Mode S transponder display to ATC?
Old September 4th 08, 10:28 PM posted to rec.aviation.ifr
Mike[_22_]
Default Mode S transponder display to ATC?
m...
paul kgyy wrote:
Is it normal practice for a Mode S transponder to display the aircraft
tail number to ATC?
No.
It isn't displayed to controllers, but a ModeS transponder does transmit its
serial number which can be read using tools not available to the controller.
The serial number does translate to the N number so long as the transponder
is correctly registered. As of now this technology hasn't been implemented
to the controller, nor is the serial number recorded in the continuous data
recording archive.
Old September 4th 08, 11:51 PM posted to rec.aviation.ifr
Peter Clark
om...
tail number to ATC?
No.
recording archive.
Doesn't the system process the flightid field? Or isn't that
transmitted?
Old September 5th 08, 01:41 AM posted to rec.aviation.ifr
Mike[_22_]
"Peter Clark" wrote in message
news:TMOdnSYGZc1D0F3VnZ2dnUVZ_gadnZ2d@earthlink. com...
tail number to ATC?
No.
its
controller.
transponder
implemented
data
recording archive.
transmitted?
I'm not sure what "system" or "field" you're referring. The computers at
the centers and tracons have no idea if the transponder is ModeS or not.
They only process the beacon code and display the ACID that's in the flight
plan.
Old September 5th 08, 02:15 AM posted to rec.aviation.ifr
Bob Noel
plan.
The centers and tracons don't have Mode S radars yet?
Bob Noel
(goodness, please trim replies!!!)
Old September 5th 08, 02:52 AM posted to rec.aviation.ifr
Jay Maynard
plan.
Some do, some don't. The problem is not the radar or the computer behind it,
bu the computer driving the displays that the controllers see: they don't
get the mode S data.
Jay Maynard, K5ZC http://www.conmicro.com
http://jmaynard.livejournal.com http://www.tronguy.net
Fairmont, MN (FRM) (Yes, that's me!)
AMD Zodiac CH601XLi N55ZC
Old September 5th 08, 01:28 PM posted to rec.aviation.ifr
Mike[_22_]
"Bob Noel" wrote in message
flight
plan.
The centers never have and never will other than a few terminal radars which
are piped into the centers for low level coverage in some areas. The ModeS
systems themselves are located all over the US, but there's no datalink
capability between the sensor and the automation system. So the only thing
forwarded to the TRACON from the transponder is the 4 digit octal beacon
code and the 3 digit altitude.
Old September 5th 08, 08:53 AM posted to rec.aviation.ifr
Thomas Borchert
Peter,
Some do. In Europe, more and more do.
Or isn't that
transmitted?
It certainly is.
Thomas Borchert (EDDH)
Old September 7th 08, 08:29 AM posted to rec.aviation.ifr
Sam Spade
Thomas Borchert wrote:
Peter,
Or isn't that
transmitted?
It certainly is.
Not in the U.S.
Old September 7th 08, 09:14 AM posted to rec.aviation.ifr
Thomas Borchert
Sam,
Not in the U.S.
Source? A source that shows a Garmin GTX330 does not transmit flight ID
data in the US would suffice.
Old September 7th 08, 07:04 PM posted to rec.aviation.ifr
Mike[_22_]
"Thomas Borchert" wrote in message
Sam,
Not in the U.S.
If a tree falls in the woods, but nobody is there to hear it, does it make a
sound?
Garrecht Mode S transponder - USA? Eric Greenwell Soaring 3 August 20th 07 09:05 PM
New transponder mode S vs. mode C Tom N. Soaring 39 November 7th 06 07:40 AM
KT76C Mode C transponder - what is it worth? Mike Rapoport General Aviation 1 November 21st 04 05:56 AM
KT76C Mode C transponder - what is it worth? G.R. Patterson III Owning 0 November 21st 04 05:56 AM
WTB: Mode C Transponder Chris Batcheller Aviation Marketplace 0 February 21st 04 01:31 PM
