Wonder if this is where we will see thermal sensing instruments
developed. Probably eventually trickle down into our cockpits someday. Brad On Aug 18, 6:57*am, Richard wrote: On Aug 18, 6:38*am, Burt Compton - Marfa wrote: From the AvWeb AvFlash news: Unmanned Gliders To Seek Their Own Lift "Automated on-board energy aware planning" is being developed by the U.K.'s Roke Manor Research to allow autonomous gliders to find naturally occurring lift and sustain unpowered or prolong powered flight, according to a report in ElectronicsWeekly.com. Ultimately, aircraft equipped with software and hardware that actively processes video feeds of cloud conditions and surface type (cool grass, or hot pavement) data would be processed along with other elements (models assessing weather and predicting vertical air movement due to thermal and orographic lift) to identify thermals and share that information with similar aircraft nearby. With that information, a virtual and real-time lift map could help produce waypoint sequences for use by integrated flight management systems aboard the aircraft as they hopscotch from lift-point to lift-point along a route. The aircraft would literally be led to their required destination via a route that applies all acquired information to avoid areas of sink and exploit the best areas of lift between the departure point and destination point. Current proposed applications for the developing technology include extending the flight range of unmanned aerial vehicles. Burt, Several college students from North Carolina State University showed up at the Montague Cross Country Challege in June 2008 (A model cross county competition). *They had their own version of what you reported above. http://goosetech.homelinux.com/soaring/index.php Richardwww.craggyaero.com- Hide quoted text - - Show quoted text - |
On Aug 18, 7:17 am, Brad wrote:
Wonder if this is where we will see thermal sensing instruments developed. Probably eventually trickle down into our cockpits someday. Brad On Aug 18, 6:57 am, Richard wrote: On Aug 18, 6:38 am, Burt Compton - Marfa wrote: From the AvWeb AvFlash news: Unmanned Gliders To Seek Their Own Lift "Automated on-board energy aware planning" is being developed by the U.K.'s Roke Manor Research to allow autonomous gliders to find naturally occurring lift and sustain unpowered or prolong powered flight, according to a report in ElectronicsWeekly.com. Ultimately, aircraft equipped with software and hardware that actively processes video feeds of cloud conditions and surface type (cool grass, or hot pavement) data would be processed along with other elements (models assessing weather and predicting vertical air movement due to thermal and orographic lift) to identify thermals and share that information with similar aircraft nearby. With that information, a virtual and real-time lift map could help produce waypoint sequences for use by integrated flight management systems aboard the aircraft as they hopscotch from lift-point to lift-point along a route. The aircraft would literally be led to their required destination via a route that applies all acquired information to avoid areas of sink and exploit the best areas of lift between the departure point and destination point. Current proposed applications for the developing technology include extending the flight range of unmanned aerial vehicles. Burt, Several college students from North Carolina State University showed up at the Montague Cross Country Challege in June 2008 (A model cross county competition). They had their own version of what you reported above. http://goosetech.homelinux.com/soaring/index.php Richardwww.craggyaero.com-Hide quoted text - - Show quoted text - Boy, I don't like the sound of this. Bas enough we have to share open sky with powered UAV's in ever increasing numbers, now the possibility of sharing thermals too? Yikes. Mars is sounding better every day! It would indeed yield the highly coveted 'thermal sniffer' (probably the very instrument Johnson described in Kemp's video), but to me would not at all be worth the price... (soaring with UAV's) Violently Opposed, -Paul |
On Aug 18, 10:41*am, sisu1a wrote:
On Aug 18, 7:17 am, Brad wrote: Wonder if this is where we will see thermal sensing instruments developed. Probably eventually trickle down into our cockpits someday. Brad On Aug 18, 6:57 am, Richard wrote: On Aug 18, 6:38 am, Burt Compton - Marfa wrote: From the AvWeb AvFlash news: Unmanned Gliders To Seek Their Own Lift "Automated on-board energy aware planning" is being developed by the U.K.'s Roke Manor Research to allow autonomous gliders to find naturally occurring lift and sustain unpowered or prolong powered flight, according to a report in ElectronicsWeekly.com. Ultimately, aircraft equipped with software and hardware that actively processes video feeds of cloud conditions and surface type (cool grass, or hot pavement) data would be processed along with other elements (models assessing weather and predicting vertical air movement due to thermal and orographic lift) to identify thermals and share that information with similar aircraft nearby. With that information, a virtual and real-time lift map could help produce waypoint sequences for use by integrated flight management systems aboard the aircraft as they hopscotch from lift-point to lift-point along a route. The aircraft would literally be led to their required destination via a route that applies all acquired information to avoid areas of sink and exploit the best areas of lift between the departure point and destination point. Current proposed applications for the developing technology include extending the flight range of unmanned aerial vehicles. Burt, Several college students from North Carolina State University showed up at the Montague Cross Country Challege in June 2008 (A model cross county competition). *They had their own version of what you reported above. http://goosetech.homelinux.com/soaring/index.php Richardwww.craggyaero.com-Hidequoted text - - Show quoted text - Boy, I don't like the sound of this. Bas enough we have to share open sky with powered UAV's in ever increasing numbers, now the possibility of sharing thermals too? Yikes. Mars is sounding better every day! It would indeed yield the highly coveted 'thermal sniffer' (probably the very instrument Johnson described in Kemp's video), but to me would not at all be worth the price... (soaring with UAV's) Violently Opposed, -Paul- Hide quoted text - - Show quoted text - What would be wrong with sharing a thermal with a UAV? We already share them with birds, cornstalks, plastic bags, and the occasional airliner - to say nothing of random 2-33s flown by student pilots, intently staring at their non-compensated mechanical vario for any sign of lift! That almost qualifies as a UAV itself! More thermal markers, too. I think it would be cool - and the UAV would probably have better thermalling etiquette than a lot of pilots out there... BTW, I bet if you had a transponder, the UAV would be programmed to avoid you like the plague! Kirk 66 |
![]() "kirk.stant" wrote in message ... BTW, I bet if you had a transponder, the UAV would be programmed to avoid you like the plague! Kirk 66 Oh boy, a whole new game! Hunt down the soaring UAV and "bump" it out of the thermal (g). bumper zz |
bumper wrote:
"kirk.stant" wrote in message ... BTW, I bet if you had a transponder, the UAV would be programmed to avoid you like the plague! Oh boy, a whole new game! Hunt down the soaring UAV and "bump" it out of the thermal (g). Good idea: get a PCAS unit like the Zaon MRX and use it to find UAVs, grab it's thermal while it leaves to find the next one! In fact, a UAV could be considered a remote thermal sensing instrument. How about carrying small one folded up in the glider? When the soaring gets tough, you launch it to help you find thermals. It could carry a Spot so you could find it later it was unable to return home on it's own. The glider could be carried in a tube under the wing or on top of the fuselage, or inside the fuselage with doors like a motor glider. Or ... Forget the transponder: just have Spot send text messages to your cell phone, so you know where the UAV is. FLARM is another way the UAVs could be avoided, and eventually they will all use ADS-B. -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * Updated! "Transponders in Sailplanes" http://tinyurl.com/y739x4 * New Jan '08 - sections on Mode S, TPAS, ADS-B, Flarm, more * "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
A UAV as thermal sniffer? Yikes!-Those things will probably be controlled by
software, written by humans -Forget it. Instead, rely on million of years of systems testing, bring an eagle along (would look awful when you open the doors to the Raptor Compartment!) Seriously; paragliders do this with success: http://www.youtube.com/watch?v=Ri23mLIDuFM more pictures at http://www.crandal.dk/louise.htm Happy Soaring, Lars Peder DG-600/18 (non-raptor version, sofar), Denmark "Eric Greenwell" wrote in message news ![]() bumper wrote: "kirk.stant" wrote in message ... BTW, I bet if you had a transponder, the UAV would be programmed to avoid you like the plague! Oh boy, a whole new game! Hunt down the soaring UAV and "bump" it out of the thermal (g). Good idea: get a PCAS unit like the Zaon MRX and use it to find UAVs, grab it's thermal while it leaves to find the next one! In fact, a UAV could be considered a remote thermal sensing instrument. How about carrying small one folded up in the glider? When the soaring gets tough, you launch it to help you find thermals. It could carry a Spot so you could find it later it was unable to return home on it's own. The glider could be carried in a tube under the wing or on top of the fuselage, or inside the fuselage with doors like a motor glider. Or ... Forget the transponder: just have Spot send text messages to your cell phone, so you know where the UAV is. FLARM is another way the UAVs could be avoided, and eventually they will all use ADS-B. -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * Updated! "Transponders in Sailplanes" http://tinyurl.com/y739x4 * New Jan '08 - sections on Mode S, TPAS, ADS-B, Flarm, more * "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
At 18:44 18 August 2008, Lars Peder Hansen wrote:
Instead, rely on million of years of systems testing, bring an eagle along (would look awful when you open the doors to the Raptor Compartment!) Should be quite simple to swap out a turbo and use the bay as a raptor compartment. I can see that training a bird to return might require a lot of work. Those fishing reels might have to be used for bait lines rather than bug wipers. Rory |
Put the whole kit and kaboodle in the glider, send it around the course
while you stay in the club's bar, and then go out and catch the wingtip when it lands. Pretend you flew it and turn the flight in to the online soaring contest -- that is unless an FAA representative is there and notices the alcohol on your breath, but you can explain the situation to him and turn the flight in later. At 18:16 18 August 2008, Eric Greenwell wrote: bumper wrote: "kirk.stant" wrote in message ... BTW, I bet if you had a transponder, the UAV would be programmed to avoid you like the plague! Oh boy, a whole new game! Hunt down the soaring UAV and "bump" it out of the thermal (g). Good idea: get a PCAS unit like the Zaon MRX and use it to find UAVs, grab it's thermal while it leaves to find the next one! In fact, a UAV could be considered a remote thermal sensing instrument. How about carrying small one folded up in the glider? When the soaring gets tough, you launch it to help you find thermals. It could carry a Spot so you could find it later it was unable to return home on it's own. The glider could be carried in a tube under the wing or on top of the fuselage, or inside the fuselage with doors like a motor glider. Or ... Forget the transponder: just have Spot send text messages to your cell phone, so you know where the UAV is. FLARM is another way the UAVs could be avoided, and eventually they will all use ADS-B. -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * Updated! "Transponders in Sailplanes" http://tinyurl.com/y739x4 * New Jan '08 - sections on Mode S, TPAS, ADS-B, Flarm, more * "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
better yet.............why doesn't the govt hire us sailplane pilots
to keep our eyes out for the bad guys..................whomever they may be at the moment. I've called in fires and other strange things I've seen in the backwood before..............heck, maybe they'll even pay for my tow! of course, if the "bad guys" catch on to possibly getting busted by an orbiting sailplane, I guess we could face getting shot at....................somthing I've wondered about occasionally when I've heard gunshots while flying..........must've been to high to hear the banjos playing tho................... Brad On Aug 18, 12:09*pm, Nyal Williams wrote: Put the whole kit and kaboodle in the glider, send it around the course while you stay in the club's bar, and then go out and catch the wingtip when it lands. *Pretend you flew it and turn the flight in to the online soaring contest -- that is unless an FAA representative is there and notices the alcohol on your breath, but you can explain the situation to him and turn the flight in later. At 18:16 18 August 2008, Eric Greenwell wrote: bumper wrote: "kirk.stant" *wrote in message .... BTW, I bet if you had a transponder, the UAV would be programmed to avoid you like the plague! Oh boy, a whole new game! Hunt down the soaring UAV and "bump" it out of the thermal (g). Good idea: get a PCAS unit like the Zaon MRX and use it to find UAVs, grab it's thermal while it leaves to find the next one! In fact, a UAV could be considered a remote thermal sensing instrument. How about carrying small one folded up in the glider? When the soaring gets tough, you launch it to help you find thermals. It could carry a Spot so you could find it later it was unable to return home on it's own. The glider could be carried in a tube under the wing or on top of the fuselage, or inside the fuselage with doors like a motor glider. Or ... Forget the transponder: just have Spot send text messages to your cell phone, so you know where the UAV is. FLARM is another way the UAVs could be avoided, and eventually they will all use ADS-B. -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * Updated! "Transponders in Sailplanes"http://tinyurl.com/y739x4 * ** New Jan '08 - sections on Mode S, TPAS, ADS-B, Flarm, more * "A Guide to Self-launching Sailplane Operation" atwww.motorglider.org- Hide quoted text - - Show quoted text - |
On Aug 18, 10:37*am, "bumper" wrote:
"kirk.stant" wrote in message ... BTW, I bet if you had a transponder, the UAV would be programmed to avoid you like the plague! Kirk 66 Oh boy, a whole new game! Hunt down the soaring UAV and "bump" it out of the thermal (g). bumper zz Not a glider, but.....Three points of view. Depends on the bumpee, I suppose http://www.ntsb.gov/ntsb/brief.asp?e...29X01124&key=1 http://www.flightglobal.com/articles...air-force.html http://www.airforcetimes.com/news/20...crash_081208w/ |
I seek your knowledge. | William Hung[_2_] | Piloting | 2 | July 8th 08 01:58 PM |
I seek your knowledge. | William Hung[_2_] | Home Built | 2 | July 8th 08 01:58 PM |
FAA authorizes Predators to seek survivors | Dave S | Piloting | 0 | August 3rd 06 03:38 PM |
NEWS: New Jet to Seek Turbulence | Skywise | Piloting | 9 | March 3rd 06 02:11 PM |
JSTARS, River Joint, U-2s to seek bin Laden | AllanStern | Military Aviation | 19 | March 12th 04 08:22 PM |
