Too Old?
Old September 1st 08, 10:36 PM posted to rec.aviation.homebuilt,rec.aviation.owning,rec.aviation.piloting
Dudley Henriques[_2_]
Default Too Old?
Gezellig wrote:
On Mon, 01 Sep 2008 13:30:50 -0400, Dudley Henriques wrote:
Ben Jeffrey wrote:
Orval Fairbairn wrote:
I know quite a few pilots flying well into their 70s -- some in
high-performance planes.
Hell Orval, it took that long for some of us to get proficient :-)))
Dudley Henriques
I have a friend in our soaring club who flew Corsairs as a USMC pilot in WW2
and still flys regularly in our club - usually the first to launch and the
last to land. To top it off, most of the time he flys his Pitts to the club
from his home field.
Ben Jeffrey
Some of the "older" pilots are in phenomenally good health. I deal with
a lot of them on a daily basis. They're amazing!
And some aren't Dudley neither of which is the point. The point is that
Fed/FAA gets aggressive, age could come into question regardless. For
that matter, why not a local port like Vegas throwing up their own
rules?
The one's that aren't should fail the medical. THAT is the point. The
"system" is supposed to discover and weed out those not medically fit to
fly.
As long as you can pass the medical, you fly. It's THAT simple!
Nobody says the system is perfect. There will always be those pilots who
slip through a medical check and then have a heart attack while flying.
Personally, I would be an advocate of more frequent medical checks for
pilots of a specific age determined by accident stats and medical
histories.
Of course if they went that route, you'd have the ACLU on their ass
screaming about "rights".
There is only one additional safety gap in the present system; that
being the individual choice of a pilot to voluntarily stop flying after
having a medical issue during the period between medicals.
As I said, it "ain't " a perfect system by a long shot!
Dudley Henriques
Old September 1st 08, 10:58 PM posted to rec.aviation.homebuilt,rec.aviation.owning,rec.aviation.piloting
Stuart & Kathryn Fields
Default Too Old?
Dudley Henriques
in WW2 and still flys regularly in our club - usually the first to
launch and the last to land. To top it off, most of the time he flys
his Pitts to the club from his home field.
Ben Jeffrey
rules?
fly.
histories.
There is only one additional safety gap in the present system; that being
the individual choice of a pilot to voluntarily stop flying after having a
Dudley Henriques
Hell, I'm 72 and fly an experimental helicopter which, because of my
modifications involve a bit of "Test Flying". More than that, I recently
soloed an ultralight helicopter where the only check out possible was to get
the numbers for rpm and egt.
If they are going to put age limits on flying, they better start with age
limits for people driving and especially driving those huge motor homes just
a few feet from my car at closing velocities around 150mph and better.
Did you know that those motor homes have a refrigerator that can store cold
beer just a couple of feet behind the driver? It is obvious that you can
legally have an open container in your motor home.
Old September 2nd 08, 09:31 PM posted to rec.aviation.homebuilt,rec.aviation.owning,rec.aviation.piloting
Gezellig
Default Too Old?
Apples and oranges imo Stu-Kath.
Old September 2nd 08, 10:24 PM posted to rec.aviation.homebuilt,rec.aviation.owning,rec.aviation.piloting
Lonnie[_3_]
Default Too Old?
"Gezellig" wrote in message
get
age
just
It wouldn't be IMO. I have a much greater fear of getting creamed head on,
than dodging falling private aircraft.
Old September 3rd 08, 03:04 AM posted to rec.aviation.homebuilt,rec.aviation.owning,rec.aviation.piloting
Mike[_22_]
Default Too Old?
"Lonnie" @_#~#@.^net wrote in message
recently
get
age
just
From behind the keyboard at mommy's house there's not much chance either
way, Maxie.
Old September 3rd 08, 05:03 AM posted to rec.aviation.homebuilt,rec.aviation.owning,rec.aviation.piloting
Gezellig
Default Too Old?
Flying isn't often the necessity that car Xport is.
Old September 3rd 08, 06:31 PM posted to rec.aviation.homebuilt,rec.aviation.owning,rec.aviation.piloting
Steve Hix
Default Too Old?
Depends on where you are, among other things.
Old September 2nd 08, 01:08 AM posted to rec.aviation.homebuilt,rec.aviation.owning,rec.aviation.piloting
K l e i n[_2_]
Default Too Old?
Dudley Henriques
Ben Jeffrey
rules?
fly.
histories.
Dudley Henriques
Well, you know, they already do that. A 3rd class medical is good for
substantially longer period of time if you are younger than 40. Also,
if you report certain conditions, etc, they give you a "special
issuance" with a 1 year limit for all classes, including 3rd.
Old September 2nd 08, 01:44 AM posted to rec.aviation.homebuilt,rec.aviation.owning,rec.aviation.piloting
Default Too Old?
Dudley Henriques
Ben Jeffrey
rules?
fly.
histories.
Dudley Henriques
This is true, but not what I'm addressing exactly. I would have no
problem with medicals requiring a shorter active period based on a
proactive projection of accident stats vs health issues within a
specific age bracket graduated after say a beginning point of 40.
In other words, the older you get and/or when you enter into an age
bracket where stats put you at a higher risk factor, the period of your
medical shortens accordingly.
The rub in all this, even in my own projection, is that it assumes that
sooner or later a pilot will reach a "no further medicals allowed" point
where a mandatory retirement is indicated.
Considering present regulations, the engine to implement such a plan
would be extremely difficult to design and push through the required
legislation.
Dudley Henriques
Old September 2nd 08, 09:36 PM posted to rec.aviation.homebuilt,rec.aviation.owning,rec.aviation.piloting
Gezellig
Default Too Old?
On Mon, 01 Sep 2008 20:44:51 -0400, Dudley Henriques wrote:
I would have no
This makes sense especially if the quality of the medical is increased
accordingly.
Disagree. If you can pass a sophisticated and comprehensive medical,
there should be no approach points. Pass = fly regardless of age.
legislation.
Can't argue with this, don't have the expertise.
