On Aug 16, 6:08*pm, "Ken S. Tucker" wrote:
On Aug 16, 2:27 pm, Mxsmanic wrote: Ken S. Tucker writes: Ok, have you ever been in a sail boat? No. Well you must try it. Your doing a tack with the sail fully stable suckin' energy from the wind, cuttin' water and bouncin' waves off the starboards, that's the sound you hear. Next, you reverse tact and the sail flutters (stalls) until re-acquistion of stability going in nearly the opposite direction and you're still heading into the wind, so the net motion is into the wind. Every pilot should do that. I was on trapeze, *with a good fat old captain on the til, and me being a skinny lively bitch loved jumped to either side of the boat, pulling the sail to max the energy out of the wind. Regards Ken PS: Read about it. On our boat we put the crew to the windward side to keep the mast more vertical. We adjust the sail by pulling on the correct strings, and it depends on the tack as to which is the lee rail going awash. As for stalling a sail -- on a beat there's lots of flow separation on the low pressure side of the sail, but it continues to drive the boat. The luffing at the trailing edge just means there's marginal flow separation there, not at the leading edge. If you want to really see a sail stall, do a jibe, not a come about. If you don't duck you'll learn soon enough why the part sweeping across the cockpit is called a boom. |
On Aug 18, 1:07 am, wrote:
On Aug 16, 6:08 pm, "Ken S. Tucker" wrote: On Aug 16, 2:27 pm, Mxsmanic wrote: Ken S. Tucker writes: Ok, have you ever been in a sail boat? No. Well you must try it. Your doing a tack with the sail fully stable suckin' energy from the wind, cuttin' water and bouncin' waves off the starboards, that's the sound you hear. Next, you reverse tact and the sail flutters (stalls) until re-acquistion of stability going in nearly the opposite direction and you're still heading into the wind, so the net motion is into the wind. Every pilot should do that. I was on trapeze, with a good fat old captain on the til, and me being a skinny lively bitch loved jumped to either side of the boat, pulling the sail to max the energy out of the wind. Regards Ken PS: Read about it. On our boat we put the crew to the windward side to keep the mast more vertical. We adjust the sail by pulling on the correct strings, and it depends on the tack as to which is the lee rail going awash. As for stalling a sail -- on a beat there's lots of flow separation on the low pressure side of the sail, but it continues to drive the boat. The luffing at the trailing edge just means there's marginal flow separation there, not at the leading edge. If you want to really see a sail stall, do a jibe, not a come about. If you don't duck you'll learn soon enough why the part sweeping across the cockpit is called a boom. With all that technical data I can see him lining up for the next Americas Cup :-) |
On Aug 17, 6:07 am, wrote:
On Aug 16, 6:08 pm, "Ken S. Tucker" wrote: On Aug 16, 2:27 pm, Mxsmanic wrote: Ken S. Tucker writes: Ok, have you ever been in a sail boat? No. Well you must try it. Your doing a tack with the sail fully stable suckin' energy from the wind, cuttin' water and bouncin' waves off the starboards, that's the sound you hear. Next, you reverse tact and the sail flutters (stalls) until re-acquistion of stability going in nearly the opposite direction and you're still heading into the wind, so the net motion is into the wind. Every pilot should do that. I was on trapeze, with a good fat old captain on the til, and me being a skinny lively bitch loved jumped to either side of the boat, pulling the sail to max the energy out of the wind. Regards Ken PS: Read about it. On our boat we put the crew to the windward side to keep the mast more vertical. We adjust the sail by pulling on the correct strings, and it depends on the tack as to which is the lee rail going awash. As for stalling a sail -- on a beat there's lots of flow separation on the low pressure side of the sail, but it continues to drive the boat. The luffing at the trailing edge just means there's marginal flow separation there, not at the leading edge. If you want to really see a sail stall, do a jibe, not a come about. If you don't duck you'll learn soon enough why the part sweeping across the cockpit is called a boom. I have no problem with the boom, I have a thick skull :-). Best time, we had was in a 10-20 knot wind, I was on trapeze, fairly small lake with white caps, 2 maybe 3 person boat, hot day with a stiff breeze, getting soaked with splash, and slippery with wet shoes. I slipped a bit but with sober adrenaline I recovered fast, whata rush. Cheers Ken |
On Aug 17, 5:38*pm, "Ken S. Tucker" wrote:
On Aug 17, 6:07 am, wrote: On Aug 16, 6:08 pm, "Ken S. Tucker" wrote: On Aug 16, 2:27 pm, Mxsmanic wrote: Ken S. Tucker writes: Ok, have you ever been in a sail boat? No. Well you must try it. Your doing a tack with the sail fully stable suckin' energy from the wind, cuttin' water and bouncin' waves off the starboards, that's the sound you hear. Next, you reverse tact and the sail flutters (stalls) until re-acquistion of stability going in nearly the opposite direction and you're still heading into the wind, so the net motion is into the wind. Every pilot should do that. I was on trapeze, *with a good fat old captain on the til, and me being a skinny lively bitch loved jumped to either side of the boat, pulling the sail to max the energy out of the wind. Regards Ken PS: Read about it. On our boat we put the crew to the windward side to keep the mast more vertical. We adjust the sail by *pulling on the correct strings, and it depends on the tack as to which is the lee rail going awash. As for stalling a sail -- on a beat there's lots of flow separation on the low pressure side of the sail, but it continues to drive the boat. The luffing at the trailing edge just means there's marginal flow separation there, not at the leading edge. If you want to really see a sail stall, do a jibe, not a come about. If you don't duck you'll learn soon enough why the part sweeping across the cockpit is called a boom. I have no problem with the boom, I have a thick skull :-). Best time, we had was in a 10-20 knot wind, I was on trapeze, fairly small lake with white caps, 2 maybe 3 person boat, hot day with a stiff breeze, getting soaked with splash, and slippery with wet shoes. I slipped a bit but with sober adrenaline I recovered fast, whata rush. Cheers Ken You're casting some doubts here. Boat shoes don't slip on wet surfaces. If you got hit with our boom I'd be betting on the boom, especially on a jibe. First rule on our boat is to get out of the way on the commands "Ready about" or "Ready Jibe". Those are NOT suggestions and are not negotiable. You want not to be saying "What did you say?" on "Jibe ho" or "Hard Alee". No traps on our boat, it's a cruiser, not a racer. It does cast a nice shadow though. Come to think of it. some other people here probably cast nice shadows, they are mostly two dimensional anyway. |
Google Groups Beta | Steven P. McNicoll | Piloting | 27 | June 10th 05 02:33 PM |
Posting via Google Groups | jim rosinski | Piloting | 7 | February 4th 05 08:13 PM |
The New Google Groups Interface | [email protected] | Soaring | 2 | December 13th 04 06:29 AM |
