snipped
B) If correct on A, how to understand the dimensions? Perhaps a 36x9" lathe has 36" between centers, and 9" is the max. diameter of basic stock? Right again. (well, the 9" is the distance from the bed to the center - you may have trouble mounting 9"stock) snipped Minor correction: I believe that 'swing' is actually the maximum diameter of the work. 9" swing would mean 4 1/2" between the bed (rails that the tailstock moves on) and the centerline. Charlie |
On Aug 17, 4:05*pm, Charlie wrote:
snipped B) If correct on A, how to understand the dimensions? Perhaps a 36x9" lathe has 36" between centers, and 9" is the max. diameter of basic stock? Right again. (well, the 9" is the distance from the bed to the center - you may have trouble mounting 9"stock) snipped Minor correction: I believe that 'swing' is actually the maximum diameter of the work. 9" swing would mean 4 1/2" between the bed (rails that the tailstock moves on) and the centerline. Charlie It used to depend on the country but now everything I see for sale seems to be max diameter turned. Bigger numbers sound better I guess. Karl |
"Charlie" wrote in message
.. . snipped B) If correct on A, how to understand the dimensions? Perhaps a 36x9" lathe has 36" between centers, and 9" is the max. diameter of basic stock? Right again. (well, the 9" is the distance from the bed to the center - you may have trouble mounting 9"stock) snipped Minor correction: I believe that 'swing' is actually the maximum diameter of the work. 9" swing would mean 4 1/2" between the bed (rails that the tailstock moves on) and the centerline. Yes, my mistake. -- Geoff The Sea Hawk at Wow Way d0t Com remove spaces and make the obvious substitutions to reply by mail When immigration is outlawed, only outlaws will immigrate. |
Mini Lathes | Kyle Boatright | Home Built | 11 | August 18th 08 05:56 AM |
Caddo Mills SW Soaring Closing 31 Dec | [email protected] | Soaring | 10 | December 14th 07 04:14 PM |
PMA Questions | Mike Granby | Piloting | 24 | December 11th 05 11:24 PM |
Mig-29 questions & general aviation questions 2003 | Steven | Military Aviation | 1 | October 20th 03 06:06 AM |
Seven Questions For Michael Moore from a Blogger (was Questions for Mr. Bush, from Michael Moore) | Jim Yanik | Military Aviation | 2 | October 9th 03 09:36 PM |
