there are no readily available statistics to answer that question.
we are working up the statistics on percentage of experimental aircraft vs other aircraft based at the airport, and also the percentage of training, vs local vs transient. Many accidents in the past have involved transient pilots not familiar with high density altitude operations or desert wind conditions. BT "Mxsmanic" wrote in message ... BT writes: NTSB statistics prove that of the 37 accidents at this airport since the county took over in 1982, only 3 were experimental aircraft. What percentage of all aircraft movements were experimental aircraft during the same period? |
BT writes:
there are no readily available statistics to answer that question. Unfortunately, unless one knows the total number of movements of both experimental and other aircraft, as well as the absolute numbers of accidents for both, the latter alone isn't of much use. we are working up the statistics on percentage of experimental aircraft vs other aircraft based at the airport, and also the percentage of training, vs local vs transient. Movements would be much more cogent than the number of aircraft based at the airport. Many accidents in the past have involved transient pilots not familiar with high density altitude operations or desert wind conditions. Which airport is this? |
Mxsmanic wrote in
: BT writes: there are no readily available statistics to answer that question. Unfortunately, unless one knows the total number of movements of both experimental and other aircraft, as well as the absolute numbers of accidents for both, the latter alone isn't of much use. You are an idiot. Bertie |
Anthony, the only movements important to your pathetic life are bowel
movements. |
2nd cellphone for retrieve/rural areas US | chris | Soaring | 6 | May 4th 08 07:47 PM |
Experimentals down in Fla | stol | Home Built | 26 | March 10th 08 02:52 PM |
Red Arrows banned from olympics - British PC strikes again | stevehaley | Soaring | 13 | October 5th 07 07:01 PM |
Has Southwest Airlines banned aspartame from the cockpit? | Dylan Smith | Piloting | 42 | August 31st 04 03:10 PM |
Airshows should be banned...Now! | Tetherhorne P. Flutterblast | Military Aviation | 28 | June 15th 04 02:43 AM |
