performance) or somewhere in
between.
Mark Hansen, PP-ASEL, Instrument Airplane, USUA Ultralight Pilot
Cal Aggie Flying Farmers
Sacramento, CA
Mark is dead right on this one,,, And you might end up with an ill
handling plane with an aft CG that will happen.....
be safe out there.
Adjustable Prop for a Cessna 150 Charles Talleyrand Piloting 14 August 19th 08 02:55 AM
Ground adjustable prop [email protected] Home Built 1 January 30th 05 06:15 AM
adjustable prop bearing Joe Home Built 5 October 23rd 04 12:00 PM
Hydraulic CS prop converting to Adjustable prop? Scott VanderVeen Home Built 0 December 5th 03 05:54 PM
Adjustable prop experience? Richard Lamb Home Built 0 July 1st 03 04:07 AM
