Charles wrote:
Most A&P's would think very poorly of any Cherry rivet used where a solid rivet is just as easily installed. My experience has been that solid rivets perform far better than any blind rivet if installed correctly. Consider buying the tools, practicing, and using solid rivets. Where I work, much of the sheetmetal jobs are replkacing working Cherry Max or Cherry rivets that have started to work loose. They should only be used where the back side is not accessible. They can be used for nonstructural applications also. I'd go with what the designer called for or with what was there in the first place, but that's just me. I'm sufficiently old fashioned about things like this I wouldn't use fiberfill nuts on flight controls either. Dan, U.S. Air Force, retired |
| Thread Tools | |
| Display Modes | |
| Rivet Guns | tdfsks | Home Built | 3 | July 21st 05 02:43 AM |
| Brake Rivet Problem | Jonathan Goodish | Owning | 12 | May 18th 05 09:14 PM |
| Another Rivet Question | c hinds | Home Built | 6 | October 31st 04 05:25 PM |
| WTB: Rivet 3x ,Hand Sqeezer, | Ken B | Aviation Marketplace | 0 | September 13th 04 12:49 AM |
| need link for SS rivet supplier | Charles S | Home Built | 1 | May 9th 04 03:34 AM |
