In rec.aviation.student Mxsmanic wrote:
Anyway, back to the topic ... it's true that I can fly in the general direction of a road instead of following it precisely, but I find that it's easy to get so far away that it's hard to see the road any more. Some Interstates will turn west for miles, and then turn east again, and so on. They stay in one direction long enough to get away from you if you are trying to keep an "average" heading, but if you turn you have to change altitude. Climbing and descending 2000 feet every few minutes seems like a lot for a small aircraft. Visibility must be really poor if you're doing this. I doubt an interstate is making regular course changes of more than 90 degrees, so you should be cutting the corners and seeing a maximum angle of 45 degrees to it. A few minutes really shouldn't be taking you so far away from it that you can't see it anymore. Even if you do get to where you can't see it, you're presumably flying a course that will intersect it again soon, so you can keep your position based on other landmarks until it heaves into view once again. I haven't seen anything in the FARs that provides a way around this for cruise flight, except, as Bob has pointed out, flying below 3000 AGL. That would work well enough in Iowa, and then the problem is solved. But over hilly terrain it gets more difficult, and also other rules come into play for low-altitude flight, such as the need to respect limitations over congested areas, wildlife preserves, etc. You could always try flying a glider instead. Nobody expects you to hold any particular cruise altitudes there. ![]() -- Mike Ash Radio Free Earth Broadcasting from our climate-controlled studios deep inside the Moon |
Maintaining altitude | Mxsmanic | Piloting | 45 | May 20th 08 02:35 AM |
if the genetic images can convict eerily, the chief farmer may hate more rivers | Youssef Sadam Bin Duran | Piloting | 0 | August 14th 07 12:47 AM |
Maintaining currency/proficiency after getting my Instrument rating | Gary Drescher | Instrument Flight Rules | 0 | March 2nd 06 12:49 PM |
Sun goes dark, rivers run red, Facetmobile webpage updated. | Richard Riley | Home Built | 32 | June 8th 04 09:02 PM |
Secondary roads? | D Grunloh | Simulators | 2 | December 16th 03 02:04 PM |
