internal timing of slick magneto
Old June 24th 04, 01:14 AM
Jerry Jensen
Default internal timing of slick magneto
Anyone have any detailed instructions for internal timing of a newer
slick magneto?
Old June 25th 04, 08:59 PM
Dan Thomas
Jerry Jensen wrote in message . ..
slick magneto?
To set the points gap you need a tiny tool made by Slick. It
goes into the applicable L or R slot in the magnet rotor, depending on
rotation direction (see data plate on mag re rotation), and the rotor
is turned in its proper direction (as viewed from the mounting flange
end) so the tool is against the armature, and the points are set so
they're just opening. This will give a gap of about .008" to .010" at
the points. Using a feeler gauge isn't all that accurate, and if the
points open a bit too early or late the spark will be pretty weak. On
a magneto, the points open at the point of maximum flux differential,
and that happens several degrees after the magnet has passed through
full register.
The distributor gear is set so the applicable L or R mark is
lined up with the mark on the rotor gear. A pin goes into the gear and
housing to lock the mag in this position for installation, with the
crank set at #1 firing position (not TDC). Don't forget to remove the
pin before turning that prop!
Dan
