Riveting question
Old August 29th 08, 07:52 PM posted to rec.aviation.homebuilt
Michael Horowitz
Default Riveting question
I'm spending a drizzly day going thru the section of AC43 dealing with
riveting and have an initial question. I think I know the answer but
could use some comformation.
Figure 4-5 shows Rivet spacing for single-lap sheet splice. It shows a
double row of rivets in one case and the note "Strength thru this
section is 75% of sheet w/o holes". In the second illustration it show
more than two rows of rivets and a greater overlap with the note
"Strength thru this section is 83% of sheet without holes".
My question is/was "How do you determine how much overlap there should
be?"
My tentative answer is "The more rivets, the stronger the joint. If
75% of the original sheet strength is fine, then overlap enough to
sustain a double row of rivets. If 83% is needed, then go to an
overlap that will support three rows of rivets. "
Is my logic correct?
Also, is 83% as good as it gets? if so, why show more than 3 rows?
- Mike
Question about rivets and riveting.... gregg Home Built 6 May 8th 05 04:05 AM
Shinn brake lining/riveting/counterboring depth? Michael Horowitz Owning 0 August 29th 04 04:12 PM
From the ground up ... question about riveting Marco Rispoli Home Built 4 July 19th 04 01:05 AM
Shinn brake linings - bonding vice riveting Michael Horowitz Owning 0 July 12th 04 04:47 PM
Dimpling and riveting pressures Max Krippler Home Built 5 November 11th 03 08:03 PM
