Gezellig wrote:
On Mon, 01 Sep 2008 20:44:51 -0400, Dudley Henriques wrote: I would have no problem with medicals requiring a shorter active period based on a proactive projection of accident stats vs health issues within a specific age bracket graduated after say a beginning point of 40. In other words, the older you get and/or when you enter into an age bracket where stats put you at a higher risk factor, the period of your medical shortens accordingly. This makes sense especially if the quality of the medical is increased accordingly. The rub in all this, even in my own projection, is that it assumes that sooner or later a pilot will reach a "no further medicals allowed" point where a mandatory retirement is indicated. Disagree. If you can pass a sophisticated and comprehensive medical, there should be no approach points. Pass = fly regardless of age. Make sure we're on the same page with the above. I might not have stated this as accurately as I should have, What I'm saying doesn't conflict with the Pass= fly regardless of age. It simply RECOGNIZES that at a certain point while following the "plan", a pilot WILL reach a specific point in time where the medical can no longer be passed. In other words, Fail= no longer fly. What I'm saying is simply that even my "plan" so to speak, ends up with basically what we have now :-)) You fly until you can't pass the physical then no more. The same issue remains. The "rub" is that no matter what is done, the end of the road seems unchanged. There can very well be a point where the pilot passes the physical at some ripe old age, then has that heart attack in the air during the periods between physicals. This is the basis for what I have envisioned as a "plan" to shorten the period between physicals as a pilot ages. Considering present regulations, the engine to implement such a plan would be extremely difficult to design and push through the required legislation. Can't argue with this, don't have the expertise. You're doing well :-)) -- Dudley Henriques |
Dudley Henriques wrote in
: Make sure we're on the same page with the above. I might not have stated this as accurately as I should have, What I'm saying doesn't conflict with the Pass= fly regardless of age. It simply RECOGNIZES that at a certain point while following the "plan", a pilot WILL reach a specific point in time where the medical can no longer be passed. In other words, Fail= no longer fly. What I'm saying is simply that even my "plan" so to speak, ends up with basically what we have now :-)) You fly until you can't pass the physical then no more. The same issue remains. The "rub" is that no matter what is done, the end of the road seems unchanged. There can very well be a point where the pilot passes the physical at some ripe old age, then has that heart attack in the air during the periods between physicals. This is the basis for what I have envisioned as a "plan" to shorten the period between physicals as a pilot ages. My situation is one of cost. I can easily pass the FAA Medical (even at my age) but have decided not to try after passing my last one. I have a Special Issuance wherein the FAA required documentation from each of my two physicians. My Medical Group charges nearly $100 per "official" letter and then there's the AME fee. I felt that a little under $300 each year was a tad much at this time so it may well be that it's time to hang up the spurs or do other flying alternatives. -- |
![]() "John Godwin" wrote in message ... My situation is one of cost. I can easily pass the FAA Medical (even at my age) but have decided not to try after passing my last one. I have a Special Issuance wherein the FAA required documentation from each of my two physicians. My Medical Group charges nearly $100 per "official" letter and then there's the AME fee. I felt that a little under $300 each year was a tad much at this time so it may well be that it's time to hang up the spurs or do other flying alternatives. -- That a shame John, sorry to hear it. How old are you, and why the special? |
"Lonnie" @_#~#@.^net wrote in
: How old are you, and why the special? Pushing 70 and well-controlled Type II Diabetes (A1C=6.0 and decreasing) and Chronic lymphocytic leukemia. -- |
![]() "Pietro" wrote in message ... "Lonnie" @_#~#@.^net wrote in : How old are you, and why the special? Pushing 70 and well-controlled Type II Diabetes (A1C=6.0 and decreasing) and Chronic lymphocytic leukemia. -- I'm very sorry to hear that. I wish you the best of luck with your situation. I've always thought when I'm eventually facing the same dilemma, I'll look for a younger pilot that wants to build some time to fly right seat. |
John Godwin wrote:
Dudley Henriques wrote in : Make sure we're on the same page with the above. I might not have stated this as accurately as I should have, What I'm saying doesn't conflict with the Pass= fly regardless of age. It simply RECOGNIZES that at a certain point while following the "plan", a pilot WILL reach a specific point in time where the medical can no longer be passed. In other words, Fail= no longer fly. What I'm saying is simply that even my "plan" so to speak, ends up with basically what we have now :-)) You fly until you can't pass the physical then no more. The same issue remains. The "rub" is that no matter what is done, the end of the road seems unchanged. There can very well be a point where the pilot passes the physical at some ripe old age, then has that heart attack in the air during the periods between physicals. This is the basis for what I have envisioned as a "plan" to shorten the period between physicals as a pilot ages. My situation is one of cost. I can easily pass the FAA Medical (even at my age) but have decided not to try after passing my last one. I have a Special Issuance wherein the FAA required documentation from each of my two physicians. My Medical Group charges nearly $100 per "official" letter and then there's the AME fee. I felt that a little under $300 each year was a tad much at this time so it may well be that it's time to hang up the spurs or do other flying alternatives. That's a CRIME. I'm VERY sorry this is happening to you. I never quite know what to do or say when I see things like this happening to a pilot. We're at the mercy of these damn doctors and they know it. You could complain, but many times that simply ends up in an endless loop that goes nowhere. Charging $100 to fill out a form is a gross over charge and the only reason they can get away with it is because you HAVE to have it. This doctor could easily have been a lawyer! -- Dudley Henriques |
Dudley Henriques writes:
Charging $100 to fill out a form is a gross over charge and the only reason they can get away with it is because you HAVE to have it. Then again, if the doctor fills out the form and signs it for a pilot, and the pilot later dies in flight, the doctor gets sued, even if the cause of death had nothing to do with the doctor's evaluation. So it works both ways. |
You're wrong again, and obviously know nothing about the medical process or
the practice of medicine. |
Viperdoc writes:
You're wrong again, and obviously know nothing about the medical process or the practice of medicine. Well, if a licensed physician joins the group and cares to comment, I'll be happy to read his posts. |
happy to read his posts. Anthony, as a licensed pilot, a physician, flight surgeon, and AME, I don't need to even bother responding to your ridiculous challenge. Besides, I thought you had little regard for credentials? Is there something not factual in my comments that you are not a physician or pilot and have never held a medical? If so, please enlighten the rest of us. Seems like you're a little sensitive on the subject, or the fact that you have no credibility-it certainly looked like an emotional response. |
