On Sep 5, 7:58*am, mhorowit wrote:
New to riveting here. Reading on basics show the impact on the manufactured head is transmitted along the rivet and forces the bucking bar off the bucktail. It then slams back, causing the rivet shaft to begin to deform. Because the bucking bar needs to move, does this mean it can not be clamped in a vice? - Mike You could clamp it in vice. There is a process called back riveting in which the rivet gun and a flush set is used to directly upset the buck tail while the manufactured head is held against the bucking bar; I have seen it used when someone is riveting flush rivets in thin skins and the flush head is held against a flat plate. This would be similar to what you propose. The key is to keep the slamming effect to a minimum by keeping pressure through the rivet from the gun to the bucking bar. Once the bar or the set or the rivet really move around that is when you will have smiles at best or tool strikes at worst. John Dupre' |
PLEASE SIGN THE MITT ROMNEY FOR VICE PRESIDENT PETITION! | Publius1787 | Naval Aviation | 0 | April 8th 08 05:01 PM |
Boeing Vice President To Speak (Available On-line) | Larry Dighera | Piloting | 0 | March 13th 08 08:46 PM |
Shinn brake linings - bonding vice riveting | Michael Horowitz | Owning | 0 | July 12th 04 04:47 PM |
Air Vice Marshal Tony Dudgeon | Keith Willshaw | Military Aviation | 0 | January 9th 04 12:43 PM |
What is the reasoning behind the smaller radius vice presidential TFR? | Larry Dighera | Piloting | 38 | November 19th 03 04:04 PM |
