On Sun, 17 Aug 2008 13:43:01 -0400, Ernest Christley
wrote: Stealth Pilot wrote: If I ever wanted to use it it would need replacing. a light weight straight run cable duct with a loop of light builders twine from end to end would have been a better option. lacing the wiring and the pitot tubing to every rib just hasnt proven to be the best option.(it took 2 months to replace the pitot tubing) For light weight, go with "wiring loom". It's cheap, extremely light, and designed to surround and protect wiring. Running wires down it blind is not easy. The wire ends want to catch on the ribs. Solve that by screwing on a small wire-nut (or make sure you have the twine, as Stealth suggests). Another option I read about, years ago, was to take a piece of mylar and roll it into a tube. Slide it into the wing, and it'll uncoil as far as it can for the largest possible cableway for later use. Ron Wanttaja |
Anyone install the EI FP5L? | Doug Vetter | Owning | 3 | March 1st 08 07:08 PM |
Can't install FSX | Blue | Simulators | 6 | November 22nd 06 09:42 PM |
Autopilot install. | Jimmy B. | Owning | 19 | July 19th 05 09:29 AM |
KLN-94 Install Manual | Mike Granby | Owning | 5 | July 7th 05 11:33 AM |
New Lycoming Install | Evan Carew | Home Built | 2 | October 9th 04 04:10 AM |
