Dick wrote:
yes there are timing marks. Unfortunately I can't access the case seam due to nosebowl and air plenum sheetmetal that I'd prefer not removing. So I guess my question still remains on difference between 30/32 and 28/30... Thanks anyway, Dick The correct answer as to why we like to maintain correct magneto timing in aviation is to prevent catastrophic engine failure such as loss of cylinders, holes burned through pistons, thrown rods and other negative consequences of detonation. Is this answer clear enough for you? Does it help that I'm an A&P? Why would you even bother to check the timing if you weren't going to do anything about it except wring your hands and beg other people to tell you it's OK? Do you go through the same agony when your oil's low, or your tire pressure's low? I can't believe that in the two days you've spent waffling over this, you couldn't find the time to loosen 4 nuts, rotate 2 mags, torque 4 nuts and make a logbook entry. -- John Kimmel I think it will be quiet around here now. So long. |
Thanks John but I was aware of the potential problems before you took the
time out to chew on me. Since you're wrong about "wringing my hands and begging for an okay", I don't consider your being an A&P any help at this time... However since most specs have a range of values, I am looking for that range. "John Kimmel" wrote in message ... Dick wrote: yes there are timing marks. Unfortunately I can't access the case seam due to nosebowl and air plenum sheetmetal that I'd prefer not removing. So I guess my question still remains on difference between 30/32 and 28/30... Thanks anyway, Dick The correct answer as to why we like to maintain correct magneto timing in aviation is to prevent catastrophic engine failure such as loss of cylinders, holes burned through pistons, thrown rods and other negative consequences of detonation. Is this answer clear enough for you? Does it help that I'm an A&P? Why would you even bother to check the timing if you weren't going to do anything about it except wring your hands and beg other people to tell you it's OK? Do you go through the same agony when your oil's low, or your tire pressure's low? I can't believe that in the two days you've spent waffling over this, you couldn't find the time to loosen 4 nuts, rotate 2 mags, torque 4 nuts and make a logbook entry. -- John Kimmel I think it will be quiet around here now. So long. |
Dick wrote:
The specs for my C-85 are upper plugs mag @ 28* BTDC and lower @ 30*BTDC. My results are upper @ 30* BTDC and lower @ 32* BTDC. I couldn't find a "flower pot" with attached degree wheel to borrow and attach to the prop hub so used a little "mickey mouse" circular protractor with a free swinging needle/pointer. Two separate readings confirmed my 30-32. TDC was identified and impulses unloaded before taking the readings. My question is whether my results are acceptable for a low speed , experimental or need to be readjusted?? If need to be redone, I'd appreciate a little on why, please. Thanks, Dick PS: If listening G, I think "highflyer"(?) gave me some mag advice during an "annual" a few years back which was appreciated. Teledyne Continental has issued MSB94-8C-1. With rare exceptions (mostly for turbo'd engines), the magneto to engine timing tolerance is +/- 1 degree. Your results, per the manufacturer, are one degree out of specification. Rip A&P/IA |
Actually found my original technique was poor and was able to use Dales
advice of timing a different piston to the upper case split. Right on @ 30 and 28deg per spec. Thanks to all who advised. "Rip" wrote in message ... Dick wrote: The specs for my C-85 are upper plugs mag @ 28* BTDC and lower @ 30*BTDC. My results are upper @ 30* BTDC and lower @ 32* BTDC. I couldn't find a "flower pot" with attached degree wheel to borrow and attach to the prop hub so used a little "mickey mouse" circular protractor with a free swinging needle/pointer. Two separate readings confirmed my 30-32. TDC was identified and impulses unloaded before taking the readings. My question is whether my results are acceptable for a low speed , experimental or need to be readjusted?? If need to be redone, I'd appreciate a little on why, please. Thanks, Dick PS: If listening G, I think "highflyer"(?) gave me some mag advice during an "annual" a few years back which was appreciated. Teledyne Continental has issued MSB94-8C-1. With rare exceptions (mostly for turbo'd engines), the magneto to engine timing tolerance is +/- 1 degree. Your results, per the manufacturer, are one degree out of specification. Rip A&P/IA |
The TCM shop manual for my IO-550 engine says to set the magneto timing plus
or minus 1° from spec. Dennis |
| MAGNETO TIMING LIGHT Plans | Roger | Owning | 4 | November 16th 05 06:24 PM |
| MAGNETO TIMING LIGHT Plans | Roger | Piloting | 4 | November 13th 05 08:50 PM |
| Bendix Magneto Question | Dick Kurtz | Owning | 0 | September 22nd 05 04:36 AM |
| Bendix Magneto Question | Dick Kurtz | Restoration | 0 | September 22nd 05 04:36 AM |
| internal timing of slick magneto | Jerry Jensen | Home Built | 1 | June 25th 04 08:59 PM |
